Go to Post Putting 2 and 2 together, and then mixing them back up for someone else to try and get 4 in a different way is just plain fun. - Elgin Clock [more]
Go Back   Chief Delphi > FIRST > Rumor Mill
Unread 01-28-2006, 11:58 PM
sirbleedsalot's Avatar
sirbleedsalot sirbleedsalot is offline
FRC #0939
Team Role: Student
sirbleedsalot has a spectacular aura aboutsirbleedsalot has a spectacular aura aboutsirbleedsalot has a spectacular aura about
Re: Who has a finished robot?
My team is not finished yet but it seems you guys could help me out, how do i program my robot to have a motor spin counter clockwise when i pull the trigger on the joystick, then released it stops turning the motor, and when i press the thumb button i want the motor to spin clockwise. I am using easyc and i was wondering how to write that code. Please help.
our web site
Unread 01-29-2006, 12:36 AM
Done???? What does this word mean? In FIRST, no robot is "done" until at least after the last competition of the year (offseason or otherwise). And we still aren't done with our '04 bot--it's been used as a practice bot for last year and a sensor testbed this year. (I know of a team that modified their robot in a big way between Championship and IRI last year. 'Nuff said.)
Unread 01-29-2006, 01:06 PM
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is offline
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
search in the easy-c section of the programming forum. if it's not there, post
Unread 01-29-2006, 04:07 PM
David55 David55 is offline
AKA: David Hillman
FRC #1577 (Steampunk) & FRC #125 (NUTRONS)
David55 is a splendid one to beholdDavid55 is a splendid one to beholdDavid55 is a splendid one to beholdDavid55 is a splendid one to beholdDavid55 is a splendid one to beholdDavid55 is a splendid one to behold
if(p1_sw_trig==1)
pwm01=0;
else if(p1_sw_trig==0)
pwm01=127;
if(p1_sw_top==1)
pwm01=255;
else if(p1_sw_top==0)
pwm01=127;
This is how you would do it in mplab...not sure if it will work in easy c.
The "p1's" in the "if's" are dependent on what port your joystick is plugged into in the OI. If your joystick is plugged into port 2- change it to p2_sw_trig.
Also...the ""pwm01" should be changed to whatever pwm your motor is connected to. You should also check if the thumb button is p1_sw_top...it could also be p1_sw_aux1 or p1_sw_aux2.
Please tell me if I confused you and I will try to make it simpler.
Unread 01-29-2006, 06:59 PM
Sgraff_SRHS06's Avatar
Sgraff_SRHS06 Sgraff_SRHS06 is offline
Kappa != 1/(4Pi-Epsilon-Naut)
AKA: Steve Graff
FRC #1111 (The Power Hawks)
Sgraff_SRHS06 is a jewel in the roughSgraff_SRHS06 is a jewel in the roughSgraff_SRHS06 is a jewel in the roughSgraff_SRHS06 is a jewel in the rough
Send a message via AIM to Sgraff_SRHS06 Send a message via Yahoo to Sgraff_SRHS06
When we mean finished, we mean "it's working in full, functional form," not "let's sell this as the next GM hybrid." And by the first definition, we're shooting for a completely-constructed bot by Thursday (and it gives me time to work on my other duties: awards.)
POWERHAWKS FORUM
2006 Chesapeake Regional Semifinalists (Thank you 614 and 339!)
UM Class of 2010!!
Unread 01-29-2006, 08:03 PM
FRC #0939
Team Role: Student
I understand what you are saying, however i am not building it in MPLAB, if i was to build it there is there a defualt code that already is programmed to drive the bot. In easyc i need to know what to drag and drop into the code(pwm control, OI to Digital output, OI to analog, and that whole list) what i would drag and drop.
our web site
Unread 01-29-2006, 08:41 PM
AKA: Steve Graff
Then I cannot help much, since my team is not using much of the EasyC yet.
POWERHAWKS FORUM
UM Class of 2010!!
Unread 01-30-2006, 07:24 AM
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Originally Posted by David55
if(p1_sw_trig==1)
pwm01=0;
pwm01=127;
if(p1_sw_top==1)
pwm01=255;
pwm01=127;
I would not use '0' or '255' as PWM #s. Use '1' and '254'. two '255's in a row indicate end of packet and can cause some erratic behavior.
I havent looked at easy C but you should be able to look at the code behind each icon and edit it, thus the code above should be useable.
Good luck.
Unread 01-30-2006, 09:17 AM
StephLee's Avatar
StephLee StephLee is offline
Deadlines? What are those?
AKA: Stephanie
FRC #0639 (Code Red Robotics)
StephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond repute
Send a message via AIM to StephLee
Our robot can't drive yet.
We've got our priorities backwards; we have several of the harder aspects done to the point where they work decently well, but the "easier" things we have yet to finish. Now we're trying to get it to the point where we can have our drive team start playing with it to figure out what needs to be changed. We're way behind where we were this time last year, but that's because we're pushing our limits a lot more this year. I just hope it can move before ship date...
Proud alum of FRC Team 1629 and mentor of FRC Team 639
Cornell Engineering class of 2012!!
Unread 01-31-2006, 08:24 PM
ShaneP's Avatar
ShaneP ShaneP is offline
Lead Mentor
FRC #0330 (The Beach Bots)
ShaneP is a splendid one to beholdShaneP is a splendid one to beholdShaneP is a splendid one to beholdShaneP is a splendid one to beholdShaneP is a splendid one to beholdShaneP is a splendid one to beholdShaneP is a splendid one to beholdShaneP is a splendid one to behold
I suppose you could say that robots are never done with, until they are permanently sitting in the robot grave yard.
But as for finished robots for this season, I doubt any team is done just yet. Even if they were, there would still be brainstorming of how to make it better.
Unread 01-31-2006, 09:45 PM
Donut Donut is online now
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
We've already been informed by our mechanical group today that with how things are going building wise, we'll have ~3 days to actually test code. No finished robots anytime soon at our school.
We have most (or all) of the chassis built, the problem is electrical is way behind (all new people and difficulty in getting engineers in to help put us there), and they still have to finish alot of the "extra" parts that go on the chassis.
Programming we've managed to jump from no code to almost all manual control done in only 3 days.
I'll check Easy C tonight and try to figure that one out.
Unread 01-31-2006, 10:23 PM
Bharat Nain's Avatar
Originally Posted by Karthik
I've learned never to say never when it comes to FIRST teams. Frankly, I guarantee you that at least one team is done at this point.
That's correct. But I do not speak of team 25. Or do I...
-= Bharat Nain =-
Whatever you do, you need courage. Whatever course you decide upon, there is always someone to tell you that you are wrong. There are always difficulties arising that tempt you to believe your critics are right. To map out a course of action and follow it to an end requires some of the same courage that a soldier needs. Peace has its victories, but it takes brave men and women to win them. - Ralph Waldo Emerson
Unread 01-31-2006, 11:11 PM
kaszeta's Avatar
kaszeta kaszeta is offline
FRC #0095 (Grasshoppers)
kaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of light
3 days? That's 72 hours of pure testing! Luxury!
Two years ago, our team didn't finish our bot until the last hour of pit day (that's not really legal anymore), and we spent entirely too much time creatively shedding weight in the pits. So, as you might imagine, the code wasn't, err, optimal. Last year we had plenty of time with the kitbot, but the final bot wasn't really ready until ship day (with some substantial changes), so it was again a lot of pit engineering getting the code up to snuff.
That said, our team this year seems to be in good shape, especially with respect to the building, and the software is coming along nicely with incremental features added. This year's bot will never be "done", it will just keep getting better and better.
Unread 01-31-2006, 11:24 PM
LightWaves1636's Avatar
LightWaves1636 LightWaves1636 is offline
is all over it.
AKA: Sarah Le
LightWaves1636 is a splendid one to beholdLightWaves1636 is a splendid one to beholdLightWaves1636 is a splendid one to beholdLightWaves1636 is a splendid one to beholdLightWaves1636 is a splendid one to beholdLightWaves1636 is a splendid one to beholdLightWaves1636 is a splendid one to behold
Send a message via AIM to LightWaves1636 Send a message via Yahoo to LightWaves1636
*gasp* robot? what robot? we were suppose to build a robot?
we've only began, but we'll get there.
Unread 02-01-2006, 10:29 PM
NERD12345 NERD12345 is offline
Junior Member
NERD12345 is an unknown quantity at this point
well, our team isn't actually building a robot, we're covering our team leader in foil. so, technically we are finished. we just have to figure our shipping and handling packages.
Pre-Rookie Teams - The How To Keith Chester General Forum 6 09-17-2008 12:28 AM
Team 701s finished robot Salik Syed Robot Showcase 14 01-28-2006 11:00 AM
Is allowing a practice robot good for FIRST? Matt Adams General Forum 38 01-19-2005 11:35 AM
what kind of robot will win? Bcahn836 Championship Event 44 04-12-2004 12:02 AM
Robot Collaboration Karthik General Forum 153 02-18-2004 03:40 AM
