Go to Post I love the smell of burnt motors in the morning! - Mike Betts [more]
Unread 29-01-2006, 18:32
d.courtney's Avatar
d.courtney d.courtney is offline
AKA: David
FRC #0781 (Kinetic Knights)
d.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud ofd.courtney has much to be proud of
Blob Size
I was wondering if it would be possible to know how far away the goal is by the blob size alone...is this possible? You'd think it would be as long as you know the actual size of the object you are tracking.
Unread 29-01-2006, 18:45
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Re: Blob Size
The main difficulty with that is that the blob will appear smaller if you are looking at it from an angle...
Unread 29-01-2006, 18:51
Kevin Watson's Avatar
La Cañada High School
FRC #2429
Re: Blob Size
Yes, maybe. Keep in mind that the number of pixels will change as you keep a fixed distance from the green light, but rotate around it. Hmmm... Given that you kinda know how far away you are from the green light using the tilt angle, I wonder if you could then use the blob size to determine the angle.
Anyway, a better way might be to determine the height of the blob using y1 and y2 because the height won't vary much.
-Kevin
Kevin Watson
http://kevin.org
Unread 29-01-2006, 18:55
Eldarion's Avatar
Eldarion Eldarion is offline
Electrical Engineer / Computer Geek
AKA: Eldarion Telcontar
no team (Teamless Orphan)
Eldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond repute
Send a message via AIM to Eldarion Send a message via Yahoo to Eldarion
Re: Blob Size
The other thing to remember is that the camera sensor is inherently noisy, and as such the blob size will randomly change by a small amount from frame to frame. You can also see the effects of the noise in that the centroid will "dance" by a few pixels even when everything is stationary, however the blob size is much more unstable. I learned this the hard way last year...
CMUCam not working? Tracks sporadically? Try this instead: http://www.falconir.com!
PM me for more information if you are interested (it's open source!).
Want the FIRST Email blasts? See here: http://www.chiefdelphi.com/forums/sh...ad.php?t=50809
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
If it's falling apart it's a mechanical problem. If it's spewing smoke it's a electrical problem.
If it's rampaging around destroying things it's a programming problem.
"All technology is run on 'Magic Smoke' contained within the device. As everyone knows, whenever the magic smoke is released, the device ceases to function."
-- Anonymous
I currently speak: English, some German, Verilog, x86 and 8051 Assembler, C, C++, VB, VB.NET, ASP, PHP, HTML, UNIX and SQL
Unread 29-01-2006, 19:21
coldabert's Avatar
coldabert coldabert is offline
The Dude
FRC #0888 (Robotiators)
coldabert is a glorious beacon of lightcoldabert is a glorious beacon of lightcoldabert is a glorious beacon of lightcoldabert is a glorious beacon of lightcoldabert is a glorious beacon of light
Send a message via AIM to coldabert
Re: Blob Size
If you need a distance estimation I would recommend using the tilt values of the servos and the y coordinates of the blob. Confidence also decreases at large distances.
Unread 29-01-2006, 20:02
d.courtney's Avatar
AKA: David
Re: Blob Size
well I was just wondering because the team wants to fix the camera to our shooter, so it would be driven by a motor and two things would be changed at once... I was also thinking of keeping track with a sensor, and doing some conversion of teeth to angle... just exploring all the options, and this one just poped up, but it seems it is too unstable so any more ideas, or would the sensor be the best bet? Thanks
Unread 29-01-2006, 20:32
Andrew Blair's Avatar
FRC #0306 (CRT)
Re: Blob Size
Heres what I would suggest. If you have to, you can still use the fixed mount to determine distance. I believe that there is a way to "shift" where the camera's center is (Maybe its shifting the centroid of the blob). In other words, you can have the camera pointing slightly offset of the target, yet still have it return center values.
So, have a routine that slaves the turret to the camera, until it finds the target. Upon finding the target, use the values to determine distance. Then, move the camera center values accordingly in order to correctly angle your shooter, if necessary. After that, unless it loses the target, you can subtract the current offset of the camera to determine current distance, and accordingly re-adjust the camera center to place your shooter "on zero".
I'm sure there is a more elegant solution, but perhaps this can be a place to start.
EDIT----------------------------------------
Post number 600!
-Sir Francis Bacon
-Albert Einstein
Unread 29-01-2006, 20:48
d.courtney's Avatar
AKA: David
Re: Blob Size
well that is another way I didn't think of, thanks for the idea.
Size Of control box rcubes85 Control System 8 18-02-2005 10:22
Robot Controller File Size Limit ?? RoboGeek Programming 1 17-01-2005 19:59
What size is it? sburro Motors 3 19-11-2004 19:38
What size monitor do you use? Elgin Clock IT / Communications 30 10-03-2004 16:53
Is there a size regulation for the pit area if we wanted to put up a banner Ragin_Kage General Forum 6 14-03-2002 15:33
