Go to Post Brainstorming and creativity are great, but you do actually have to build the ideas you come up with sometime. - Chris is me [more]
Unread 27-01-2006, 01:25
Kevin Watson's Avatar
La Cañada High School
FRC #2429
*** CMUcam2 Frequently-Asked-Questions ***
I've started a CMUcam2 frequently-asked-questions document here: http://kevin.org/frc/camera. If you have questions that you think should be added to the document, please post them here.
-Kevin
Kevin Watson
http://kevin.org
Unread 28-01-2006, 23:45
bear24rw's Avatar
bear24rw bear24rw is offline
Team 11 Programming Captain
AKA: Max T
FRC #0011 (MORT)
bear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to behold
Send a message via AIM to bear24rw
Re: CMUcam2 Frequently-Asked-Questions
Q3: Where do we plug in the pan and tilt servos?
A3: By default the pan servo is attached to the robot controller's PWM 1 output and the tilt servo is plugged into the the robot controller's PWM 2 output. These assignments can be changed in camera.h.
Don't you mean "tracking.h" ?
Unread 29-01-2006, 00:09
FRC #2429
DOH! Thanks for pointing that out <sheepish-grin>.
-Kevin
Kevin Watson
http://kevin.org
Unread 30-01-2006, 12:01
mallot1243's Avatar
mallot1243 mallot1243 is offline
FRC #1243
mallot1243 is an unknown quantity at this point
what is the difference in using the PWM outputs and the Servo0, 1 on the camera?
Unread 30-01-2006, 12:14
FRC #2429
The code currently uses the robot controller's PWM outputs to control the pan and tilt servos. I'm working on a version of tracking.c that will allow you to use robot controller or CMUcam2 PWM outputs. I'll post it if I can get it to work correctly.
-Kevin
Kevin Watson
http://kevin.org
Unread 30-01-2006, 22:08
FRC #2429
The CMUcam2 Frequently-Asked-Questions document has been substantially updated in the last day or so. Included is a troubleshooting checklist. It can be found here: http://kevin.org/frc/camera.
-Kevin
Kevin Watson
http://kevin.org
Unread 31-01-2006, 19:35
Ryan O's Avatar
Ryan O Ryan O is offline
FRC Eclipse Plug-in Developer
no team (FRC Eclipse)
Ryan O is an unknown quantity at this point
Send a message via AIM to Ryan O
In the thread titled "Code Errors with Bells and Whistles" I detailed a problem I encountered when I rewrote part of your code so the camera scans in both directions. Since you wrote the origanal, i was wondering if I possibly just left out a neccassary intailization line or something. Can you give any suggestions?
Unread 01-02-2006, 00:47
FRC #2429
Send me the code and I'll have a look.
-Kevin
Kevin Watson
http://kevin.org
Unread 01-02-2006, 08:29
Ryan O's Avatar
-Kevin
Ok, I e-mail it to you if it doesn't work. I made a couple changes. One things was to move the intailization to the very top of the code. Before, I was calling Tracking_Config_Data info before intailization, so that might have been the problem. If it was I'll post here to let you know that it was fixed. Otherwise I should have it sent by five tonight. Thanks for the help.
Unread 08-02-2006, 11:57
mallot1243's Avatar
FRC #1243
Can you use a different motor to control pan function? if so what would the code have to look like?
Unread 08-02-2006, 18:40
bhsrobotics1671's Avatar
bhsrobotics1671 bhsrobotics1671 is offline
Andrew Nabors
AKA: Andrew Nabors
FRC #1671 (Buchanan Bird Brains)
bhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to behold
Talking Re: CMUcam2 Frequently-Asked-Questions
-Kevin
how do you re-upload the tracking.h file to the camera again after modifying it?
thankss
-bunch of freshman noobs from clovis, CA
team 1671
Unread 08-02-2006, 18:46
X-Istence X-Istence is offline
Melt the RC controller!
AKA: Bert JW Regeer
X-Istence will become famous soon enoughX-Istence will become famous soon enough
Send a message via AIM to X-Istence Send a message via MSN to X-Istence
Different . First, the motor does not have PWM versus Angle, thus you'd have to find some method of finding how to fix it so that it did, then you'd have to figure out how you want to keep track of what angle it is at. Basically it is complicated.
My Blog!
Unread 08-02-2006, 18:55
nehalita's Avatar
nehalita nehalita is offline
Robots are friends
AKA: tagger fanatic
FRC #1345 (Platinum Dragons); FRC# 97 (RoboRuminants)
nehalita has a reputation beyond reputenehalita has a reputation beyond reputenehalita has a reputation beyond reputenehalita has a reputation beyond reputenehalita has a reputation beyond reputenehalita has a reputation beyond reputenehalita has a reputation beyond reputenehalita has a reputation beyond reputenehalita has a reputation beyond reputenehalita has a reputation beyond reputenehalita has a reputation beyond repute
Send a message via AIM to nehalita Send a message via MSN to nehalita Send a message via Yahoo to nehalita
1) I was trying to drive the robot and operate the camera at the same time so I enabled "Default_Routine" in the Process_Data_From_Master_uP function but I think it conflicted with the camera code (i'm not sure if that's right) because the camera wouldn't work at all. So I just put whatever I needed before "putdata" [the pwms, relays, etc.]
i don't know if my assumptions were right or if i messed up but i think you should address this in some form of a question (that I obviously can't come up with right now).
2) This is a stupid mistake, but someone else might have done it before. If you "accidentally" switch the servos hooked up to the RC, you get that "searching searching searching" thing also and it took me an hour to figure that one out (it's always gotta be the simple things that take forever to figure out).
3) I think you should put something at the top or inside the code about being careful when you load the code for the first time. I had the pwms hooked up to the camera and my motors hooked up to pwm01 and pwm02. So, as the camera tracked the green light, the robot went crazy and i nearly killed myself. After reading the FAQs, I figured out why but maybe if there's a warning somewhere inside the code, it won't happen to another team.
4) When i started using the camera for the first few times, i had the serial cable hooked up to the camera along with the pwm to the ttl port. It's obvious to me now that I can't have both hooked up to the camera at the same time but it wasn't then. You could put that in your FAQs
....those are all the mistakes i can remember but i'm sure i have plenty more to come. =)
btw, after my series of errors, my camera worked wonderfully. you're the man kevin. my whole team's amazed how "i got" the camera to dance around but really, it was all your hard work and i got the credit for it. great job.
oh, and the FAQs helped a lot!
"Relativity applies to physics, not ethics." Thank you Einstein
MIT '10
Proud Member of H.I.L.
The PLATINUM DRAGONS are on FIRE!
Unread 08-02-2006, 19:23
Andrew Nabors
AKA: Andrew Nabors
-Kevin
Kevin We Need Your Help Re-Uploading the tracking.h file
Anyone!?!?!?
Buchanan Bird Brains - FRC Team 1671
2015 FIRST World Champions
118, 1678, 1671, 5012
Unread 09-02-2006, 11:00
mallot1243's Avatar
FRC #1243
I should have explained my self a little more. We're planning on taking the pan servo off and using the code to control a turret, is there a way to develope a potentiometer structure in replacement of the servo function?
Questions you've been asked about robotics JamizzleHavok13 Chit-Chat 32 09-08-2009 16:16
#1 The Journey of a FIRST Graduate: Questions Ken Leung General Forum 12 27-07-2005 18:24
Please post questions Chairman's judges asked!! Roxanna V Chairman's Award 0 05-04-2005 10:33
Q/A questions so far.. AmyPrib Rules/Strategy 49 28-01-2005 08:39
**FIRST EMAIL**/Autodesk Inventor Training and Technical Questions Information Rich Wong FIRST E-Mail Blast Archive 0 07-12-2004 17:22
