Go to Post You can sometimes step outside the box if you have properly thought through the question. - Jim Zondag [more]
Unread 31-01-2006, 16:07
Arkorobotics's Avatar
Arkorobotics Arkorobotics is offline
Robots!
AKA: Ara Kourchians
FRC #0589 (FalkØn)
Arkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to behold
Send a message via AIM to Arkorobotics
Air Conditioning tube legal?
Does anyone know if air conditioning tubes are legal? Just like the ones for the center goal tubes.
2007 Rockwell Automation Innovation in Control Award winners (Southern California Regional)
Crescenta Valley High School Team 589
http://www.arkorobotics.com My Blag
3.141592653589793238462643383275902884197 <- Current memorization of Pi
Callsign: N6ARA
Unread 31-01-2006, 16:11
GaryVoshol's Avatar
Cogito ergo arbitro
Re: Air Conditioning tube legal?
Why not? They're not electrical, pneumatic, lubricant or adhesive, so you can go through the allowable parts spreadsheet pretty easily. Just recall the ball visibility rule (for the beginning of the match) and the ball release rule (at the end of the match) in deciding how to implement it into your machine.
Unread 31-01-2006, 16:12
Marcel Marcel is offline
The Fool
AKA: BabyFace
FRC #0059 (RamTech)
Team Role: Scout
Marcel is on a distinguished road
Send a message via AIM to Marcel Send a message via MSN to Marcel Send a message via Yahoo to Marcel
Cant tell you off the top of my head. Try serching the manual.
Follow the Parts Use Flowchart on Page 14 of Section 5. (I just did, it's OK as long as it doesn't violate any rules associated with its area for use.)
Unread 31-01-2006, 16:15
Robots!
AKA: Ara Kourchians
FRC #0589 (FalkØn)
I knew it would be legal, It just seemed fishy.. I mean you can make an entire mechanism in a day, no milling of cnc required.. to easy in a way. Whatever. thanks anyway
Callsign: N6ARA
Can the Plane Take-Off? greencactus3 Games/Trivia 113 05-01-2009 11:59
air speed sensor for rc plane Greg Needel Technical Discussion 19 07-10-2005 23:43
Higher PSI in air Tanks Projectchon Pneumatics 8 01-02-2005 15:05
More than two air tanks? Mercutio Pneumatics 6 10-02-2004 16:07
What are pneumatics? Aignam Pneumatics 23 16-10-2002 21:17
