Go to Post First, corndogs and now cowbells... when will you make the pain stop, Frank?!?!?! - barn34 [more]
Unread 30-01-2006, 19:49
EricWilliams EricWilliams is offline
FRC #2039 (Rockford Robotics)
EricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of light
Standard Joysticks
2 years in a row now we've had problems with the standard joysticks in the kit of parts. Last year one joystick had no X-Axis control, the potentiometer was dead. This year every time we move the sticks, we have to re-adjust the trim, because the potentiometer is too loose. We're going to get some new joysticks, does anyone have any ideas on a good one?
Unread 30-01-2006, 20:00
SoftwareBug2.0's Avatar
AKA: Eric
FRC #1425 (Error Code Xero)
Re: Standard Joysticks
My team's first year, we just disabled the trims and made it so that they couldn't move at all. I know that this isn't what you're hoping for, but it might help you in the mean time.
Unread 30-01-2006, 20:01
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Buy a pre-2004 pair off a defunct team. We're still using them.
From what I've heard, analog joysticks are really hard to find these days. I wish you the best of luck.
Unread 30-01-2006, 20:08
Another awsome idea from Astro... you're my hero man. We still have a few pre-2004 joysticks lying around somewhere, which we definitely might use. The only problem with new/old joysticks... we'll have to find the pinout diagrams .
Unread 30-01-2006, 20:22
AKA: Eric
I may be mistaken, but I believe the pinout should be the same except that pins that go to buttons that don't exist on the old joysticks won't do anything.
Unread 30-01-2006, 21:10
AKA: Jamie Bliss
They're identical. The D-Pad/POV hat on the new sticks actually hooks up to an analog channel.
On the old sticks, you have:
  • p?_x
  • p?_y
  • p?_wheel
  • p?_sw_top
  • p?_sw_trig
Everything else is wide open. (Just don't screw up you're sticks to badly, as they're hard to replace.)
Unread 30-01-2006, 22:50
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Have you considered customizing the KOP joysticks? Most of their issues can be solved mechanically. By either creating custom handles or adding/altering the springs in the base/handle itself, you can also stiffen it up. I discussed customizing the either the KOP joysticks of the old CH Flightsticks in these two posts:
http://www.chiefdelphi.com/forums/sh...1&postcount=13
http://www.chiefdelphi.com/forums/sh...92&postcount=5
I've gotton so many requests for more information about our team's 2005 operator interface, I think I should just write a white paper about customizing joysticks. But that might have to wait until after the ship date though...
Art Dutra IV
世上无难事,只怕有心人.
Unread 30-01-2006, 23:31
kaszeta's Avatar
kaszeta kaszeta is offline
FRC #0095 (Grasshoppers)
kaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of light
I'll second this recommendation. CH Flighsticks (what they used in previous years) are frequently sought after items. I'm thinking of cleaning up some of our team's ancient crusty ones (and I mean crusty!) and seeing if we can trade them to newer teams.
Ebay is still a decent resource for these, as well as some of the more rare gameport devices such as Flightstick Pros (with a full hat on them like the current sticks, but still ambidextrous), CH Throttles, Pedals, etc. We're probably going to use a CH Throttle and Flightstick Pro combo this year, although we also have a handmade throttle that's worked well in the past (made from a pressure cylinder and transducer, actually).
Unread 09-02-2006, 14:09
samson234's Avatar
samson234 samson234 is offline
Head Lathe Operator
AKA: Sam Harding
FRC #0234 (Cyberblue)
Team Role: Driver
samson234 will become famous soon enough
This may be a stupid question, but why is it FIRST changed to a different joystick? I have driven with both new and old, and the old joysticks are far superior? Also, why is it they give us two right handed joysticks? Is FIRST trying to phase out left handed drivers?
"It takes a little over an hour."
Unread 09-02-2006, 14:22
Stupid question or no, the answer is easy. The new joysticks are available; the old ones are not.
Unread 09-02-2006, 14:24
kaszeta's Avatar
The answer is simple enough: the company that made the old joysticks (CH Flightsticks) stopped making them. FIRST can't supply what they can't get.
Unread 09-02-2006, 15:01
DjAlamose's Avatar
DjAlamose DjAlamose is offline
AKA: Teh Albie
FRC #0279 (Tech Fusion)
DjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to behold
Send a message via AIM to DjAlamose
If I was you I would just use ps2 or x-box controllers. Most good drivers play video games of some kind and what better to give them than something that they are used to?? Plus you will have all sorts of options with what you can do, 10 buttons and two analog sticks.
WHAT TIME IS IT????? 279!!
2006 GLR Safety Award (2nd year in a row)
2005 National Xerox Creativity Award
2005 National Curie Quarter Finalist w/ 1126 and 180
2005 Buckeye Regional Champs w/ 67 and 274
2005 Buckeye Regional GM Industrial Design Award
2005 Buckeye Regional Safety Award
2005 GLR Quarter Finalist
2005 GLR Xerox Creativity Award
2005 GLR Safety Award
2004 Nationals Curie Division Finalist
2004 GLR Champs
2004 Buckeye Delphi Driving Tomorrow Award
2004 Buckeye Quarter Finalist w/ 1001 and 869
2003 GM Industrial Design Award GLR
2001 National Champs
Unread 09-02-2006, 20:39
computer411's Avatar
computer411 computer411 is offline
AKA: Chris Deslandes
FRC #1699 (Robocats)
computer411 is on a distinguished road
I hear you my friend. We were a brand new team last year and were fed up with the joysticks. So we wwent to CH products OEM Department that makes industrial joysticks. They still sell models that use 100k computer potentiometers. The only drawback is they are slightly expensive and you have to wire them into the OI yourself, no preassembeled connectors.
We choose to go to the Moon in this decade and do the other things, not because they are easy, but because they are hard. --JFK
Team 1699 - winners of the Play of the Day award at The Bash at the Beach!
Team Rookie year: 2005
FIRST Robots rookie year: 2004
Unread 10-02-2006, 00:29
TimeOut's Avatar
TimeOut TimeOut is offline
AKA: Sean Kelly
FRC #0499 (The Toltechs)
TimeOut is on a distinguished road
We are looking for a standard joystick that has rudder control built in. But finding standard gameport joysticks is getting difficult.
Anyone have any ideas for a knob that is self centering? The idea is to be able to turn the knob and then release it so it will move back to neutral. (rotation control). I was thinking of maybe a Jog control from an old VCR but that's even getting hard to find!
Sean
Unread 12-02-2006, 01:37
Dillon Compton Dillon Compton is offline
Jack-Of-All-Trades
FRC #1391 (Metal Moose)
Dillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud of
Send a message via AIM to Dillon Compton
Hey all,
I'm on a computer at school right now so I dont have the web address, but when I was researching joystick options for my team earlier this year I found an online supplier of dexxa gameport joysticks (after some significant digging through froogle), w/ hat and 5 buttons, I believe, for about ten dollars each. We ended up going with a local supplier for gameport joysticks, and havent purchased or used these dexxa's yet(but we are planning on purchasing 4 or 5 so that we have some stockpiled...). Additionally, I contacted CH systems and their newer, USB sticks use the same model of 100k potentiometer that their gameport sticks did. If I am not completly mistaken, these new CHs should then be fairly easily moddable to a gameport output with our friend the db-15 solder cup and some wire + basic wiring/soldering skills.
I'll post the link to the Dexxa stick supplier in the morning, so stay tuned.
-Dillon Compton
www.metalmoose.com
Buying Joysticks computer411 Control System 3 14-06-2005 12:44
2004-2005 Joysticks kjohnson Control System 3 11-04-2005 23:39
number of joysticks Waste General Forum 21 27-01-2005 15:04
Sophisticated Joysticks WebWader125 Control System 3 03-12-2004 15:33
need joysticks! Tom Bottiglieri General Forum 14 24-02-2004 09:36
