Go to Post If you need persuasion woven tight with logic, leave it to a software architect. - Richard Wallace [more]
Unread 29-01-2006, 15:38
Zoom's Avatar
Zoom Zoom is offline
Lost User
AKA: Umair Nasir
FRC #0369 (Nuts & Volts)
Zoom is an unknown quantity at this point
Send a message via MSN to Zoom
Pwm and pot
i want to know if there is a way in which i can make the servos move (which are hooked in to pwm) when i trun the pot. i get the value for the pot. now i need to get the value for the servo and some how make it move when the value of the pot changes. is there a way?
A Program isnt finished until the Programmer dies...
Unread 29-01-2006, 15:44
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Re: Pwm and pot
All you have to do is directly map the pot values to the PWM the servo is on:
pwm01 = rc_ana_in01;
Change the ports to what you are actually using.
If you need more complicated control... make it more complicated yourself.
--EDIT--
See below message.
Unread 29-01-2006, 15:49
steven114 steven114 is offline
Programming Wizard and Team Captain
AKA: Steven Schlansker
FRC #0114 (Eaglestrike)
steven114 is a jewel in the roughsteven114 is a jewel in the roughsteven114 is a jewel in the rough
Send a message via AIM to steven114
Re: Pwm and pot
Actually, you'd have to do something more like:
pwm01 = Get_Analog_Value(rc_ana_in01) >> 2;
The controller doesn't sample the analog inputs until you call Get_Analog_Value, and the shift is to convert the 10-bit analog input to the 8-bit PWM output.
Shift to the left, shift to the right!
Pop up, push down, byte, byte, byte!
Unread 29-01-2006, 16:04
Biff Biff is offline
AKA: Tom Cooper
#1227 (Techno Gremlins)
Biff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the rough
Re: Pwm and pot
Both the above should work, The first is if the pot is connected to the OI (operator control) the second is if the pot is on the robot. Just fill in the correct context and you are good to go.
Unread 29-01-2006, 16:13
Zoom's Avatar
Lost User
AKA: Umair Nasir
Re: Pwm and pot
thankx alot.
Unread 29-01-2006, 18:33
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Re: Pwm and pot
Danny Diaz over in the National Instruments forum wrote a LabVIEW app that allows you to move motors around in realtime. You might want to check it out.
-Kevin
Kevin Watson
http://kevin.org
Unread 29-01-2006, 18:47
Programming User
Re: Pwm and pot
Yep... my mistake.
reading hobby PWM sciguy125 Programming 2 17-10-2005 20:47
R/C Control types Andy Brockway Programming 43 24-11-2003 17:07
How do you set a speed limit on the servo Fares Programming 6 01-01-2003 15:04
Pwm VanWEric Programming 17 01-11-2002 16:07
More pBasic Woes... Dan 550 Programming 4 11-11-2001 23:08
