Go to Post They're just dots. You can get them back. - Brandon Martus [more]
Go Back   Chief Delphi > Technical > National Instruments LabVIEW and Data Acquisition > LabView and Data Acquisition
Unread 30-01-2006, 18:01
Jon Anderson's Avatar
Jon Anderson Jon Anderson is offline
Jon Anderson is a glorious beacon of lightJon Anderson is a glorious beacon of lightJon Anderson is a glorious beacon of lightJon Anderson is a glorious beacon of lightJon Anderson is a glorious beacon of light
Send a message via AIM to Jon Anderson
Dashboard Program Question
In the dashboard program provided by innovationFIRST, I don't know how to modify it so that the outputs for the pwms on the screen can be something different. By default they are on pwms 1 and 2, but those are being used for the camera. Specifically we are looking to use pwms 3 and 4 as the outputs.
So, does anyone know how to modify the program so we can see different outputs?
Unread 31-01-2006, 01:47
Danny Diaz's Avatar
Danny Diaz Danny Diaz is offline
Smooth Operator
AKA: FrankenMentor
None #0418
Danny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond repute
Send a message via AIM to Danny Diaz
Re: Dashboard Program Question
You're asking in the wrong thread. To my knowledge the dashboard program provided by InnovationFIRST is not modifiable. The Dashboard provided by National Instruments run in LabVIEW IS modifiable and was designed to be customized for your specific use-case. If you have questions about the LabVIEW Dashboard, then this is your forum. If not, I recommend the Innovation FIRST Dashboard forum.
-Danny
Danny Diaz
Former Lead Technical Mentor, FRC 418
Dashboard port question patTeam241 Programming 5 16-02-2005 02:23
How About A Palm Dashboard Program? archiver 2001 0 24-06-2002 00:52
Dashboard Output Question jnossen Technical Discussion 5 02-02-2002 19:52
