Go to Post In FIRST, there's no such thing as too many 1/4-20 bolts, too many bottles of caffeinated beverage, and too much knowledge from others. - Billfred [more]
Unread 30-01-2006, 13:42
Cuog's Avatar
Cuog Cuog is offline
Registered Linux User: 390661
AKA: Alex
FRC #0422
Programming with the EDU
I have a 2004 EDU robot controller that i am trying to use to start developing code at home(my team needs the large RC at school so they can start putting it on the robot) and the problem that i am having is that when i edit the default code and compile then add it to the RC it does not do what i want or it does nothing at all,
is there any sort of special areas to edit code for the EDU RC also i am not using a radio modem so i dont know if that will have some sort of effect on it.
KK4KQO
http://voltair.us
Unread 30-01-2006, 13:53
Eldarion's Avatar
Eldarion Eldarion is offline
Electrical Engineer / Computer Geek
AKA: Eldarion Telcontar
no team (Teamless Orphan)
Eldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond repute
Send a message via AIM to Eldarion Send a message via Yahoo to Eldarion
Re: Programming with the EDU
The EDU RC is not cross-compatible with the full-size FRC controller. I would suggest using either the 2004 or the 2005 full-size RC for this application.
CMUCam not working? Tracks sporadically? Try this instead: http://www.falconir.com!
PM me for more information if you are interested (it's open source!).
Want the FIRST Email blasts? See here: http://www.chiefdelphi.com/forums/sh...ad.php?t=50809
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
If it's falling apart it's a mechanical problem. If it's spewing smoke it's a electrical problem.
If it's rampaging around destroying things it's a programming problem.
"All technology is run on 'Magic Smoke' contained within the device. As everyone knows, whenever the magic smoke is released, the device ceases to function."
-- Anonymous
I currently speak: English, some German, Verilog, x86 and 8051 Assembler, C, C++, VB, VB.NET, ASP, PHP, HTML, UNIX and SQL
Unread 30-01-2006, 13:56
Cuog's Avatar
AKA: Alex
FRC #0422
I would love to get a full size RC but my team is dead set on not pirating from these 2 previous robots but i am pretty sure that the EDU can still be used for testing sensor algorithms right?
KK4KQO
http://voltair.us
Unread 30-01-2006, 13:57
CmptrGk's Avatar
CmptrGk CmptrGk is offline
Programming Mentor
AKA: Dillon
FRC #0716 (Who'sCTEKS)
CmptrGk has much to be proud ofCmptrGk has much to be proud ofCmptrGk has much to be proud ofCmptrGk has much to be proud ofCmptrGk has much to be proud ofCmptrGk has much to be proud ofCmptrGk has much to be proud ofCmptrGk has much to be proud of
are you adding the needed files to the edu's default code?
"Great autonomous mode Dillon."," It hasn't been written yet"
after an Archimedes match
Unread 30-01-2006, 13:59
Eldarion's Avatar
I think you are talking about this thread: http://www.chiefdelphi.com/forums/sh...ad.php?t=42181
-- Thomas Paine
-- Anonymous
Unread 30-01-2006, 14:00
Pat Fairbank's Avatar
Pat Fairbank Pat Fairbank is offline
Circuit Breaker
Pat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond repute
Send a message via MSN to Pat Fairbank
In case you weren't aware, the EDU RC uses a slightly different default code than the full-size RC. It can be found on the IFI Legacy Docs page under "Mini RC".
Also, the EDU RC runs the code whether or not you have a radio modem hooked up to it.
Patrick Fairbank
Team 254 | Mentor (2012-)
Team 1503 | Mentor (2007-2011)
Team 296 | Alumnus (2001-2004) | Mentor (2005-2006)
patfairbank.com
Unread 30-01-2006, 14:01
Cuog's Avatar
AKA: Alex
FRC #0422
I took the EDU default code off of IFIRobotics.com and added a little addition to cycle the pwm01 up until it reached 255 and start over again and the pwm would just stay at 58.( i added this in default_routine then in procces data from local io and niether one worked)
KK4KQO
http://voltair.us
Unread 30-01-2006, 15:04
If you post the EDU project we can help.
We're using the 2004 EDU to drive our prototype shooter's velocity control.
Unread 30-01-2006, 17:21
Cuog's Avatar
AKA: Alex
FRC #0422
I am using the project file i downloaded from the link Pat put up there then in Proccess_Data_From_Local_IO() i added the lines:
pwm01++;
if(pwm01 == 255)
pwm01 = 0;
KK4KQO
http://voltair.us
Unread 30-01-2006, 17:35
coldabert's Avatar
coldabert coldabert is offline
The Dude
FRC #0888 (Robotiators)
coldabert is a glorious beacon of lightcoldabert is a glorious beacon of lightcoldabert is a glorious beacon of lightcoldabert is a glorious beacon of lightcoldabert is a glorious beacon of light
Send a message via AIM to coldabert
The EDU RC will run the same type of code as the full size RC. Just be sure to include all needed library and header files. Sensor algorithms can be tested by the EDU but be sure that any outputs are compatible with the hardware.
Unread 30-01-2006, 18:52
Process_Data_From_Local_IO() is definitely the wrong place to update a PWM. The PWM output will only change with each call to Putdata() inside Process_Data_From_Master_uP(), so move your code there.
Comment out the call to Default_Routine() unless you've disabled the pwm01 set in there.
I downloaded a fresh copy of the Edu default code and added your lines with a print in Process_Data_From_Master_uP(), commenting out the call to Default_Routines() so pwm01 doesn't get clobbered. I also attached a servo to pwm01 on the Edu for positive feedback that it works, and it happily ticks away, rewinds, and ticks away again.
Unread 30-01-2006, 19:29
Cuog's Avatar
AKA: Alex
FRC #0422
Ok since u have had the code work im going to go and upload what u just made and see if it works and if it doesnt then i will call up ifi since it will likely be a firmware problem, i have no idea if the EDU RC we have is any good since it has been sitting around for the past 2 years, and thanks everyone this will really get me moving on more advanced sensors since i can test now
KK4KQO
http://voltair.us
Programming Vex w/ MPLab dababyjebus FIRST Tech Challenge 27 25-04-2008 09:11
Programming - Getting Started Mark McLeod Programming 80 16-04-2008 23:37
Programming Forum Warning Brandon Martus Announcements 10 29-12-2005 13:32
Suggestion for Delphi Programming Posts Chris Hibner CD Forum Support 1 27-07-2005 10:02
Robot Programming Education phrontist Programming 11 03-05-2004 07:32
