Go to Post Go with a Big Block. The torque is awesome and you cant beat the sound of a built Big Block with a high lift cam and some open headers. A blower would be a nice addition as well. Good luck getting past the inspector. - GBK [more]
Go Back   Chief Delphi > Technical > National Instruments LabVIEW and Data Acquisition > LabView and Data Acquisition
Unread 30-01-2006, 13:38
Wynlyndd Wynlyndd is offline
FRC #1865
Wynlyndd is an unknown quantity at this point
error 5101 : Timeout
We have tried over and over to get labview to work. We have run all the serial port diagnostics we have seen and indeed we have no trouble getting serial communications to the controller board to upload new code.
However, Labview always gives us an error (5101) about the serial port. We have reinstalled Labview and NI-VISA, checked in MAX that our serial ports are configured properly, etc.
We finally found a java based gui for testing the camera and it seems to work fine (finally got a frame from our camera!) but we would really love to figure out the problem. Any ideas?
Unread 30-01-2006, 16:30
Danny Diaz's Avatar
Danny Diaz Danny Diaz is offline
Smooth Operator
AKA: FrankenMentor
None #0418
Danny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond repute
Send a message via AIM to Danny Diaz
Re: error 5101 : Timeout
Have you tried the latest update? What kind of Serial adapter are you using (built-in versus USB-Serial cable)?
-Danny
Danny Diaz
Former Lead Technical Mentor, FRC 418
Unread 31-01-2006, 12:14
FRC #1865
I guess I did not see a Labview update. I will go back and check.
We are using the builtin serial port.
Unread 31-01-2006, 14:05
Joe Hershberger Joe Hershberger is offline
AKA: jhersh
FRC #2468 (Appreciate)
Joe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to all
It's not a LabVIEW update... it's an update to the CMUCam2 application. Found here.
-Joe
Timeout!! Ricky Q. Rules/Strategy 19 01-04-2004 22:03
Bug: Login Problems - Session timeout value too low? DanL CD Forum Support 4 09-01-2004 16:33
Microsoft Timeout AJ Quick Regional Competitions 12 09-03-2003 17:38
Timeout Ruling Discussion ram Off-Season Events 4 29-11-2001 13:38
