Go to Post "You are the lead programmer now, therefore everything that goes wrong is your fault. When anything good happens its the teams fault." "But what if the robot spontaneously combusts?" "Your Fault." ~Borna - CodeTBone [more]
View Poll Results: Drives Platform
2 Wheels 2 1.10%
4WD 47 25.82%
4 wheels, 2 driven 12 6.59%
6WD 73 40.11%
8WD 5 2.75%
10WD+ 5 2.75%
Tank tracks 15 8.24%
Kiwi Drive 4 2.20%
Omni Directional 4 2.20%
Crab Drive 5 2.75%
Swerve Drive 1 0.55%
Wheels? Who needs wheels? 9 4.95%
Voters: 182. You may not vote on this poll
  #31   Spotlight this post!
Unread 29-01-2006, 14:05
Pavan Dave's Avatar
Pavan Dave Pavan Dave is offline
Busy in College
AKA: I am John Gault.
FRC #1745 (P-51 Mustangs) FRC #118 (Robonauts)
Pavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond repute
Send a message via AIM to Pavan Dave
Re: The Annual Drives Platform Poll
We are using the Crab Drive meathod on our robot. Also I was wondering the efficiency of the Kiwi Drive system. See the video I believe it would be easy to trap or "Pin" this robot on the sides not even needing a corner. Could someone that is using it explain maybe?
-Pavan
Times change. People change. Teams change.
2008-Present: FRC1745, P51-Mustangs - Mentor
2005-2008: FRC118, Robonauts - Alumni
National Director of Philanthropy - Delta Epsilon Psi Fraternity, Inc.
1745 - 118 - ΔΕΨ
  #32   Spotlight this post!
Unread 29-01-2006, 14:12
ida_noeman's Avatar
ida_noeman ida_noeman is offline
AKA: phobbs
FRC #1719 (Umbrella Corp.)
ida_noeman is on a distinguished road
-Pavan
According to 4.3.4.4 <G24>, you can only pin another robot for 10 seconds before you have to back up 3 feet (then try again). Perhaps it's not that much of a disadvantage to be weak against pinning.
"Weeks of coding can save you hours of planning"
"If the code was hard to write, I'm dam well going to make it hard to read!"
  #33   Spotlight this post!
Unread 29-01-2006, 14:25
Andrew Blair's Avatar
FRC #0306 (CRT)
The idea of a holonomic drive is that, on a flat field, you don't need to worry too much about being pinned because with a good driver, the bot is so fast and maneuverable that you can't get it.
-Sir Francis Bacon
-Albert Einstein
  #34   Spotlight this post!
Unread 29-01-2006, 14:56
Gdeaver Gdeaver is offline
FRC #1640
I hope that all teams that are going up the ramp have looked at the dynamic of their drive choice and the CG issues. Teams that don't could be great tippers.
  #35   Spotlight this post!
Unread 29-01-2006, 15:44
Gene F's Avatar
Gene F Gene F is offline
FIRST Fanatic
AKA: Gene Falendysz
#0343 (Metal in Motion)
Gene F is a splendid one to beholdGene F is a splendid one to beholdGene F is a splendid one to beholdGene F is a splendid one to beholdGene F is a splendid one to beholdGene F is a splendid one to beholdGene F is a splendid one to beholdGene F is a splendid one to behold
Send a message via AIM to Gene F
Metal in Motion, team 343 will be on tracks again this year for the forth year in a row. We're getting quite comfortable with them. We talked about a 6 wheel base but felt there wasn't enough of an advantage to change from what we are familiar with. Look for the 6 wheel base next year!
- Gene Falendysz
  #36   Spotlight this post!
Unread 03-02-2006, 08:25
Alex Cormier's Avatar
Alex Cormier Alex Cormier is offline
www.TwoPencilDesigns.com
AKA: Grizz, Twinkletoes, PitBull1126
FRC #1405
Alex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond repute
interesting. slowly 4WD is creeping up to 6WD, who will have the most be the end of build season??
Two Pencil Designs - Vinyl Graphics, Bumper Numbers, and Strategy Items!
Like us on Facebook & follow us on Twitter
Facebook.com/TwoPencilDesigns & TwoPencilDesign
  #37   Spotlight this post!
Unread 03-02-2006, 08:57
bobotics319 bobotics319 is offline
AKA: Andrew Levasseur
FRC #0319 (Bobotics)
Team Role: Communications
bobotics319 is an unknown quantity at this point
are team is using a 6wd system and its all up and driving
  #38   Spotlight this post!
Unread 03-02-2006, 10:01
kaszeta's Avatar
kaszeta kaszeta is offline
FRC #0095 (Grasshoppers)
kaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of light
Bot drive
Seeing that it's more than halfway through build season, I figure we can be a little more open with details now:
Our team's testing with our drive system has been very positive, so I think we're definitely going to use it on the final bot:
1. Four omni-wheels driven by 2 large CIMs and 2 small CIMs
2. Four IFI traction wheels on the corners (driven along with the omnis by the small CIMs).
So, we've got 8 powered wheels (with a max of 6 making contact), with holonomic ability.
This gives us holonomic drive (so we can align the whole bot with the target independent of translation) with ramp climbing capabilities. I'll try and post images when we get them.
  #39   Spotlight this post!
Unread 03-02-2006, 10:34
aaeamdar's Avatar
aaeamdar aaeamdar is offline
Post-A-Holic
AKA: Paul Dennis
FRC #1719 (The Umbrella Corp)
aaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant future
A very nice poll. Is there any way in the future to have it split into what newbies are going after and what veterans are going after? Like each bar would be split into two sections, showing rookies and veteran votes. It would be interesting to see if any rookies went for crab steering or kiwi for example.
And how does that thing go /forward/? I'm looking at the video, I'm just asking rhetorically.
Paul Dennis
  #40   Spotlight this post!
Unread 03-02-2006, 10:44
Tim Delles's Avatar
Tim Delles Tim Delles is offline
Since 2001.
FRC #0078
Tim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond repute
We (1719) are going with 4WD, that's because we're a rookie team and keepin' it simple.
That is always a good thing to do.
Timothy Delles - Clarkson University
2011 - Present: FRC Team 78 - AIR Strike
2011 - Present: VEX Team 78 - AIR Strike
2010 - 2011: FRC Team 3280 - Rhode Rebels
2001 - 2009: FRC Team 229 - Division By Zero
4th Annual Tournament of Rosie Rosiebotboss General Forum 1 31-05-2005 11:12
Time for the annual <fill in the blank> thread Gary Dillard General Forum 6 07-01-2005 22:55
**FIRST EMAIL**/FIRST Annual Fund Message from James R. Utaski, FIRST Board of Direct miketwalker FIRST E-Mail Blast Archive 0 27-05-2004 11:25
**FIRST EMAIL**/First Annual FIRST Robotics Conference, April 16 April 18, 2004 for t miketwalker FIRST E-Mail Blast Archive 6 04-04-2004 18:31
idea: a semi-official coaches poll archiver 1999 8 23-06-2002 22:23
