#16
Re: [Help] OI Modification
now would replacing the green LEDs with blue ones be against the rules. My guesss is so.
Also on average what does a blue LED draw? Basically how many Blue LEDs could you use before you reach 10ma? |
#17
Athlon 64 3500, $200 Mortherboard, ~$150 memory, ~ $100 HDD, ~$100 Linux, $0 You could have a very powerful computer on your robot. |
#20
From the OI Reference Guide, p.5, "The LED drivers provide 5V that is current limited to 10mA. Connect the LED’s anode to the desired LED drive pin. Connect the LED’s cathode to any ground pins." |
#21
So is the 10mA limit just on the OI, or is there a 10mA limit on LED's on the Robot itself?
#22
If you really want to have some LED feed back, have one connected to your OI through one of the joystick ports. It's not to difficult to have any one of the 8 eyes on your drive team look down to see if you have that lock on. I know that Blue LED's are all the rage, but green and red are a whole heck of a lot cheaper and just as visible. My team has kicked around the idea of putting a 'ball' on the OI. Basically its a cross of 5 LEDs. When the camera sees the target, it returns a value of how far and in which direction the light is from the center of its field of view. If it is to the left, the left most light would light up. if it is to the right and up, the top and right LED's light and so on. When it is dead on, or close enough for a good shot, the center lights up. It has the advantage of letting you know not only if you are on target or not, but how to get on target. While the RC could correct for this automagically, it's nice to put some control in the humans hand. It's an idea somewhat borrowed from the aviation world, in which the 'ball' is a grid of lights that a pilot can see at the end of the runway (or carrier deck) and informs him of where he is in relation to the glide slope. -Andy A. |
#25
There is no LED output as on the RC. The LED outputs on the OI are for indicators you can map and add to your operator interface. Lighting on the robot itself comes under the heading "decoration" and can be powered from the main battery. Be sure to follow the rules here though in relation to decorations, electrical and interference. |
| Dewalts modification suggestion | Stephen Kowski | Motors | 1 | 05-07-2007 13:21 |
| Globe motor modification | Veselin Kolev | Motors | 11 | 26-01-2006 15:35 |
| Joystick Modification Question | wmurphy | Control System | 2 | 31-01-2005 00:29 |
| Modification on the Torque motor? | archiver | 2001 | 0 | 23-06-2002 23:45 |
| Caster Modification | archiver | 2001 | 1 | 23-06-2002 22:58 |
