Go to Post Also you NEVER need to apologize for asking questions. Asking questions is how you learn. - akoscielski3 [more]
Unread 29-01-2006, 01:48
roboticsguy1988's Avatar
roboticsguy1988 roboticsguy1988 is offline
Larry Johnston
AKA: Larry Boy
FRC #1501 (Team THRUST)
Team Role: Electrical
roboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud of
Send a message via ICQ to roboticsguy1988 Send a message via AIM to roboticsguy1988 Send a message via MSN to roboticsguy1988 Send a message via Yahoo to roboticsguy1988
Re: [Help] OI Modification
now would replacing the green LEDs with blue ones be against the rules. My guesss is so.
Also on average what does a blue LED draw? Basically how many Blue LEDs could you use before you reach 10ma?
Larry Johnston, Team THRUST, Team #1501, Team THRUST webpage
2005 IRI - Imagery and Design Award
2005 - 2006 BMR - Professional Grade Award
2006 BMR - Delphi Driving Tomorrow's Technology Award
"That can't be their 'bot. not nearly enough (if any) rivets to be a 1501 machine." ~ RogerR
~Da team that uses all tha rivets, Team #1501~
The FIRST Software Repository ~ Chief Admin
openFIRST ~ Project Supporter (Former editor)
DMOZ.org - FIRST - US Teams Section ~ Chief Editor
Unread 29-01-2006, 11:49
BrianBSL BrianBSL is offline
FRC #0190
BrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud of
You decide how much current to give them, based on the resistor size you use in series with it. But at 10mA, you are not going to get more than 1 LED unless you use a larger resistor and thus have the LED be less bright. Some "bright" LED's produce their rated intensity at a forward current of 20mA or more, sometimes even in the hundreds of mA for very bright LED's (although this is extremely rare).
My posts represent my personal views only, and do not represent the views of either my team, Team 190, nor its primary sponsor, Worcester Polytechnic Institute.
Unread 29-01-2006, 12:06
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Originally Posted by EricH
Having a portable computing device (laptop, PDA, etc) on the robot--the inspectors will call you on it pretty quickly, and so will the refs if the inspectors miss it.
Actually, in principle, it's not illegal. It is an additional electronic component, and subject to those rules.
Unread 29-01-2006, 12:40
MikeDubreuil's Avatar
Carpe diem
FRC #0125 (Nu-Trons)
Actually, I think you could put a very fast computer together that would fall within the rules. There's really only two limiting rules. The $200 per component limit and the $3500 budget. You could follow those rules and still add a top of the line computer to your robot.
Athlon 64 3500, $200
Mortherboard, ~$150
memory, ~ $100
HDD, ~$100
Linux, $0
You could have a very powerful computer on your robot.
Unread 29-01-2006, 20:34
I think it is important to make an explanation here for casual observers. The LED outputs are switched to the 5 volt power supply through an internal resistor. This resistor will correctly limit the output current to 10 ma when connected directly to an LED (without a resistor).
From the OI Reference Guide, p.5, "The LED drivers provide 5V that is current limited to 10mA. Connect the LED’s anode to the desired LED drive pin. Connect the LED’s cathode to any ground pins."
Unread 29-01-2006, 21:30
zachriggle zachriggle is offline
FRC #1940
zachriggle is infamous around these parts
So is the 10mA limit just on the OI, or is there a 10mA limit on LED's on the Robot itself?
Unread 29-01-2006, 21:41
Eldarion's Avatar
Eldarion Eldarion is offline
Electrical Engineer / Computer Geek
AKA: Eldarion Telcontar
no team (Teamless Orphan)
Eldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond repute
Send a message via AIM to Eldarion Send a message via Yahoo to Eldarion
It is a hardware limitation on the OI's LED output pins.
CMUCam not working? Tracks sporadically? Try this instead: http://www.falconir.com!
PM me for more information if you are interested (it's open source!).
Want the FIRST Email blasts? See here: http://www.chiefdelphi.com/forums/sh...ad.php?t=50809
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
If it's falling apart it's a mechanical problem. If it's spewing smoke it's a electrical problem.
If it's rampaging around destroying things it's a programming problem.
"All technology is run on 'Magic Smoke' contained within the device. As everyone knows, whenever the magic smoke is released, the device ceases to function."
-- Anonymous
I currently speak: English, some German, Verilog, x86 and 8051 Assembler, C, C++, VB, VB.NET, ASP, PHP, HTML, UNIX and SQL
Unread 29-01-2006, 21:55
FRC #0190
Thanks for that catch. I had read that a few days ago, but didn't think about it this morning when I posted the original reply.
Unread 30-01-2006, 00:35
Andy A. Andy A. is offline
Getting old
FRC #0095
You could deck your robot out in enough LED's to light up the arena, assuming the refs don't decide it's annoying/distracting. What that would gain you, I don't know. LED feedback on the robot would be pretty difficult to justify, since it's extra weight you already know you don't have to spare and It's difficult enough to see. Recall that the robot can be 50 feet away separated by thick plastic and surrounded by 5 other robots. Your going to have a real hard time seeing a couple of LED's on your bot.
If you really want to have some LED feed back, have one connected to your OI through one of the joystick ports. It's not to difficult to have any one of the 8 eyes on your drive team look down to see if you have that lock on. I know that Blue LED's are all the rage, but green and red are a whole heck of a lot cheaper and just as visible.
My team has kicked around the idea of putting a 'ball' on the OI. Basically its a cross of 5 LEDs. When the camera sees the target, it returns a value of how far and in which direction the light is from the center of its field of view. If it is to the left, the left most light would light up. if it is to the right and up, the top and right LED's light and so on. When it is dead on, or close enough for a good shot, the center lights up. It has the advantage of letting you know not only if you are on target or not, but how to get on target. While the RC could correct for this automagically, it's nice to put some control in the humans hand. It's an idea somewhat borrowed from the aviation world, in which the 'ball' is a grid of lights that a pilot can see at the end of the runway (or carrier deck) and informs him of where he is in relation to the glide slope.
-Andy A.
Unread 30-01-2006, 07:07
Zach,
There is no LED output as on the RC. The LED outputs on the OI are for indicators you can map and add to your operator interface. Lighting on the robot itself comes under the heading "decoration" and can be powered from the main battery. Be sure to follow the rules here though in relation to decorations, electrical and interference.
Dewalts modification suggestion Stephen Kowski Motors 1 05-07-2007 13:21
Globe motor modification Veselin Kolev Motors 11 26-01-2006 15:35
Joystick Modification Question wmurphy Control System 2 31-01-2005 00:29
Modification on the Torque motor? archiver 2001 0 23-06-2002 23:45
Caster Modification archiver 2001 1 23-06-2002 22:58
