Go to Post Remember, however, that such software limitations in no way approximate the functionality of a multiple-speed, mechanical transmission. They're simply a convenient way of limiting your students' lead feet. - Madison [more]
Unread 29-01-2006, 17:33
bush's Avatar
bush bush is offline
AKA: Aaron
FRC #0710 (Pine Crest School)
bush has a spectacular aura aboutbush has a spectacular aura about
Send a message via AIM to bush
Servo Offset -> Angle conversion
I have estimated the conversion at
Angle = Offset / 2
Does anybody have a more optimal conversion equation?
Unread 29-01-2006, 18:24
6600gt's Avatar
6600gt 6600gt is offline
AKA: Lohit
FRC #0226 (Hammerhead)
6600gt is a jewel in the rough6600gt is a jewel in the rough6600gt is a jewel in the rough
Re: Servo Offset -> Angle conversion
Angle = Offset / 2
((PAN_SERVO - 124) * 65)/124
((TILT_SERVO - 144) * 25)/50
In Kevin's camera code check out terminal.c
Its the 65/124 degrees change for every pan incriment and 1/2 for every tilt incriment that you need.
Unread 29-01-2006, 19:06
bush's Avatar
AKA: Aaron
That of course assumes that your CENTER pwm values are at 124 and 144 (not hard to change). But then my next question would be, why would the degree change be different for 2 identical servos?
Unread 29-01-2006, 19:11
Eldarion's Avatar
Eldarion Eldarion is offline
Electrical Engineer / Computer Geek
AKA: Eldarion Telcontar
no team (Teamless Orphan)
Eldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond repute
Send a message via AIM to Eldarion Send a message via Yahoo to Eldarion
My guess is it has something to do with the camera sensor--it isn't a perfect square, but is rectangular with the "pan" side being longer than the "tilt" side.
Without having looked at that piece of code, I don't really know for sure.
CMUCam not working? Tracks sporadically? Try this instead: http://www.falconir.com!
PM me for more information if you are interested (it's open source!).
Want the FIRST Email blasts? See here: http://www.chiefdelphi.com/forums/sh...ad.php?t=50809
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
If it's falling apart it's a mechanical problem. If it's spewing smoke it's a electrical problem.
If it's rampaging around destroying things it's a programming problem.
"All technology is run on 'Magic Smoke' contained within the device. As everyone knows, whenever the magic smoke is released, the device ceases to function."
-- Anonymous
I currently speak: English, some German, Verilog, x86 and 8051 Assembler, C, C++, VB, VB.NET, ASP, PHP, HTML, UNIX and SQL
Unread 29-01-2006, 20:01
6600gt's Avatar
AKA: Lohit
Yeah probably because the camera is centered around the pan axis but not the tilt axis.
Unread 29-01-2006, 20:36
Andrew Blair's Avatar
FRC #0306 (CRT)
Perhaps with the linkage in the KOP bracket the pan is longer or shorter.
-Sir Francis Bacon
-Albert Einstein
Unread 29-01-2006, 20:43
PEKMAN's Avatar
PEKMAN PEKMAN is offline
Alum
AKA: Peter Krasucki
FRC #0293 (Spike)
PEKMAN is on a distinguished road
With the help of the LabView software I have found that 45 degrees is right around 50 servo "ticks".
"Life is just a sexually transmitted disease." - R. D. Laing
"I find television very educating. Every time somebody turns on the set, I go into the other room and read a book." - Groucho Marx
Unread 29-01-2006, 21:51
Eldarion's Avatar
Uh-oh...
So I did something bad by unscrewing the servo horn and re-centering the tilt axis to be exactly vertical at 127?
I wonder how many other teams did that as well...
-- Thomas Paine
-- Anonymous
Unread 29-01-2006, 22:04
devicenull devicenull is offline
Robot? We need a robot?
Rookie Year: 1234
devicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nice
Uh-oh...
Our's is deliberately off center.. we can tilt more upward then downward. Although if the target is ever below our robot, we won't be able to see it (but at that point, we have more problems then that)
bush's Avatar
AKA: Aaron
Uh-oh...
I did that too, but that is not what 6600 gt was referring to. It simply meant that the pan servo lies on the vertical axis of the camera lens, while the tilt servo is not in line with the horizontal axis.
Unread 30-01-2006, 08:55
DanDon's Avatar
DanDon DanDon is offline
ohhh MY god
AKA: Dan Hoizner
FRC #0375 (The Robotic Plague)
DanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond repute
Send a message via ICQ to DanDon Send a message via AIM to DanDon Send a message via MSN to DanDon
Hi all,
If you still need help converting, there's a great thread about it here
Hope this helps,
Unread 30-01-2006, 13:34
Eldarion's Avatar
Just one more quick reply here.
On my camera, at least, the camera lens is exactly in line with the pan and tilt servos. Did anyone mount the camera board upside-down, or is the offset just too slight to easily notice?
-- Thomas Paine
-- Anonymous
Servo behavior question / advanced servo/PIC programming question DanL Electrical 12 18-10-2005 18:33
Servo command confusion?!?!?!?! [527]phil Programming 9 15-07-2005 20:10
Servo Compact Design Problems!!! Dominator_Legen Electrical 22 07-04-2005 18:15
Servo Help Dominator_Legen Motors 3 11-03-2005 19:50
FIRST-SME membership archiver 2001 5 24-06-2002 00:41
