Go to Post I think this is the forest that ChiefDelphi often misses as we're picking the branches off every tree. - Libby K [more]
Unread 27-01-2006, 18:41
NASAbound1636 NASAbound1636 is offline
clueless???
AKA: joe
FRC #1636 (Reds Robotics)
NASAbound1636 is an unknown quantity at this point
fickle autonomous
In autonomous mode i have entered the program and all errors are fixed but one, a syntax error. when i call it up it is 2 lines after all code is finished, nothing is there, how do I fix this phantom error?
Unread 27-01-2006, 19:05
Eldarion's Avatar
Eldarion Eldarion is offline
Electrical Engineer / Computer Geek
AKA: Eldarion Telcontar
no team (Teamless Orphan)
Eldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond repute
Send a message via AIM to Eldarion Send a message via Yahoo to Eldarion
Re: fickle autonomous
It is most likely a missing end bracket, or less likely, you forgot your semicolon on the last statement.
CMUCam not working? Tracks sporadically? Try this instead: http://www.falconir.com!
PM me for more information if you are interested (it's open source!).
Want the FIRST Email blasts? See here: http://www.chiefdelphi.com/forums/sh...ad.php?t=50809
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
If it's falling apart it's a mechanical problem. If it's spewing smoke it's a electrical problem.
If it's rampaging around destroying things it's a programming problem.
"All technology is run on 'Magic Smoke' contained within the device. As everyone knows, whenever the magic smoke is released, the device ceases to function."
-- Anonymous
I currently speak: English, some German, Verilog, x86 and 8051 Assembler, C, C++, VB, VB.NET, ASP, PHP, HTML, UNIX and SQL
Unread 29-01-2006, 04:33
LightWaves1636's Avatar
LightWaves1636 LightWaves1636 is offline
is all over it.
AKA: Sarah Le
LightWaves1636 is a splendid one to beholdLightWaves1636 is a splendid one to beholdLightWaves1636 is a splendid one to beholdLightWaves1636 is a splendid one to beholdLightWaves1636 is a splendid one to beholdLightWaves1636 is a splendid one to beholdLightWaves1636 is a splendid one to behold
Send a message via AIM to LightWaves1636 Send a message via Yahoo to LightWaves1636
hehe and you were right, again if LaBar or Jake is avalible, try them first to make things faster because programming is easier to troubleshoot in real life and I believe I have enough knowledge to trouble shoot programming also.
Unread 30-01-2006, 15:43
clueless???
AKA: joe
To give an Idea of the problem i'm having, when i compile it the following message appears: (note: it is typed exactly as seen after this line)
Skipping file. There is no tool to process the file with the given suffix.
Skipping link step. Not all sources built successfully.
BUILD FAILED: Mon Jan 30 13:38:58:2006
if you can translate this and fix the error hypothetically plz let me know how!
-me
Unread 30-01-2006, 16:12
Jared Russell's Avatar
Taking a year (mostly) off
Do all your source files end in .c?
IE no .cpp, .C, .cxx, .cc or anything else?
Unread 30-01-2006, 17:16
clueless???
AKA: joe
yes it's titled static output.c
Unread 30-01-2006, 18:02
clueless???
AKA: joe
-me
Ignore this, I fixed That problem, but now a new one pops up and it says this:
Make: The target "C:\Documents and Settings\jeffco\Desktop\autonomous.c\static output.o" is out of date.
Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8722 "static output.c" -fo="static output.o" /i"C:\Documents and Settings\jeffco\Desktop\012406c" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
C:\Documents and Settings\jeffco\Desktop\autonomous.c\static output.c:55:Error: syntax error
BUILD FAILED: Mon Jan 30 15:55:19 2006
there are 3 kinds of people in the world. those who can count, and those who can't.
Did you know that 4/3 of all people have trouble with fractions?
there are 10 kinds of people in the world, those who understand binary, and those who don't.
If you have 1 of these and you will let me use it then pm it to me
Unread 30-01-2006, 18:28
CronosPrime1 CronosPrime1 is offline
FRC #0321
CronosPrime1 is an unknown quantity at this point
Well, it seems there is an error at line 55. Again, check for missing semicolons or brackets.
Unread 30-01-2006, 18:34
clueless???
AKA: joe
the thing is, there is NOTHING on line 55 or line 54 or line 56!
Unread 30-01-2006, 18:37
Dave Scheck's Avatar
Dave Scheck Dave Scheck is offline
Dave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond repute
What about 53, 52, or 51? A syntax error that shows up on a line that doesn't have anything is usually a missing bracket, parenthesis, or semicolon. Your problem isn't actually at line 55, but the compiler thinks it is because your syntax from a previous line is invalid.
Unread 30-01-2006, 18:38
clueless???
AKA: joe
I shall check.
Unread 30-01-2006, 18:42
clueless???
AKA: joe
all brackets, parenthesis, and semicolons are accounted for. any other possibilities?
Unread 30-01-2006, 19:40
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
The phase of the moon, the tides, the compiler's horoscope...
There are times when the compiler will just spit at you and throw semingly random syntax errors.
Open the file in notepad, and check to make sure there's nothing there.
Look for syntax errors at the previous code line.
Contact someone and have them check.
Unread 30-01-2006, 20:39
Kevin Watson's Avatar
La Cañada High School
FRC #2429
If I remember correctly, the tools choke if your path or file name have an embedded space. Move your project off your desktop to something like c:\code and rename your source file(s) static_output.c, etc.
-Kevin
Kevin Watson
http://kevin.org
Unread 30-01-2006, 23:13
You probably did this, but go to Project->Clean then try building.
I also don't know how tolerant MPLab is of alternate line break settings - did you by chance write your code on Linux or a Mac?
Lastly, try selecting lines 54-56 together and deleting them. Maybe there's a hidden character somewhere (maybe way off the right margin?).
EDIT: oh, and make sure any strings you use have beginning and ending quotes - MPLab has given me errors in weird places when I've forgotten to close a string.
A Warning to Human Players During Autonomous The Lucas General Forum 21 07-04-2005 02:29
Setting Autonomous Settings from OI Tom Saxton Programming 15 27-03-2005 11:45
Despite what IFI says, you can configure autonomous from OI... TedP Programming 19 31-03-2004 10:09
autonomous mode problem on field Chris_C Programming 17 26-03-2003 19:11
