Go to Post There's a fine line between cockiness and confidence. Confidence is one of the major keys to success and happiness in life. As long as one can carefully stay on the right side of the line, staying connfident while remaining humble, and ego can be quite beneficial. - Karthik [more]
Unread 31-01-2006, 16:44
vector023 vector023 is offline
FRC #1168
vector023 is an unknown quantity at this point
Old Breaker Panel
Can our team use the Breaker Panel (power Distribution Center) from last year? It's the all-in-one panel so that 40A and 20A and 30A can be at the same location. Thanks a lot!
Unread 31-01-2006, 16:49
Re: Old Breaker Panel
You know, the rules are very useful--and so is search. Doing a search led me to a reference to the following:
Originally Posted by Manual Section 5
<R54> The EX18-12 Battery, the Main 120 Amp Circuit Breaker, and the Circuit Breaker distribution panels must be connected as shown in the 2006 ( or optionally) as in the 2005 diagrams shown below. The EX18-12 Battery must use the Anderson Connector. The connector must be attached with either the copper SLU-35 lugs provided in the Terminal Supply Bag or appropriate crimp-on lug connectors. The Battery terminals and the connecting lugs must be insulated with shrink tubing and/or electrical tape. You may use additional lengths of #6 red and #6 black wire to reach the panels as needed to make the above connections. The circuit breakers must be readily accessible for inspection and testing at each competition event.
It's legal.
Unread 31-01-2006, 16:51
Jon Jack's Avatar
Jon Jack Jon Jack is offline
VEX Robotics
no team (No Team)
Jon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond repute
Send a message via AIM to Jon Jack
I believe that the GDC clarified in Update #3 that teams can use the IFI Breaker in addition to or in replacement of the breakers provided in the this year.
Team 1538 / The Holy Cows, 2005-2016
Unread 31-01-2006, 16:54
FRC #1168
Thank you very much guys!
Unread 31-01-2006, 16:55
dude__hi's Avatar
dude__hi dude__hi is offline
Now a CSWA
AKA: Cristian Arcega
FRC #0842 (Falcon Robotics)
dude__hi is an unknown quantity at this point
The old breaker panel is legal and so much more useful than this year's although it can take more components than we use....
Powerpoint is a distraction, people use it when they don't know what to say...
2008 FIRST Chairman's Award Winner
Cost Accounting for 2005 breaker panel Peter Matteson Rules/Strategy 0 24-01-2006 14:01
12 volt sensor distribution breaker panel? Uberbots Electrical 3 14-01-2006 23:31
New Model Posted - 2005 Breaker Panel Ed Sparks Inventor 5 01-01-2006 23:25
Breaker Panel Diagnostics dm0ney Programming 4 29-03-2005 19:00
Breaker Panel Gal Longin Electrical 1 13-01-2005 16:01
