Go to Post A quote from the Southern California Regional Visitors guide: "If you are having problems the FIRST thing to do is ask your neighbor for help" - ChrisH [more]
Unread 31-01-2006, 10:51
Re: Manual Velocity PID, anyone successful?
For anyone who has utilized a differential term in their control loop, did you use the timing of the default routine or set up an timed interrupt driven differential calculation?
I know the default code loops at ~26ms, but is its rate of repitition constant enough to house the differential term calculation?
Unread 31-01-2006, 11:12
Jared Russell's Avatar
Taking a year (mostly) off
I find that the default 39Hz main loop is fast enough for any feedback applications in FIRST, and it is fairly well timed as long as you don't go overboard on the interrupts.
Besides, the closer together your differential term calculations are, the less resolution you have in them (i.e. you couldget 5-10 "ticks" difference on a 100Hz loop but the same rate would produce 12-25 on 39Hz).
Unread 31-01-2006, 12:50
Joel J's Avatar
Joel J Joel J is offline
do you..
Originally Posted by Abwehr
You can replace the line:
control /= 4;
with:
control >> 2;
But that's about it - otherwise it works.
if control can be negative, then a right shift can have a disastrous effect! mcc18 v2.4 does NOT shift in 1's for a negative number. Instead, it treats all numbers as unsigned.
For example,
int control = -16;
control = control >> 2;
After that snippet, you'd expect control to be -4, but in actuality its 16380. Quite different.
Joel Johnson
RAGE (173) Alumni, 1999-2003
Unread 31-01-2006, 13:27
kaszeta's Avatar
kaszeta kaszeta is offline
FRC #0095 (Grasshoppers)
kaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of light
For example,
int control = -16;
Indeed, our team learned that lesson the hard way....
Unread 31-01-2006, 15:34
For example,
int control = -16;
Wow - I definately would have thought that a shift would extend the sign.
I guess I should have RTFM.
Unread 31-01-2006, 20:51
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Originally Posted by Rick TYler
Yeah, but, writing PID from scratch is hard. Does anyone have some sample code I could show to our student programmers?
The Navigation code Kevin made for last year's robot has PID in it.
And it's pretty easy.
error = current - target
integral += error
derivative = error - prevError
output = Kp * error + Ki * integral + Kd * derivative
prevError = error
(The implementation details are left to the reader )
What Makes a FIRST Team Successful? Dr.Bot General Forum 17 23-12-2005 08:45
PID cmd_drive can't drive straight? gnormhurst Programming 4 18-02-2005 01:54
2005 Autonomous Scripting Manual Anthony Kesich Programming 31 17-02-2005 17:30
**FIRST EMAIL**/Important 2005 Competition Manual Information Sscamatt FIRST E-Mail Blast Archive 1 06-01-2005 18:50
