Go to Post Could you explain this concept of a break from FIRST? Did my wife put you up to this? - Gary Dillard [more]
Unread 28-01-2006, 13:17
magical hands magical hands is offline
Jigar Patel
AKA: Jigar Patel
FRC #2185 (Etobicoke CI)
magical hands is on a distinguished road
Exclamation CAMERA DOESN"T RESPOND!!!!!!
I followed all the instructions and built my cam according to the mount assembly instructions.
1) Then i take servo pan and hook it upto pwm 01
2) Then i take servon tilt and hook it up to pwm02
3) than i power the camera throught pwm03
4) I load the camera code into the robot
5) Turn the green lights on
As a result I get no results all i see is my camera moved and its facing the ceiling. I thought the camera is suppose to scan for colour green but it doesn't do anything? Can anyone help me troubleshoot the problem and get the camera to work! Please and Thank You
E-mail: jigarjuhi@yahoo.ca
Unread 28-01-2006, 13:40
Kevin Watson's Avatar
La Cañada High School
FRC #2429
Re: CAMERA DOESN"T RESPOND!!!!!!
Is the operator interface tethered to the robot controller with the red cable? If so, are all of the LEDs on the RC and OI green? If they are, double check that you've got the serial port connected correctly and then run the serial port diagnostics mentioned in Q13 and Q14 of the CMUcam2 FAQ: http://kevin.org/frc/camera.
-Kevin
Kevin Watson
http://kevin.org
Unread 28-01-2006, 20:17
Jigar Patel
AKA: Jigar Patel
-Kevin
I did all that and i even ran the diagnostics but it said something like searching or diagnosing... something like that and I waited for 5 minutes and still no results came up so i thought that everything is fine! Also when i tried to use last year's GUI it didn't work like it said camera ready but all i see is black! no histograms nothing. i even tried to move servos using GUI but they didn't move!
Unread 28-01-2006, 20:45
If your camera initializes pointing up instead of forward, maybe the servo wasn't centered when it was mounted to the tilt assembly.
If you only see black, maybe the lens cover is still on the camera.
Unread 29-01-2006, 13:52
Jigar Patel
AKA: Jigar Patel
We did remove the lens cover. Are their chances that our camera is broken or something internal problems? If so what can we do about it meaning can we get a new one? From where?
Unread 29-01-2006, 14:20
Safarley2901's Avatar
Safarley2901 Safarley2901 is offline
AKA: Steve Farley
FRC #0808 (Mechanical Mayhem)
Safarley2901 has a spectacular aura aboutSafarley2901 has a spectacular aura aboutSafarley2901 has a spectacular aura about
Is it Focussed right?
2005 Pittsburg Regional Finalists
2005 Cleveland Regional Semi finalists
Unread 29-01-2006, 14:45
Eldarion's Avatar
Eldarion Eldarion is offline
Electrical Engineer / Computer Geek
AKA: Eldarion Telcontar
no team (Teamless Orphan)
Eldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond repute
Send a message via AIM to Eldarion Send a message via Yahoo to Eldarion
Just clarifying: After it said "Camera Ready" you clicked "Grab Frame", right?
Also, if you were trying to move the servos from inside the GUI, you must have the servos plugged into servo ports 1 and 2 on the CMUCam board.
CMUCam not working? Tracks sporadically? Try this instead: http://www.falconir.com!
PM me for more information if you are interested (it's open source!).
Want the FIRST Email blasts? See here: http://www.chiefdelphi.com/forums/sh...ad.php?t=50809
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
If it's falling apart it's a mechanical problem. If it's spewing smoke it's a electrical problem.
If it's rampaging around destroying things it's a programming problem.
"All technology is run on 'Magic Smoke' contained within the device. As everyone knows, whenever the magic smoke is released, the device ceases to function."
-- Anonymous
I currently speak: English, some German, Verilog, x86 and 8051 Assembler, C, C++, VB, VB.NET, ASP, PHP, HTML, UNIX and SQL
Unread 29-01-2006, 15:37
Jigar Patel
AKA: Jigar Patel
Oh no wonder my servos didn't move thanks! however ya my camera was focused it said camera ready. however when i see the GUI window everything is black also I wasn't able to grab frames or do anything? In other words i wasn't able to use GUI although GUI was able to recognize the camera it didn't help me! Should i assume that the camera is broke or their is the problem in GUI?
CMU Camera kills robot controller if not found. Chris_Elston Programming 21 27-03-2006 14:30
How To Use the Google Camera generalbrando Kit & Additional Hardware 2 07-02-2006 16:00
Camera Is Spazzing Out! BrittanyV Programming 15 04-02-2006 13:39
Scripting Setup and the Camera + Serial Port Drivers CJO Programming 22 11-01-2006 17:42
CMUCam2 Camera Code - Are important parts commented out? Mr. Lim Programming 4 14-01-2005 12:11
