Go to Post Great CAD ** work! ** Cardboard Aided Design - philso [more]
Unread 31-01-2006, 16:47
bhk88 bhk88 is offline
bhk88 is a jewel in the roughbhk88 is a jewel in the roughbhk88 is a jewel in the rough
RC Controller Stuck
My team has recently tried to upload our code onto the RC. The first time we tried, everything went well, and the code was responding. The second time, after some revisions of the code, the RC seemed to freeze. The Programming State LED was stuck yellow, even after we redownloaded the code. I searched CD and found that this problem occurred to other teams. When we followed FIRST's instructions on how to correct the "frozen" RC, nothing changed. Does any one have any idea what's wrong. Thanks for your help.
Brett Kassof
Programming Leader
Team 1546
Unread 31-01-2006, 17:46
Zoom's Avatar
Zoom Zoom is offline
Lost User
AKA: Umair Nasir
FRC #0369 (Nuts & Volts)
Zoom is an unknown quantity at this point
Send a message via MSN to Zoom
Re: RC Controller Stuck
do all the steps first told you to do. but when you let go of the prog button dont press the reset button. at this time you should only have the battery led and the prog led on. upload your code and then just press reset. it should fix it.
A Program isnt finished until the Programmer dies...
HELP! Can't Program Robot Controller - LED stays on. sheyna Programming 3 21-01-2006 18:50
Mini-Me robot arm controller Andrew Schuetze Control System 7 19-10-2005 11:07
Stuck sprocket - need advice sanddrag Technical Discussion 20 13-10-2005 12:12
Help On Coding 2K1 Controller GregTheGreat Programming 9 05-12-2003 18:35
serious problem found - robot controller resets when jarred! KenWittlief Electrical 23 19-03-2003 13:30
