Go to Post Titanium is almost twice as heavy as aluminum. I can have the bragging aspect of making a bullet resistant robot, but if someone is coming into a competition and shooting my robot, I have more important things to worry about! - Andrew Blair [more]
Unread 30-01-2006, 16:46
Packmon's_girl's Avatar
Packmon's_girl Packmon's_girl is offline
Rei, and guys...stop being so male
AKA: Rebekah Olson
FRC #1918 (Packman)
Team Role: Student
Packmon's_girl is an unknown quantity at this point
Send a message via AIM to Packmon's_girl Send a message via MSN to Packmon's_girl Send a message via Yahoo to Packmon's_girl
pic: Bare minimum
2006 - All-Star Rookie, Top Seeded Rookie (West Michigan regional)
2006 Nationals - Top Seeded Rookie, Newton Division
((FYI Steller_mist is my gaia username))
Unread 30-01-2006, 16:48
Collin Fultz's Avatar
Collin Fultz Collin Fultz is offline
no team (IndianaFIRST)
Collin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond repute
Re: pic: Bare minimum
This looks good. I'm curious though. Why didn't you use the KOP frame? It seems like it would be lighter than 8020. Maybe not.
I like the gearbox. Good luck!
Collin Fultz
Unread 30-01-2006, 16:50
AKA: Rebekah Olson
FRC #1918 (Packman)
Team Role: Student
I think the reason why is because the team we originally started working with used the 8020, and we find it easier to connect our diffrent things we need to it. Not to mention, we are a rookie team, and we wanted something strong, easy to work with, and we were pressured to use it.
Unread 30-01-2006, 17:14
mpob's Avatar
mpob mpob is offline
AKA: Mike OBrien
#1511 (Rolling Thunder)
mpob will become famous soon enoughmpob will become famous soon enough
Looks good! Your team is off to a really good start!
Keep up the hard work!
--Mike
Roll Strong!
Mentor Team 1511 - Rolling Thunder!
Unread 30-01-2006, 17:16
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
FRC #5507 (Robotic Eagles)
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
A bit of advice:
The radio doesn't really need to be mounted up high like you have it. The radios are very powerful, and mounting it with the rest of your electronics will decrease the amount of wire you need to run and make one less element you need to worry about breaking.
Unread 30-01-2006, 17:23
AKA: Rebekah Olson
FRC #1918 (Packman)
Team Role: Student
They just decided to tape it up there, because it was an easy place to put it, and we take it apart every night.
Unread 30-01-2006, 17:27
coldabert's Avatar
coldabert coldabert is offline
The Dude
FRC #0888 (Robotiators)
coldabert is a glorious beacon of lightcoldabert is a glorious beacon of lightcoldabert is a glorious beacon of lightcoldabert is a glorious beacon of lightcoldabert is a glorious beacon of light
Send a message via AIM to coldabert
Originally Posted by Greg Marra
A bit of advice:
It is generally a good idea to keep the radio antenna vertically oriented.
Unread 30-01-2006, 17:38
occra 23.
AKA: ryo
None #1481
really? why is that? up high with less interference i get but why vertical?
Unread 30-01-2006, 17:40
Gdeaver Gdeaver is offline
FRC #1640
Eliminate the spaghetti wiring. Told our team same thing on Sat.
Unread 30-01-2006, 17:52
Murf the Smurf's Avatar
Murf the Smurf Murf the Smurf is offline
FRC #1706 (IOWNYA)
Murf the Smurf is on a distinguished road
Last year was the first year for our team and we found that using zip ties to hold wires that ran to similar components was the easiest way to organize your wiring
Nerd Just Doesnt Describe It....
Team 1706
Unread 30-01-2006, 17:57
the beam pattern of the antenna looks like a classic doughnut , with the antenna poking up the center of the hole.
Off the top and bottom ends of the antenna you get no energy at all, so having the antenna horizontal means there are two blind spots on your coverage.
Unread 30-01-2006, 18:00
BTW, this thread raises an interesting question: what is the real 'bare minimum' for a robot this year.
If you go though all the rules, then what is the robot required to have?
the team number and name, the flag...... is anything else really required?
could you have a blob of silly putty with the flag stuck in it, with your team number on all sides, and pass inspection?
Unread 30-01-2006, 18:03
devicenull devicenull is offline
Robot? We need a robot?
Rookie Year: 1234
devicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nice
You *need* the backup battery too. Although without the RC, I don't exactly know where you would connect it. Aren't the team color LED's required too?
Unread 30-01-2006, 18:42
FRC #1706 (IOWNYA)
Do you have any plans to score points or are you planing on just defending goals and pushing balls in if you get lucky?
Team 1706
Unread 30-01-2006, 19:51
Andy A. Andy A. is offline
Getting old
FRC #0095
The RC, radio, backup battery, main battery, main breaker, breaker block or other associated support wiring, flag mount, and team numbers. Also, you would have to plug in your OI to enable the RC, or it would just stay disabled and the field software wouldn't know if there were 6 teams or 5 teams. This would probably be a pain in the scoring teams you know what.
These are the bare minimum things that you would need to pass inspection per the rules. A head ref might decide that you need to at least have a frame or something to bolt all that down to though. So toss in a piece of plywood.
-Andy A.
pic: River Rage 9 pic JohnBoucher Extra Discussion 2 30-10-2005 14:43
Using a computer to control the pic mikesown Programming 6 13-09-2005 19:13
Linux and new microcontollers. djcapelis Programming 48 29-01-2005 00:26
Learning PIC C Adam Collet Programming 18 19-10-2003 19:36
