Go to Post As guests in the city, we should make an effort to do some fundraising for the folks affected by the storm. Any ideas out there? - Jon236 [more]
Unread 29-01-2006, 15:50
Ami Schwartz Ami Schwartz is offline
FRC #1657
Ami Schwartz is an unknown quantity at this point
Q. abuot autonomous Mode
Hi, this is ami again from team #1657.
This time i'v got a Q. about the autonomous mode : after each game can i change my autonomous program ?
I mean that after game "A" i can pull it out and change it to a different program that will suit the next game ("B").
Thx alot "Hamosad team"
Unread 29-01-2006, 16:08
Andrew Blair's Avatar
FRC #0306 (CRT)
Re: Q. abuot autonomous Mode
Yes. In fact, it's recommended to have multiple autonomous possibilities in order to compete more effectively. Theres plenty of space on the controller this year; just have a switch control which mode is run. There plenty of resouces on these forums for this. Good luck!
-Sir Francis Bacon
-Albert Einstein
Unread 29-01-2006, 16:34
Cuog's Avatar
Cuog Cuog is offline
Registered Linux User: 390661
AKA: Alex
FRC #0422
basically use a switch(variable) block for what code u want to execute based on the digital inputs on your robot, like if switch1 is fliped incrment a vairable and for each switch flipped up it increments the value and in the switch have a case for each variable to execute each code.
KK4KQO
http://voltair.us
a simple autonomous mode question chippermonky Programming 3 18-02-2005 01:54
A little question about the autonomous mode Anton Programming 4 18-01-2005 14:08
autonomous mode problem on field Chris_C Programming 17 26-03-2003 19:11
