Go to Post Now, everyone knows that Oompaloompas are like bunnies in that they have an insatiable desire to multiply, and the same can be said with Michigan teams (with all due respect) which are currently multiplying and filling that hand-shaped democratic kingdom with their honorable number. - Eugenia Gabrielov [more]
Unread 30-01-2006, 18:47
magical hands magical hands is offline
Jigar Patel
AKA: Jigar Patel
FRC #2185 (Etobicoke CI)
magical hands is on a distinguished road
Post Steps to make cam work?
- Made the cam mount assembly
- Attached the cam to robot
- Cam works fine
- I load kevin's default code into the Controller
- In I/O window i get "CR" (What does that mean?) It keeps repeating "CR"
- Once i press reset button onto the robot in I/O window i see "RM" (what does that mean?)
How i set the cam up
- I connected my pan to pwm01
- connected my tilt to pwm02
- I give power to my cam throught pwm03
- Connected my TTL (Mini chip) on to the controller where it says TTL
Questions
1) What should my next step be to make my camera work?
2) When i get the values for Red, Green and Blue through GUI? How can i turn it so i can put this colour value into my code? and where and how can i put this colour value into my code?
Thank You Very Much
Unread 30-01-2006, 18:57
devicenull devicenull is offline
Robot? We need a robot?
Rookie Year: 1234
devicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nice
Re: Steps to make cam work?
Disconnect your laptop from the camera itself.. it doesn't know if it should be talking to you or the robot controller.
You do not have to change the code to track the target. You may want to calibrate the camera to make it track better, but that is well documented in the CMUCam2 Workbook at http://kevin.org/frc/
Unread 30-01-2006, 19:03
Jigar Patel
AKA: Jigar Patel
I did disconnect the link between camera and computer, but same problems.
1) when i first did it their was nothign showing up in I/O window however after reading the text files i figured out that you have to change the port values by commenting and uncommenting.
2) After i did that, some stuff started to show up in I/O window for e.g. "CR" repeating itself, so i chose to press reset button on controller and "RM" showed up and than "CR" again repeating itself.
How are you guys connecting your camera. Also, how did you guys make ur camera to show values in I/O window? It would be really helpful if someone can briefly make it clear. Thanks
Unread 30-01-2006, 19:46
bush's Avatar
bush bush is offline
AKA: Aaron
FRC #0710 (Pine Crest School)
bush has a spectacular aura aboutbush has a spectacular aura about
Send a message via AIM to bush
The camera itself has 4 connections:
1) PWM cable - Power In (camera) to PWM Out (RC)
2) PWM cable - Pan Servo to PWM Out (RC)
3) PWM cable - Tilt Servo to PWM Out (RC)
4) PWM cable - RS232 3pin (camera) to TTL232 adapter to TTL port (RC)
If you want to view output on your computer, connect your computer's serial port to the Program port on the RC. Open the Terminal window in IFI Loader, and then you can view output.
Unread 30-01-2006, 20:51
That sounds like the Robot Controller is sending its camera communication to the program port instead of the TTL port. You've apparently commented/uncommented the wrong lines. Kevin's code should work just fine without modification.
Unread 30-01-2006, 21:01
Jigar Patel
AKA: Jigar Patel
I did but all i see is <IFI> nothing more than that? like the I/O window is completely blank. I don't see any messages in I/O so how can i troubleshoot such problem? What are the possible mistakes.
Unread 30-01-2006, 21:50
If all you get is the IFI> prompt, your RC is apparently not starting up the user program. Is it communicating properly with the OI?
Unread 31-01-2006, 17:43
Jigar Patel
AKA: Jigar Patel
my I/O works fine with other codes. I don't know y it doesn't work with camera code?
When to leave that first tech job? Morenoh149 Career 4 07-10-2005 00:40
QUESTION OF THE WEEK!!! archiver 2000 14 24-06-2002 00:22
Who knows how the motors [I]really[/I] work? Wetzel Chit-Chat 5 13-02-2002 21:50
