Go to Post I personally hope they change the terrain of the playing field ... if only to "level" the playing field. - Daniel_LaFleur [more]
Unread 30-01-2006, 20:46
itzrobz itzrobz is offline
None #0333
itzrobz is an unknown quantity at this point
Re: Newbie Needs Help
Originally Posted by Alan Anderson
Don't hook up both the DB9 cable to the computer and the "PWM" communication cable to the RC at the same time. They'll interfere with each other. Only use the computer if you're controlling the camera with the computer, and only use the cable to the RC if you're controlling the camera with the RC.
Ohhhh, I understand now. Another stupid question:
I can hook up the RC to the computer and use the "PWM" communication cable to connect to the camera (from the RC) at the same time right?
Thanks
Unread 30-01-2006, 22:29
devicenull devicenull is offline
Robot? We need a robot?
Rookie Year: 1234
devicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nice
Originally Posted by itzrobz
The default camera code is the Streamlined version of the camera right? We did everything correctly, according to you and the manual. I don't know whats wrong with it. We will try to download the streamlined version into the camera when we get a chance.
Just one question, Is the terminal window supposed to say "Searching..." even if the camera is not properly configured, with the focus, to search?
thanks for your help
Either the bells and whistles or streamlined code will work.. not the default code from IFI's web site.
You may want to upgrade your IFI loader, and make sure that works.
Unread 30-01-2006, 22:33
None #0333
The IFI loader we have is v1.1.0 and we downloaded the camera codes from Kevin's website yesterday.
Unread 31-01-2006, 16:43
sT4s1657 sT4s1657 is offline
FRC #1657
sT4s1657 is an unknown quantity at this point
I have the same problem with kevin's program (frc_camera_s and frc_camera)
so i tried the FRCcode2.4(something like that) and it work fine for a while but now when i tried to get this to work with the gyro and the accelometer the RC got stock, and now i cant get the camera working again....
Unread 04-02-2006, 10:55
None #0333
I still need help. The camera is still not responding to the code. HELP!!!
Thanks in advance.
i am a newbie at the camera Capozzi Programming 3 28-01-2006 10:56
AHHH! I'm a lost newbie! I need help! lkdjm Programming 8 28-01-2006 08:41
quick question as a newbie Kristian Calhoun General Forum 8 26-10-2005 15:15
spur gears & fishers ...newbie question... archiver 2001 3 23-06-2002 23:17
Total newbie to the Chairman's Award A. Leese Chairman's Award 4 06-06-2001 22:03
