Go to Post Are you confused yet? - Andy Grady [more]
Unread 29-01-2006, 15:21
devicenull devicenull is offline
Robot? We need a robot?
Rookie Year: 1234
devicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nice
Can't get EDU RC to print things.
I'm using the edu_serial_ports code, and none of my printf's will actually display anything.
Using the default code for it, which mirrors what you type into the terminal window, I do see output.. but that use's Write_Serial_Port_One(), not printf.
Any suggestions?
I've tried changing it to the second serial port, but that is apparently the TTL port.
Unread 29-01-2006, 15:43
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Re: Can't get EDU RC to print things.
Any suggestions?
Can you send me your code?
-Kevin
Kevin Watson
http://kevin.org
Unread 29-01-2006, 16:42
FRC #2429
Any suggestions?
Remove printf_lib.c/.h from your project and try it again (I also sent you a PM).
-Kevin
Kevin Watson
http://kevin.org
Are things quieter than usual this year? Madison General Forum 23 26-01-2005 13:59
[FVG]: Some things nobody seems to know about Astronouth7303 FIRST-related Organizations 2 01-01-2005 21:03
Simple things you can do to make your bot/team perform better KenWittlief General Forum 21 01-04-2004 15:11
A hint of things to come... archiver 2001 0 24-06-2002 01:12
