Go to Post "Fair and professional" needs to be two-directional. - John Neun [more]
Unread 28-01-2006, 18:28
Andrew Blair's Avatar
FRC #0306 (CRT)
Re: Mounting / Connecting The Fisher Price Motor
Originally Posted by Nitroxextreme
Are their any lighter ways to make these FP gearboxes usable?
My team is trying to use them, but without being able to make the output shaft able to hold sprocket, they will be "useless".
This really is an easy (with access to a lathe), light way to do it. The entire aluminum slug with bolts weighs maybe a few ounces, and the necessary shaft support can be as light as you want to make it.
-Sir Francis Bacon
-Albert Einstein
Unread 28-01-2006, 18:31
How about a proven method to take power off from the next-to-the last gear? IIRC, this stage is about 450 RPM.
Unread 29-01-2006, 19:37
Nitroxextreme's Avatar
Nitroxextreme Nitroxextreme is offline
Relation to Mrs. Steve
AKA: Jon
FRC #1626 (Falcon Robotics ; 190 (Gompei and The Herd))
Nitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to behold
Send a message via AIM to Nitroxextreme
Are you talking about making a metal "slug" to fit in the octahedral shaped plastic piece?
I'm still a bit confused how this would work? Would the slug have a shaft on it like the whole thing milled/lathed out of one aluminum rod?
"He needed a chuck norris lesson in FIRST"...."I will give him a round house kick to the face...with gracious professionalism"
Unread 29-01-2006, 20:09
Manoel's Avatar
Manoel Manoel is offline
FRC #0383 (Brazilian Machine)
Manoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond repute
Send a message via ICQ to Manoel Send a message via MSN to Manoel
We did that last year, cutting the gearbox to eliminate the last stage. I don't remember exactly how we did it, tomorrow I'll take a good look at the robot and post the results here.
Manoel Flores da Cunha
Brazilian Machine
Team # 383
Unread 29-01-2006, 20:20
FRC #0306 (CRT)
Well, really whatever you want. Heres how it breaks down:
On the white output of the fisher-price, there is an octagonal hole formed by tabs. It appears to be round at first glance. So, by maching a round slug that fits in this octagonal hole closely, you have now effectively "Plugged the hole". Between the slots of the FP output, you drive bolts through, into holes tapped on the Aluminum slug. So, the slug can then have whatever you want on it. Want to drive a 1/2" shaft with it? Machine and broach a 1/2" hole into the Al slug! All it is is really plugging the output hole with something that is easy to interface.
-Sir Francis Bacon
-Albert Einstein
Unread 31-01-2006, 19:52
AKA: Jon
I was talking with one of our mentors about connecting to the FP gearbox output "shaft"
And the first thing that he said was that a 1in or 1 1/2 in nut would fit in there
We haven't been able to get a nut that big yet, but I believe that this may also be able to solve our problem
Unread 31-01-2006, 20:16
FRC #0306 (CRT)
Very interesting solution. But arn't most nuts hexagons, and not octagons?
-Sir Francis Bacon
-Albert Einstein
Cheap Torque Measurement? ChuckDickerson Motors 15 13-06-2005 13:57
Use of the fisher price motor ALONE Some Guy Motors 6 03-02-2005 08:55
Fisher Price Motor Into Drill Gearbox Chris Technical Discussion 11 21-04-2004 09:09
Locking the Fisher Price Motor xxlshortys Motors 10 24-02-2004 21:24
New Fisher Price Motor - IMPORTANT Paul Copioli Motors 6 08-02-2002 13:35
