Programming with the EDU
I have a 2004 EDU robot controller that i am trying to use to start developing code at home(my team needs the large RC at school so they can start putting it on the robot) and the problem that i am having is that when i edit the default code and compile then add it to the RC it does not do what i want or it does nothing at all,
is there any sort of special areas to edit code for the EDU RC also i am not using a radio modem so i dont know if that will have some sort of effect on it. |
| Programming Vex w/ MPLab | dababyjebus | FIRST Tech Challenge | 27 | 25-04-2008 09:11 |
| Programming - Getting Started | Mark McLeod | Programming | 80 | 16-04-2008 23:37 |
| Programming Forum Warning | Brandon Martus | Announcements | 10 | 29-12-2005 13:32 |
| Suggestion for Delphi Programming Posts | Chris Hibner | CD Forum Support | 1 | 27-07-2005 10:02 |
| Robot Programming Education | phrontist | Programming | 11 | 03-05-2004 07:32 |
