Go to Post If you water it and nurture it and fertilize it and put it out in the sunlight, it might just grow up to be a big lathe... :) - dlavery [more]
Unread 27-01-2006, 22:59
zachriggle zachriggle is offline
FRC #1940
zachriggle is infamous around these parts
Joystick Ports as Duplex Data Port
Is it possible to not only transmit data through the joystick port, but to also receive it? I understand that this may not (most likely will not, I think I remember reading something along those lines) be allowed during the competition, but it would help immensely for debugging purposes.
My reason for asking is that I want a diagnostic system that will work when the FRC isn't hooked up directly via parallel port, and can't afford (the Team can't) to shell out $100+ on a wireless radio set for the RS232 port.
Unread 27-01-2006, 23:00
Adam Richards's Avatar
Adam Richards Adam Richards is offline
I'm baaaaaaack.
FRC #1902 (Exploding Bacon)
Adam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond repute
Send a message via AIM to Adam Richards
Re: Joystick Ports as Duplex Data Port
Have you looked into hooking a laptop up to the dashboard port?
Unread 31-01-2006, 22:06
DonRotolo's Avatar
Back to humble
FRC #0832
The short answer is no. The four Joystick ports on the OI are inputs to the OI only (with the exception of a small amount of +5 volts coming out of the OI to read the joystick potentiometers).
The Dashboard port is exactly what you are looking for, however.
Don
Unread 31-01-2006, 23:12
Matt Krass's Avatar
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
To be entirely honest, some of them have LED outputs, but that allows a very limited amount of data and you can view the LEDs right on the OI, default code I believe makes them show which way the joystick inputs are pointed for calibration, but you can change that.
Matt Krass
Unread 01-02-2006, 07:32
...for debugging purposes...
Yes, the Dashboard port is probably what you want to use.
But if you want simple debugging without the need for a computer, you can send a single number to the numeric display on the OI. See the very end of the Default_Routine() in the default code, where it formats the backup battery voltage to be displayed as the User Byte. Last year, I used one of the joystick wheels to select among several feedback values as diagnostic display.
Unread 03-02-2006, 23:15
FRC #1940
Has anyone written any software that converts the dashboard to a terminal (even if readonly)? There are 7 (8?) user-settable bits. 8 bits in an ASCII character (you can get by with 6, using a modified character table)... how fast is the refresh rate? Assuming it's faster than 26ms (ms = thousandths... so 40 chars\s max if limited to 26ms), you could have a relatively simple readonly text print-out of whatever you wanted.
Writing the software wouldn't be hard, especially if you used Linux (Serial port access is simpler).
@Edit
Where is the code that controls the joystick wheels? I can't seem to locate that little bit, and it's driving me INSANE. I want to use it as a toggle switch... I figure you could get 3-4 states out of it with relative precision... 2 at least (top and bottom). Also, will we have to use FIRST-provided joysticks, or will we be able to use our own (assuming I do a mod to said wheels to make them click into place).
Unread 06-02-2006, 17:09
chickensofdoom chickensofdoom is offline
AKA: Eric Thompson
#0818 (Genesis '02)
chickensofdoom is an unknown quantity at this point
Send a message via AIM to chickensofdoom Send a message via MSN to chickensofdoom Send a message via Yahoo to chickensofdoom
Yeah, we're trying to do something similar on our team. We have a palm pilot, and some software that emulates an LCD screen with it, and we're hoping to be able to use it to remotely display statistics (wheel speed, pot positions, etc.)
We just started working on it, so I'm still having trouble figuring out exactly how to output to the LCD manually and everything.
Anyway... I'd probably just plug it into the Dashboard port if I plan to interface to it, then?
Unread 06-02-2006, 21:17
FRC #1940
Yeah, you probably need a RS232 converter cable, though. Luckily, Axim x50 series RS232 cables are readily available (but for the steep-arse price of $50).
Unread 07-02-2006, 01:35
ForgottenSalad's Avatar
ForgottenSalad ForgottenSalad is offline
In search of a home...
AKA: Michael Wessler
ForgottenSalad will become famous soon enoughForgottenSalad will become famous soon enough
Send a message via AIM to ForgottenSalad
If anyone out there has anything like this please post or PM it... While having a full-fledged dashboard is nice, I would much prefer a terminal type readout.
A dashboard port related question, the data transfer through it is output only, correct?
Unread 07-02-2006, 18:19
devicenull devicenull is offline
Robot? We need a robot?
Rookie Year: 1234
devicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nice
A better idea would be a sort of lookup table. You would have a table in your dashboard program, with stuff like:
"Battery voltage %i"
"Doing something - %i %i"
"I broke something"
Then, the RC would set say User_Byte1 to the correct value, and the rest of the user bytes to the parameters for that message. The dashboard program would then read those and display the proper message. Just using User_Byte1, you could have 255 messages..
Updated: Serial Port Driver Code Kevin Watson Programming 4 05-02-2005 18:39
New Serial Port Driver Kevin Watson Programming 16 09-01-2005 01:56
Fried program slots? Jeff Waegelin Programming 18 19-03-2003 18:08
Limiting PWM in pbasic archiver 2001 4 24-06-2002 00:38
