Go to Post Maybe I'm just a chicken. Not to disparage the ThunderChickens. Those guys are a whole different breed of poultry. - Kevin Sevcik [more]
View Poll Results: should bumpers be standard?
yes 33 33.67%
no 42 42.86%
standard except for length and size 18 18.37%
bumpers? 5 5.10%
Voters: 98. You may not vote on this poll
Unread 26-01-2006, 19:22
gondorf's Avatar
gondorf gondorf is offline
inventor/solidworks engineering spe
AKA: stephen truscott
FRC #1733 (The Polar Bots)
gondorf is a splendid one to beholdgondorf is a splendid one to beholdgondorf is a splendid one to beholdgondorf is a splendid one to beholdgondorf is a splendid one to beholdgondorf is a splendid one to beholdgondorf is a splendid one to beholdgondorf is a splendid one to behold
bumper customization?
<R35> The use of bumpers is strongly encouraged. Bumpers can reduce damage to robots when they contact another robot or field elements. If you choose to use the specified bumpers, you will have both a more robust robot and the traction advantage of a heavier robot. Bumper height has been specified so that robots will make contact bumper-to-bumper and so that the balls will be pushed rather than pulled under the robots. Note that robot wheel/tracks must be properly positioned relative to the bumpers to avoid trouble climbing the ramp. Obviously harvesting balls from the floor or launching balls along the floor must be done through gaps in bumpers or over bumpers. As the bumper mounts are being designed, please think about carrying the robot. The bumpers do not make good handles. Please do not "lawyer" the bumper rule - it is meant to help. If used, bumpers must satisfy the following constraints:
Bumpers must be designed as shown in figure 5-1
Bumpers must be removable so that they can be weighed separately from the robot
Bumpers must weigh, in total, no more than 15 pounds including any fasteners that attach them to the robot
Bumpers must not include sections that weigh more than 3 ounces per inch (i.e. no short bumpers with giant heavy fasteners)
Bumpers must use a stacked pair of 2-1/2 inch "pool noodles" as the bumper material
Bumpers must use 3/4 inch plywood backing 5 inches tall as the bumper structure to attach the bumper ("pool noodles") to the robot
Bumpers must be covered with a tough smooth cloth (1000 denier Cordura Plus® strongly recommended)
At the start of the match bumpers may extend outside the horizontal starting dimensions for the robot (as specified in Rule <R05>) by up to a maximum of 3-1/2 inches per side, nothing other than pool noodlesand cloth may extend more than 1 inch beyond the robot boundaries
Bumpers must be positioned on the robot so that they remain between 2-1/2 inches and 8-1/2 inches above the floor
how does this allow for customization? i mean they kinda limit your ability to design.
Unread 26-01-2006, 19:23
Collin Fultz's Avatar
Collin Fultz Collin Fultz is online now
no team (IndianaFIRST)
Collin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond repute
Re: bumper customization?
That's exactly the point. Basically they're giving you 15 lbs and three extra inches on each side. If you don't like the rules...you don't have to use them.
Collin Fultz
Unread 26-01-2006, 19:26
Mr. Freeman Mr. Freeman is offline
Put better title here.
AKA: Kellan
no team (CSM Robotics)
Mr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to behold
I think that they didn't want people designing "bumpers" with ball gathering mechanisms, or otherwise using the "bumpers can extend outside the robot boundaries" rule to an ungracious advantage.
"Time is an illusion, lunchtime doubly so."
-Douglas Adams
“Why is it that I can walk into Wal-Mart and buy boxes of bullets and black powder, but I can’t buy potassium perchlorate to do science because it can also be used to make explosives?”
-Theodore Gray
Unread 26-01-2006, 19:38
occra 23.
AKA: ryo
None #1481
clarification.... you dont have to use the bumpers. not you dont have to use the rules.
Unread 26-01-2006, 21:27
pathew100 pathew100 is offline
AKA: Pat Murphy
FRC #0862 (Lightning Robtics)
pathew100 has much to be proud ofpathew100 has much to be proud ofpathew100 has much to be proud ofpathew100 has much to be proud ofpathew100 has much to be proud ofpathew100 has much to be proud ofpathew100 has much to be proud ofpathew100 has much to be proud ofpathew100 has much to be proud ofpathew100 has much to be proud of
Send a message via AIM to pathew100
You don't have to use the official FIRST spec bumpers. But...
If you do, you get the extra 15lbs.
You also get the extra 3 inches or so.
You can make your own bumper however you want but,
You don't get the extra weight or size.
You still can only contact other robots within the defined 'bumper' zone extending 8" from the floor. Also your bumpers cannot be more than 10 degrees from vertical. These last two restrictions are Rules, not Suggestions (like the bumper design).
Unread 26-01-2006, 21:32
Andrew Blair's Avatar
FRC #0306 (CRT)
Anyone wonder how FIRST is even getting fifteen pounds out of the bumpers anyway? I mean, there is only a certain amount of perimeter on the robot, and only a certain way that you can build the bumpers. 15 pounds seems like a little much, unless you pour a little lead shot in with the noodles...
-Sir Francis Bacon
-Albert Einstein
Unread 27-01-2006, 01:17
Not all plywood is created equal. Hint: the best plywood for the purpose doesn't come from Home Depot.
It's a pity they specified plywood for the backing board. Our front and rear bumpers (more like collision protection bars) last year were 4/4 red oak. They had significant quantities of dings and scratches, but our robot was otherwise untouched. Plywood is pretty wimpy stuff by comparision. If you think of solid lumber as nature's own composite material, in plywood have the fibers are going the wrong way in an application like this.
Unread 29-01-2006, 15:53
Schneidie's Avatar
Schneidie Schneidie is offline
AKA: Marc Schneider
FRC #0177 (The Bobcats)
Schneidie will become famous soon enoughSchneidie will become famous soon enough
Smile Re: bumper customization?
The rules are a bit strict, as they do not allow for any customization to the bumpers, if the bumpers are to exceed the legal limit of the robot. But the bumpers are a huge advantage, seeing as they add width and weight over the legal limits without being illegal, bu tthat's only if you use the bumpers in the rules.
Schneidie
Unread 29-01-2006, 16:36
Jon K. Jon K. is offline
n.e.r.d #6
Jon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond repute
Originally Posted by Schneidie
The rules are a bit strict, as they do not allow for any customization to the bumpers, but the bumpers are a huge advantage, seeing as they add width and weight over the legal limits without being illegal.
They do allow for some customization, but still put all teams on an equal playing ground. The previous years bumper rules simply stated that they had to be soft so that you could hit them and not get hurt. Well different teams have different pain threshholds so to speak, and therefore there were a bunch of different designs. These are customizable in that you are allowed to leave opening for ball gathering etc, as well as being able to choose different colored fabric to cover them, so they can still match your robot.
Alumnus of FLL 2000 ~ Alumnus of FRC173 2002-2005 ~ Mentor of FRC173 2006-2007 ~ Mentor of FRC 3780 2014
FIRST Volunteer since 2003
Manufacturing Manager
AndyMark, Inc.
http://www.andymark.com
Unread 29-01-2006, 16:54
Gdeaver Gdeaver is offline
FRC #1640
Bumpers are a great idea. The problem is that the rules are very strict. With our kit frame and wheels and the lack of modifications allowed, we can't go up the ramp with bumpers. The modifications to the frame and wheels that would allow us to go up the ramp have undesirable effects. So at this time we most likely will not use bumpers. If First in an update allows modifications to the bumper height we would use bumpers. There are many problems with collisions involving bumpered and non-bumpered bots. This whole bumper issue needs rethinking by First going forward. Mandatory bumpers in a bumper zone with certain allowed design modifications would be a very very good thing.
Unread 29-01-2006, 17:07
Marcel Marcel is offline
The Fool
AKA: BabyFace
FRC #0059 (RamTech)
Team Role: Scout
Marcel is on a distinguished road
Send a message via AIM to Marcel Send a message via MSN to Marcel Send a message via Yahoo to Marcel
Well one thing my team usually does rather than bumpers is to design the robot so if someone tries anything, they'll be hurting thimselves more than the damage they wanted to do on us lol. See we cant get in trouble because we didn't try to hurt anyone, its just that someone tried us and hurt themselves in the process Bwahahahaha.
Unread 29-01-2006, 20:54
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is offline
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
I might be mistaken, but is there a rule that says that IF you put bumpers on, they must be on all four sides? If not...well there's a possible solution to your problem
Unread 30-01-2006, 00:09
pez1959's Avatar
pez1959 pez1959 is offline
Cap'n Patty
AKA: Patrick
FRC #1959 (Aye Aye Robot)
pez1959 is on a distinguished road
Send a message via AIM to pez1959 Send a message via MSN to pez1959 Send a message via Yahoo to pez1959
well assuming that the rule posted previously^ is the only rule about bumpers, it suggests that you can put your bumpers on in sections. Since it doesn't say anything about all four sides, I think its a safe assumption that you can do bumpers on only two or three sides.
Unread 30-01-2006, 00:50
Kirk Kirk is offline
FRC #0254
Kirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud of
Send a message via AIM to Kirk
I was just wondering if anyone has found a source for the specific pool noodles? I remember a thread where someone was having a hard time finding the noodles.
Thanks,
Kirk
Unread 31-01-2006, 14:30
Team 614 Team 614 is offline
FRC #0614
Team 614 is an unknown quantity at this point
we were able to get our bumpers one ebay pretty cheap just look around
Confessions of a serial bumper... Joe Johnson Car Nack's Corner 3 13-01-2006 15:31
Bumper modification Doogie Technical Discussion 4 11-01-2006 22:37
Bumper sensors jeffmorris FIRST Tech Challenge 1 02-10-2005 16:20
Bumper Classification Sachiel7 Rules/Strategy 5 30-01-2005 18:43
