Go to Post They know how to make paperweights into other objects, like robot controllers. - Greg McKaskle [more]
Unread 31-01-2006, 20:34
Nitroxextreme's Avatar
Nitroxextreme Nitroxextreme is offline
Relation to Mrs. Steve
AKA: Jon
FRC #1626 (Falcon Robotics ; 190 (Gompei and The Herd))
Nitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to behold
Send a message via AIM to Nitroxextreme
Best type of "pulley" material
My team has decided to use some sort of pulley/tread system to get the balls off the ground and into the hopper.
However, for the distance that we are going for there just are not any standard lengths. We have done some research into the endless belts, but have not found any easy way that we can make them ourselves and have them be strong.
What kind of rubber tube, flat belt, etc. would be easiest to make a custom length and where could this be purchased?
"He needed a chuck norris lesson in FIRST"...."I will give him a round house kick to the face...with gracious professionalism"
Unread 31-01-2006, 20:41
Electrical Engineer
Rookie Year: 1995
Re: Best type of "pulley" material
http://www.chiefdelphi.com/forums/sh...354#post435354
Mike Betts
As easy as 355/113...
Unread 31-01-2006, 21:25
Parker's Avatar
Parker Parker is offline
FRC #1079 (C.R.E.A.T.E.)
Parker is an unknown quantity at this point
My team ran into the same problem. We discovered that the green padding that goes under hard-wood floors had the properties we were looking for. It has a little stretch which will allow it to go around our rollers and has enough friction to lift a ball quickly into a hopper. The only problem is that it is similar to duct tape; if it gets a tear along on a particular side it pulls that strip off. My teammates and I are taking measures to prevent this.
We are attaching the material be using thick thread and some kind of fabric glue ( I'm not exactly sure on the glue). We tested this method and it failed after four members of the team pulled as hard as they could. The test convinced us of the designs integrity.
The material can be obtained from any flooring/tile store.
Unread 31-01-2006, 22:00
CrazyCarl461's Avatar
CrazyCarl461 CrazyCarl461 is offline
Power User
AKA: Carl Agnew
CrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant future
Send a message via AIM to CrazyCarl461
We just got some hollow core round belt from McMaster that has little barbed connectors (sold separately). I was skeptical at first, but it turns out those little guys hold a lot better than they look. It takes some pretty violent tugging to get them back apart again. Also, the plastic and aluminum connectors seem to behave about the same.
My 2011 Build Season Blog
Resistance may be futile, but capacitance has potential!
© All content is protected by the honor system
Unread 31-01-2006, 22:12
Have you found a source for 3/8-inch shaft pulleys for that 1/4-inch round belting?
Why? Oh ... no particular reason...
Unread 31-01-2006, 22:22
DonRotolo's Avatar
Back to humble
FRC #0832
If you want wide flat belting, then consider the stuff that is sold as both non-slip carpet under-padding and as non-slip shelf lining. It is a nylon fiber mesh (kinda like loose window screen) with a coating of rubbery foam-like material along the strands. (Kinda hard to describe, sorry). It's sold in rolls 12" and 24" wide for shelf liner (I got some at "the container store"; I'm sure it's available elsewhere), and rolls and sheets (like, 9' x 12') for under carpets.
The 'belt' is cut to length and the ends are sewn together (yes, needle and thread - choose thread wisely, and space out the stitches from the ends for strength) to make a loop.
The stuff is amazingly strong, and quite grippy, with hardly any stretch.
Good luck, see you in Trenton.
Don
Unread 31-01-2006, 22:36
Power User
AKA: Carl Agnew
I hate to give away all our secrets ... but yes. We went with black acetal idler pulleys from SDP/SI (A 6M 9-03110). All we had to do was drill the centers out to 0.375 and put keyways in the ones we want driven (provided the torque isn't too high). Combine with keyed shaft or steel tube and you are set!
Cheezy Poofs' Wheel Material evolution Technical Discussion 6 18-04-2004 23:11
what type of sensors are good and convenient magical hands Programming 7 04-01-2004 23:04
type of material; conveyor belt Alyssia General Forum 9 10-01-2003 13:06
Illegal material PDonovan Rules/Strategy 13 16-05-2002 16:53
Best material for wheels. Dr.Bot Technical Discussion 0 21-01-2002 23:32
