Go to Post Welcome to CD, side effects aren't limited too, but may include, addiction to mechanical and electrical assemblies, desire to program in C, drawing objects in Solidworks and subconscious learning! - Jay H 237 [more]
Unread 28-01-2006, 11:16
Gabriel Mendez's Avatar
Gabriel Mendez Gabriel Mendez is offline
GaBrIeL MeNdez
FRC #0369
Gabriel Mendez is an unknown quantity at this point
pic: Shooter Prototype Teaser
William E. Grady Technical High School
http://www.TEAM369.com/
My Dudies:
Driver,Mechanical, and Electrical
Former Captain now Mentor
Currently Attending:
Polytechnic University
Unread 28-01-2006, 11:19
SpaceOsc's Avatar
SpaceOsc SpaceOsc is offline
16 Years of FIRST!
AKA: Oscar Vasquez
FRC #4501 (Humans)
SpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant future
Send a message via AIM to SpaceOsc Send a message via Yahoo to SpaceOsc
Re: pic: Shooter Prototype Teaser
just a thought, if u turn over the frame right side up you might not need those pillow blocks for your wheels? (Assuming its a 1/2 offset by the pillow block) It save you some weight
Last year the drive team was working on these hard to make pillow blocks and half way through i asked them if they couldnt simply turn it over?.. sometimes its so easy, that it cant be obivious
2014-2017: Team 4501 Coach/Lead Mentor
2002-2011: Team 702, Mentor
2001-2002: Team 702 Captain
Unread 28-01-2006, 11:24
spamified88's Avatar
spamified88 spamified88 is offline
AKA: Sean
FRC #1257 (Parallel Universe)
spamified88 will become famous soon enoughspamified88 will become famous soon enough
Send a message via AIM to spamified88
If you choose to use that design for a chooter, you should call your robot "The Intimidator", because who wouldn't be afraid of staring down a barrel?
Head rule guru, I know everything, or at least I'm supposed to...hehe
PARALLEL
UNIVERSE
Unread 28-01-2006, 14:00
Zoom's Avatar
Zoom Zoom is offline
Lost User
AKA: Umair Nasir
FRC #0369 (Nuts & Volts)
Zoom is an unknown quantity at this point
Send a message via MSN to Zoom
We made the axle blocks out of aluminum. So we could save a lot of weight, the blocks pin the shafts down, since the IFI wheels come with their own bearings . Our goal was to keep it as low as possible.
Good thougth though.
A Program isnt finished until the Programmer dies...
Unread 28-01-2006, 14:24
SpaceOsc's Avatar
16 Years of FIRST!
AKA: Oscar Vasquez
FRC #4501 (Humans)
Originally Posted by Zoom
We made the axel blocks out of aluminum. So we could save a lot of weight, the blocks pin the shafts down, since the IFI wheels come with their own bearings . Our goal was to keep it as low as possible.
y would any of that keep u from turning the frame over and not using the blocks?
Unread 28-01-2006, 15:40
GaBrIeL MeNdez
FRC #0369
Smile Re: pic: Shooter Prototype Teaser
We decided not to turn the frame over because the transmissions are going in between the center and rear wheels. We need a flat surface to bolt them down.
My Dudies:
Unread 29-01-2006, 02:09
Unglued Unglued is offline
AKA: Andrea Valenzuela
None #0865 (Warp7)
Team Role: Animator
Unglued is on a distinguished road
Send a message via AIM to Unglued Send a message via MSN to Unglued
since you're trying to get it as low as possible then i guess you don't intend to climb the ramp, any maybe even push other robots onto your ramp, well turning frame upside down helps in this, also you can make something like we did (not sure what it's called) to lower the frame even more. it requires some machining but nothing too difficult(just needs a drill press and bansaw)
here's a close-up pic (our clerance was less than 1/8 of an inch last year)
as for the flat surface for the gearboxes, i'm sure there are many different ways to mount them, maybe come L channel, or you cut the places you don't need(parts not supporting the wheels)
Unread 29-01-2006, 08:13
KTorak's Avatar
KTorak KTorak is offline
Fire Rescue 47
AKA: Kyle Dersch
FRC #1023 (Bedford Express)
Team Role: Driver
KTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond repute
Send a message via AIM to KTorak
How is your clearance over the ramp? From the picture, it appears that your robot would bottom up, but then you do have that 3rd wheel that looks like it would keep if from bottoming out, but then again the front of your frame might hit the ramp.
Kyle D- Myspace - Facebook
2008 Bedford Express Driver & Build & Design (Team) Co-Leader
2007 Bedford Express Driver & Build & Design (Team) Leader
2006 Bedford Express Driver, Build Team Member, & Board of Directors
2005 Bedford Express Rookie, Build Team Member & Robot Operator
2008 - GLR Quarter Finalist
2007 - GLR Finalist & Boilermaker Finalist & MARC Off Season Event Winner
2006 - GLR Johnson & Johnson Sportsmanship Award & Archimedes 7th Seed Quarter Finalist
2005 - GLR Finalist & Judges Award.
2004 - GLR Semi Finalist.
2003 - GLR/DTR Quarter Finalist & GLR/NAT'L Rookie All Star.
Unread 29-01-2006, 22:49
GaBrIeL MeNdez
FRC #0369
We lowered it as low as possible but not to low that it would keep us from going up the ramp. The front clears and the rear doesn't bottom out, the middle wheels do really help.
We are currently installing Andy Marks AM Shifter 2
Ill be posting new pic's soon.
My Dudies:
Unread 29-01-2006, 22:58
Mr.D's Avatar
Mr.D Mr.D is offline
Randy Decker
FRC #0829 (Warren Robotics "The Digital Goats")
Mr.D is just really niceMr.D is just really niceMr.D is just really niceMr.D is just really nice
How and where are the balls loaded into the barrel?
Randy Decker
Computer/Networking Technology, PLTW DE/IED,
and Electronic Systems Technician Teacher
Walker Career Center
Indianapolis, IN
www.warrenrobotics.org
2008 Boilermaker Regional J&J Gracious Professionalism Award
2008 Bloomington Vex Champion
2007 St. Louis Regional Champion
pic: 888 Ball Shooter Prototype Jeffdewber Extra Discussion 18 26-01-2006 16:51
pic: team 125 minature ball shooter prototype Brandon Holley Extra Discussion 5 14-01-2006 00:52
pic: Team 1595 Prototype!!! L@@K sgsdragons Robot Showcase 18 10-02-2005 14:27
pic: 45 teaser pic 2 Kyle Love Robot Showcase 7 02-02-2005 23:22
pic: Team 1053's very first ever teaser pic CD47-Bot Robot Showcase 3 16-02-2004 22:56
