Go to Post when you think you are here to compete against other teams, thats when bad things start happening... - KenWittlief [more]
Unread 30-01-2006, 18:30
Freddy Schurr Freddy Schurr is offline
FRC #0204
Freddy Schurr has a reputation beyond reputeFreddy Schurr has a reputation beyond reputeFreddy Schurr has a reputation beyond reputeFreddy Schurr has a reputation beyond reputeFreddy Schurr has a reputation beyond reputeFreddy Schurr has a reputation beyond reputeFreddy Schurr has a reputation beyond reputeFreddy Schurr has a reputation beyond reputeFreddy Schurr has a reputation beyond reputeFreddy Schurr has a reputation beyond reputeFreddy Schurr has a reputation beyond repute
Painting PVC, HELP!!!!
Painting PVC
I need to paint PVC pipe for our pit display. Anyone know how I should do this? I thinking of sandpapering the pipes to get a rough finish and take off the number and lettering and also primer it and then paint with spray paint.
Anyone else have any ideas or it my idea good?
Unread 30-01-2006, 18:33
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Painting PVC, HELP!!!!
That sounds good to me. Make sure to wipe it off after you sand it or it will be covered in dust. Also, I believe they make paint specifically for plastic that doesn't require primer, but I've never tried it.
Unread 30-01-2006, 18:37
Cyber Punk 234's Avatar
Cyber Punk 234 Cyber Punk 234 is offline
John Carter
AKA: John
None #0234 (Cyber Blue)
Team Role: Webmaster
Cyber Punk 234 is on a distinguished road
Send a message via AIM to Cyber Punk 234 Send a message via MSN to Cyber Punk 234
Yea they do have paint for plastic,you can get it at a local home depo or lows, works well. Really if you go that wrought i don't think sanding it will be necessary. Its worth a try.
Member of FRC team 234
Mentor to FVC team 56
Team Website
Myspace
Unread 30-01-2006, 18:43
KyleGilbert45's Avatar
KyleGilbert45 KyleGilbert45 is offline
KyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant future
I would try Krylon Fusion .
Unread 30-01-2006, 18:54
ahecht's Avatar
ahecht ahecht is offline
'Luzer'
AKA: Zan
Be careful when sanding PVC -- it tends to scratch very easily. Use a very fine grit sandpaper (on the order of 800 grit).
A better solution would be to completely clean the PVC with soap and water and spray it with a primer designed for plastics (you should be able to find one in the spray paint section of Home Depot or Lowes). I've even seen spray primers sprcifically designed for PVC.
After your primer is on, you want to spray in two coats -- a so-called dry coat, which spreads some color over all the PVC but still allows the primer to show through, and a wet coat, which covers everything until the surface looks wet and shiney.
Zan Hecht
Unread 30-01-2006, 19:07
Conor Ryan Conor Ryan is online now
I'm parking robot yacht club.
FRC #4571 (Robot Yacht Club)
Conor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond repute
I have a few ideas:
Try using the primer paint for glueing PVC and Applying a coat of that, then spray paint over that. My idea is that since the primer creates a surface for the glue to bond to, why can't it create a surface for the paint to bond to?(maybe i'm wrong) If you have some sitting around you my want to try it.
Another alternative, since 800 grit sandpaper isn't the easiest thing to come by, you may want to try a Very Fine Emory Cloth/Paper or Steel Wool.
Unread 30-01-2006, 20:34
FRC #0204
Does anyone know how I can remove the lettering and numbers off the PVC pipe? Just asking!
Unread 30-01-2006, 20:58
Andrew Blair's Avatar
FRC #0306 (CRT)
As was said, emery paper or any fine abrasive should take it off. In my experience.
-Sir Francis Bacon
-Albert Einstein
Unread 30-01-2006, 21:38
Gdeaver Gdeaver is offline
FRC #1640
Clear PVC primer. It's just solvent. A little on a rag will clean it up. Very flammable. Should use in a well ventilated area or outside with a respirator
PVC Tanks Leav Pneumatics 13 15-01-2005 15:21
Trouble finding flat pvc sch 40 PVC caps Gdeaver Kit & Additional Hardware 8 12-01-2005 14:21
45 degree PVC angle fittings: which? archiver 2001 2 23-06-2002 22:53
Goal...PVC is loose... archiver 2001 7 23-06-2002 22:38
pvc piping gthakore Rules/Strategy 3 09-01-2002 21:27
