Go to Post Patience is the key to FIRST. - Pavan Dave [more]
Unread 14-01-2006, 10:54
coastertux coastertux is offline
Penn State Class of 2010!
AKA: Steve
FRC #1640 (sab-BOT-age)
coastertux is just really nicecoastertux is just really nicecoastertux is just really nicecoastertux is just really nicecoastertux is just really nice
Send a message via AIM to coastertux
CMU Cam not Tracking Properly on Robot
When the camera is on the bench, it tracks perfectly in LabView (after putting a jumper on the pins to flip the Pan). When we hook it into the robot via TTL and PWM 1 (Pan Servo) and 2 (Tilt Servo) it does not track properly. Once it locks on to the target, the camera pans/tilts the target out of the field of view of the camera (the Pan and Tilt Errors increase when they should be decreasing).
Anyone else have this same problem?
"The important thing is not to stop questioning. Curiosity has its own reason for existing. One cannot help but be in awe when he contemplates the mysteries of eternity, of life, of the marvellous structure of reality." ~Albert Einstein
DHSE '06, PSU '10 (Eberly College of Science - Chemistry)
Unread 14-01-2006, 11:10
AKA: Steve
Re: CMU Cam not Tracking Properly on Robot
We found the problem! In tracking.h we redefined PAN_ROTATION_SIGN_DEFAULT and TILT_ROTATION_SIGN_DEFAULT to the opposite values. Now it is tracking perfectly!
Unread 14-01-2006, 12:10
billbo911's Avatar
billbo911 billbo911 is online now
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Yep, that'll do it.
OBTW, that situation is covered in the Tracking.h file included in the code from Kevin Watson. It is well worth the time to walk through ALL of his code. He documents it very well.
Unread 14-01-2006, 12:27
Terry Sherman's Avatar
Terry Sherman Terry Sherman is offline
Mentor -- Software
FRC #0093 (NEW Apple Corps.)
Terry Sherman is an unknown quantity at this point
Another thing to note is if you are using the 'Bells & Whistles' version of Kevin's code that this parameter is also stored in EEPROM. What this means is if you change the #defines in the code, recompile, and download you will not actually see a change in the behavior. This is because the code is loading the last used values (previous defaults) from EEPROM. You have to use Kevin's menu system to modify the value or alternatively (since you changed the default values) reset the configuration to default.
-Terry
Unread 14-01-2006, 13:19
Kevin Watson's Avatar
La Cañada High School
FRC #2429
Yep. If the software finds a valid camera and/or tracking configuration in EEPROM it will use that information for configuration. To save values from the header file into EEPROM select load default values from the menu and then hit the save changes key. You can see where the software gets the configuration data by enabling debug messages in camera.h.
-Kevin
Kevin Watson
http://kevin.org
Unread 28-01-2006, 23:21
aaronm_k aaronm_k is offline
aaronm_k is on a distinguished road
Exclamation Re: CMU Cam not Tracking Properly on Robot
Yes, if you have any tracking problems, be sure to check these settings first! Kevin's default values are wrong when used with the assembly instructions in the CMUcam workbook, and I spent 3 days changing every other setting before I finally found this post!
Unread 29-01-2006, 00:02
FRC #2429
Sorry about the documentation problems. As I suspect you'll get better tracking performance, you might consider rotating your camera 180 degrees because the best way to mount the camera is with the tilt axis extending through the camera module.
-Kevin
Kevin Watson
http://kevin.org
Honda's robot... Don Wright Math and Science 7 17-12-2005 13:15
CMU Camera Tracking auditt241 Programming 0 03-02-2005 16:33
pic: (447) Our CMU CAM BOX rufu5 Extra Discussion 2 17-01-2005 19:10
Index of team's post about their robot... Ken Leung Robot Showcase 1 20-03-2002 17:10
about how Drive Train push the robot... shouldn't the force accelerate the robot? Ken Leung Technical Discussion 12 26-11-2001 09:39
