Go to Post ALL technology is run on 'Magic Smoke' contained within the device. As everyone knows, whenever the magic smoke is released, the device ceases to function. - kmcclary [more]
View Poll Results: Basic running platform weight
under 20 lbs. 1 2.04%
21 - 30 lbs. 5 10.20%
31 - 39 lbs. 15 30.61%
40 - 49 lbs. 12 24.49%
over 50 lbs. 16 32.65%
Voters: 49. You may not vote on this poll
Unread 29-01-2006, 12:21
Andrew Schuetze's Avatar
Andrew Schuetze Andrew Schuetze is offline
499 Founder / Alamo FTC & FLL AP
Andrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond repute
Post Drive-train / chassis weight
The FIRST triple threat constraints - TIME - $$$ - WEIGHT
I am curious to learn how teams basic running platform is doing in regards weight
Our modified kitbot chassis and Omni-wheel wheel design came in at 50 lbs yesterday That is about 10 lbs more than I had expected but maybe it is okay. We are using the basic kit frame, four CIM motors, four kop transmissions, four AM plastic omniwheels.
So, post your sub-system weight and description if you like for comparison.
APS
Founder FRC 499
Parent alumni FRC 2745 & 4219
Co-Coach FTC 4549 & 6407
Alamo FTC Affiliate Partner
Alamo FLL Affiliate Partner
Unread 29-01-2006, 12:58
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Drive-train / chassis weight
Right now we have 4 small CIMs, two small clyinders, two custom shifting gearboxes, 6 wheels, 8 pillow blocks, and a base frame at 23 lbs (or so Inventor says). That does not include wheel axles, bearings, sprockets, or chains. So I'm guessing maybe 35lbs.
Unread 29-01-2006, 13:00
Ken358 Ken358 is offline
Ken358 has a spectacular aura aboutKen358 has a spectacular aura aboutKen358 has a spectacular aura about
Ours is about 40 lbs. with motors, but no electronics.
How does your robot drive with the 4 omni wheels? We have been experimenting with 2, we have never tried 4 for fear of being pushed sideways.
I am intrested to see how it works.
Ken
Unread 29-01-2006, 13:26
Ken
We lack getting chain around the last wheel set so it doesn't drive as of yet
We have them mounted in the corners at an angle such that the wheels are aligned along the diagonal.
We have conceeded losing in a pushing match but hope that the system is more manuverable and can drive our way around such situations. We felt that being able to turn on a dime and swerve while chasing balls was more important that holding postion in this years game. It is a worry though when one is lined up for a shot and gets a push. If weight was not a concern then we could deploy some pnuematic actuated locking feet...
I'll post a link to some video of it driving once it is complete.
APS
Founder FRC 499
Unread 29-01-2006, 13:30
Hutch Hutch is offline
NOTAG
Hutch will become famous soon enoughHutch will become famous soon enough
Four KOPS gearboxes? I'd think an easy way to drop weight would be to use two and use chain to drive the wheels... But then again I don't know how much a KOP gearbox weighs.
Unread 29-01-2006, 13:45
Andrew Blair's Avatar
FRC #0306 (CRT)
I think like 50 lbs or so, with kitbot frame, 4 cims, KOP gearboxes, and a beefier six wheel drive. And we only use #25 chain!
-Sir Francis Bacon
-Albert Einstein
Unread 29-01-2006, 14:49
David Hoff's Avatar
David Hoff David Hoff is offline
FRC #4050 (Biohazard)
David Hoff is a name known to allDavid Hoff is a name known to allDavid Hoff is a name known to allDavid Hoff is a name known to allDavid Hoff is a name known to allDavid Hoff is a name known to all
Cyber Blue is right around 50 pounds for our drive with 4 CIMs, 2 gearboxes, modified kit frame, treads, and everything needed to make the treads roll. It's heavy but it's pretty much what we expected.
Cyber Blue Team 234: Indianapolis, IN 2002-2006
Purdue FIRST Programs: West Lafayette, IN 2006 - 2010
Cyber Titans Team 3793: Frederick, MD 2012
Biohazard Team 4050: Chambersburg, PA 2014
Unread 29-01-2006, 15:11
phrontist's Avatar
phrontist phrontist is offline
Proto-Engineer
AKA: Bjorn Westergard
FRC #1418 (Vae Victus)
phrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond repute
Send a message via AIM to phrontist
We have two frames, one atop the other. The bottem subassembly weighs 11 pounds sans motors and pre-drilling. The top assembly weighs about 20 pounds right now. That's with electronics, motors, and other active element weight subtracted.
University of Kentucky - Radio Free Lexington
"I would rather have a really big success or a really spectacular crash and failure then live out the warm eventual death of mediocrity" - Dean Kamen
Unread 29-01-2006, 16:58
Mike Norton's Avatar
Mike Norton Mike Norton is offline
FRC #0061
Rookie Year: 1995
Mike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to all
our running robot base comes in at 60 lbs. that includes everything even the air tanks to shift on the fly. This robot can take a hit. CG of this robot is around 3/4" off the ground. we use 35 chain which weighs more but worth it in many ways.
Building FIRST robots since 1995
BVT Robotics
Unread 29-01-2006, 17:13
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
Our complete drivetrain weighs about 45 pounds. It is six wheel drive and we use 35 chain.
Unread 29-01-2006, 22:05
I added a poll for grins
Add to the poll in addition to posting your chassis description and motor/transmission counts
APS
Founder FRC 499
Unread 29-01-2006, 22:43
Joe J.'s Avatar
Joe J. Joe J. is offline
My Gaming Is FIRST!
AKA: Joey
Joe J. has a reputation beyond reputeJoe J. has a reputation beyond reputeJoe J. has a reputation beyond reputeJoe J. has a reputation beyond reputeJoe J. has a reputation beyond reputeJoe J. has a reputation beyond reputeJoe J. has a reputation beyond reputeJoe J. has a reputation beyond reputeJoe J. has a reputation beyond reputeJoe J. has a reputation beyond reputeJoe J. has a reputation beyond repute
Send a message via AIM to Joe J.
Ours weighs some where around 50 lbs. including Kit bot frame, KOP Transmissions, 4 total small CIMs, chain, 2 820 IFI wheels, 2 8" Skyway wheels RC and about 95% of our total electrical system. Of course since we are building in our school we figured the weight by me holding the frame while standing on a bathroom scale
Joe Jagadics
Lead Mentor / Coach
Lightning Robotics FRC Team 862
Unread 29-01-2006, 22:44
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Right now, our two-level 80/20 frame is weighing in at about 14 pounds. All said and done, the final chassis and drive train should total around 35-40 pounds.
Art Dutra IV
世上无难事,只怕有心人.
Unread 30-01-2006, 00:05
Veselin Kolev's Avatar
Veselin Kolev Veselin Kolev is offline
X51 Production Company PGM (TM)
Veselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond repute
Chassis with pillow blocks, electronics mounts, armor: 20 lbs
Two drive trains: 12 lbs
Wheels: 4 lbs
As for the rest of our robot:
Ball sucker: 10 lbs
Spiral of doom: 15 lbs
cannon: 10 lbs
doomsday machine: 12 lbs
Emergency rocket propelled ball extraction: 2 lbs
Unread 30-01-2006, 22:20
bjimster1's Avatar
bjimster1 bjimster1 is offline
AKA: Jimmy Bourne
FRC #1029 (Wolvcats)
bjimster1 is just really nicebjimster1 is just really nicebjimster1 is just really nicebjimster1 is just really nice
Send a message via AIM to bjimster1
for all those concerned with weight, our wheels weigh 12lbs EACH (yea they're heavy on purpose, you guys are smart, figure out why). we have 2. the complete drivetrain weighs ~45lbs minus electronics.
im not concerned with weight.
there's a song that comes to mind it starts something like MOVE %!$@&
-2006 UCF Quarterfinalists w/ 1345 & 21
-2005 Peachtree Quarterfinalists w/ 1180 & 462
-2005 UCF Quarterfinalists w/ 1694 & 348
CMU '11
Direct Drive Four Motor System Collin Fultz Technical Discussion 42 02-11-2006 12:03
Where Are "Chassis & Drive Train Instructions" Robeaux Kit & Additional Hardware 1 10-01-2006 16:17
[ECDU]: Right drive train for this game Michael Leicht FIRST-related Organizations 4 03-04-2005 22:31
What type of drive train did you make this year? James114 Technical Discussion 31 12-03-2005 19:11
