Go to Post There are no guarentees in life. Cherish what you have while you have it. None of us knows what tomorrow will bring. - KenWittlief [more]
Unread 30-01-2006, 13:45
Wynlyndd Wynlyndd is offline
FRC #1865
Wynlyndd is an unknown quantity at this point
IFI> ?
When uploading the fri_camera or fri_camera_s to the controller board, we never see the "Searching..." The terminal window is blank.
I believe checked with hyperterm and all we see onscreen is IFI> .
We are unclear what types of diagnostic steps to take here out to test some default code before attempting to write our own. We'd like to see the camera performing some default tracking and we are having issues with Labview at the moment.
Any ideas?
Unread 30-01-2006, 13:48
Eldarion's Avatar
Eldarion Eldarion is offline
Electrical Engineer / Computer Geek
AKA: Eldarion Telcontar
no team (Teamless Orphan)
Eldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond repute
Send a message via AIM to Eldarion Send a message via Yahoo to Eldarion
Re: IFI> ?
Any ideas?
Jus a few basic troubleshooting questions:
Are the lights on on the camera? If so, which ones?
Do you have a backup battery installed?
Did you hook up the serial cable and TTL converter between the camera and the RC?
CMUCam not working? Tracks sporadically? Try this instead: http://www.falconir.com!
PM me for more information if you are interested (it's open source!).
Want the FIRST Email blasts? See here: http://www.chiefdelphi.com/forums/sh...ad.php?t=50809
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
If it's falling apart it's a mechanical problem. If it's spewing smoke it's a electrical problem.
If it's rampaging around destroying things it's a programming problem.
"All technology is run on 'Magic Smoke' contained within the device. As everyone knows, whenever the magic smoke is released, the device ceases to function."
-- Anonymous
I currently speak: English, some German, Verilog, x86 and 8051 Assembler, C, C++, VB, VB.NET, ASP, PHP, HTML, UNIX and SQL
Unread 30-01-2006, 13:50
Pat Fairbank's Avatar
Pat Fairbank Pat Fairbank is offline
Circuit Breaker
Pat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond repute
Send a message via MSN to Pat Fairbank
Re: IFI> ?
One more question:
Do you have the OI hooked up to the RC (either wirelessly or by tether)?
Patrick Fairbank
Team 254 | Mentor (2012-)
Team 1503 | Mentor (2007-2011)
Team 296 | Alumnus (2001-2004) | Mentor (2005-2006)
patfairbank.com
Unread 30-01-2006, 21:55
Terry Sherman's Avatar
Terry Sherman Terry Sherman is offline
Mentor -- Software
FRC #0093 (NEW Apple Corps.)
Terry Sherman is an unknown quantity at this point
Re: IFI> ?
We've had this problem as well with all our other code in place with the camera. The solution to our problem was to use IFI Loader 1.1.0 dated 1/26/2006. I think this version allows writing of the entire memory available in the RC (Our code was just a little bit over 25% available memory when we started encountering the problem and the new processor for 2005 has 4x the flash the previous (2005) rc had.)
http://www.ifirobotics.com/rc.shtml
-Terry
Unread 01-02-2006, 21:17
Oumonkey's Avatar
Oumonkey Oumonkey is offline
Master of the If statement
AKA: Josh Tyus
FRC #1555 (Pulse)
Oumonkey has a spectacular aura aboutOumonkey has a spectacular aura about
Re: IFI> ?
I have the exact same problem, so I guess I don't have to start a thread now...
So please help me, I don't want to have to dispose of a body again...
And to answer these question The only light on for me is the green The backup battery is installed, I guessing you mean the one of the rc controller if not that may be my problem, And yes I am using the tll converter, and yes its tethered.
Also, It was working but the tilt would run away, so I went into tracking.h and changed it, should I have tried tacking.c?, and after that it wouldn't work. I have pwm01 and pwm 02 to the controller blocked out of the code, and everytime I load the code, it doesn't work and I just get the ifi> thingy.
Please help me, I'll give TWO cookies! not just one but TWO!!!
Thanks in advance, and sorry for hijacking your thread, I just didn't want to make a second thread since our problems sound similar.
THANK YOU!!!!!
:breaths:
