Go to Post I check Chief Delphi more often than I check Facebook and Twitter combined. It's probably unhealthy actually... - Ginger Power [more]
Unread 28-01-2006, 10:08
Dancin103 Dancin103 is offline
The Crazy Blonde
AKA: Cassie
FRC #0103 (Cybersonics)
Dancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond repute
Send a message via AIM to Dancin103
Velocity???
Quick and probably complex question......Has anyone figured out how to measure the velocity of the balls exiting the shooter your team has created???
Cybersonics Technology Team 103
2003 Championship Chairman's Award Winners
NEED CHAIRMAN'S HELP?? Subscribe to our YouTube Channel, we answer your questions daily!
Unread 28-01-2006, 11:57
Parker's Avatar
Parker Parker is offline
FRC #1079 (C.R.E.A.T.E.)
Parker is an unknown quantity at this point
Re: Velocity???
Go into a closed room where there is no wind and fire the ball. You want to measure the distance, time and launch angle. The distance divided by time is the X component of your initial velovity. The X compenent times cosine of the angle will give you your initial velocity.
air resistance is negligible in a closed room.
*Beware of metric to standard conversion and radians to degrees!
Unread 28-01-2006, 12:24
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: Velocity???
use a radar gun
2001-2004: Team 100
2006-Present: Team 254
Unread 28-01-2006, 12:46
Re: Velocity???
there has been a lot of debate and discussion on this subject, esp regarding how much air resistance slows the ball down (air is still present in a room, even when its not moving)
and also the effect that spin has on the distance a ball will travel.
The two answers that seem to have the most validity are making a time-gate with two optical sensors, that the ball passes through as it exits your bot, or using a radar gun.
If you search this forum on " muzzle velocity " you will find a lot of posts on the subject.
The Crazy Blonde
AKA: Cassie
Re: Velocity???
HOw are you measuring this accurately - what instruments are you using? And do you have an idea how FIRST is going to measure this important component at the competitions??
Unread 28-01-2006, 13:40
Veselin Kolev's Avatar
Veselin Kolev Veselin Kolev is offline
X51 Production Company PGM (TM)
Veselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond repute
Re: Velocity???
Since our school advisor is an AP physics teacher, he has lots of interesting stuff, like photogates. These are basically optical switches, so when a ball passes one, it blocks the laser and registers as a hit. If you put a photogate right up to the cannon and measure the time it takes the ball to pass the photogate, you know the ball's width so you know the ball's speed. It is very accurate because the photogates have a very high refresh rate, and they're digital.
If you have access to a high school physics room, ask around and see if anyone has a photogate, they're pretty common.
Unread 30-01-2006, 08:26
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Re: Velocity???
We used a digital video camera and a piece of PVC piping marked in 1' increments.
We were able to not only see muzzle velocity, but how consistant our muzzle velocity is even in 'rapid file'
Unread 30-01-2006, 08:29
Re: Velocity???
very interesting. A camcorder has a refresh rate of 16mS (60 images per second)
did you have to set the camera in 'sports mode' or some other 'fast action' mode of operation to get a clear image?
Unread 30-01-2006, 15:17
Best Available Data
FRC #1778 (Chill Out!)
Re: Velocity???
What type? I was under the impression that my miniDV camera ran at 30 fps, largely becuase in iMovie, there are 30 ticks in a second. I googled it and couldn't find anything.
Unread 30-01-2006, 15:33
Re: Velocity???
Only a few pro-level camcorders offer 60fps rates. The vast majority of camcorders (either older formats or DV) offer 30fps interlaced, 30fps progressive (non-interlaced), and/or the quickly-becoming-more-popular 24fps progressive "just like film" rate. Sixty fps camcorders aren't rare, but they aren't common, either.
Unread 30-01-2006, 15:51
John Gutmann John Gutmann is offline
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
John Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant future
Send a message via AIM to John Gutmann Send a message via MSN to John Gutmann Send a message via Yahoo to John Gutmann
Re: Velocity???
that is exaclt what our team did. We took the Photo gates from a Kelvin "Kel-Air" track and re mounted them to tell us the balls speed.
Unread 30-01-2006, 16:01
Jared Russell's Avatar
Taking a year (mostly) off
Re: Velocity???
You can use either banner sensors with reflective tape or the photoswitches from this year's kit to do it in code. Put them across the exit point of your shooting mechanism.
Start a timer when the interrupt from the beam being broken occurs, get its value when it sees the other side again, and do some math (since the ball is 7" in diameter).
If a ball is going 12m/s, it will take about 14.8ms between these events, well within the capabilities of the RC's timer resolution (see www.kevin.org/frc for how to use timers).
Unread 30-01-2006, 16:09
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Re: Velocity???
I think it is fantastic that a few teams out there are fortunate enough to have access to instruments that are accurate enough to measure the ball speed precisely. So, can you do the rest of us a HUGE favor.
Now that you know exactly how fast your ball is launching and what angle of elevation you are launching, can you please calculate just how much air resistance and spin are affecting the balls flight. In other words, does the basic equation for trajectory, or more precisely range, equal what you are seeing? And if not, by how much are you off?
Unread 30-01-2006, 17:23
Re: Velocity???
ok, you are correct. The even and odd fields of the interlaced video are captured at 60 'fields' per second
most camcorders, when you pause them or single step the frames will output only one of the fields (even or odd), and then it jumps to the same field of the next frame
so yes, your view-able images would be 33.33mS apart.
Problems Using PID for Velocity Astronouth7303 Programming 6 10-02-2006 09:00
Manual Velocity PID, anyone successful? Chris_Elston Programming 20 31-01-2006 20:51
Measuring Muzzle Velocity Team 614 Rules/Strategy 8 28-01-2006 14:53
Velocity Calculation CyberWolf_22 Programming 2 27-01-2006 10:36
pneumatic launch velocity Keeler836 Pneumatics 23 16-01-2006 23:23
