Camera Library Problems
Ok I am having problems with camera code and I've narrowed it down to easyC. Check out this thread here. Hopefully I've made everything self explanitory in that thread. My easyC version is 2.5.0.1 if that helps. Feel free to ask any questions.
Jake |
Re: Camera Library Problems
I've tapped the serial data and found the problem. In our increment code when it reaches 100 it instead sends then 11 ...19 until 110 when it actually sends 110. The same goes for 200: 20 21 ..29 until 210. You're missing a digit when sending the serial data, whenever the tens digit is a zero. Hope this helps.
Jake |
We noticed this in testing this weekend and are working on a fix.
| Problems Combining Camera Code and Driving Code | cmurdoch | Programming | 20 | 10-02-2007 16:34 |
| Camera Servo Problems | pi_guy578 | Programming | 2 | 28-01-2006 13:17 |
| problems mounting the camera to the 'bot with the default servo/mount set up | Redneck | Programming | 0 | 16-02-2005 20:53 |
| Camera Problems | pickle | Programming | 21 | 20-01-2005 20:43 |
| Camera "Grab Frame" Problems | Isabel Cole | Programming | 7 | 15-01-2005 21:53 |
