Go to Post Who wants to see your robot get their butt handed to them? - Joe_Widen [more]
Unread 31-01-2006, 19:23
st1nkm4n st1nkm4n is offline
FRC #1357
st1nkm4n is an unknown quantity at this point
Camera not working
Hello
Our camera tracking was working, but alas it has stopped.
By working, I mean that I loaded Kevin Watson's default code (from www.kevin.org/frc) and plugged my camera's power into Analog 1, the Pan servo on the camera into PWM1 and the Tilt servo on the camera into PWM2. And it magically moved the servos to track the object, as Kevin's code did. Oh, and I also plugged the serial port into the robot controller and the camera. (And did not plug in the DB9 cable at the same time). Is there a special condition to activate the PWMs? (And the COM1 terminal window would report the position and stop "searching...")
Oh, and on Labview the camera performs all functions, including servo tracking.
I suspect a special condition must be achieved that I had before (A 12 volt battery that our team electricians hooked up)? Would this matter?
Unread 31-01-2006, 19:26
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Re: Camera not working
Originally Posted by st1nkm4n
Hello
Have you consulted the frequently-asked-questions document?
-Kevin
Kevin Watson
http://kevin.org
Unread 31-01-2006, 22:21
Jared Russell's Avatar
Taking a year (mostly) off
BACKUP BATTERY.
Sorry for caps, but that is the answer.
Unread 01-02-2006, 21:20
Oumonkey's Avatar
Oumonkey Oumonkey is offline
Master of the If statement
AKA: Josh Tyus
FRC #1555 (Pulse)
Oumonkey has a spectacular aura aboutOumonkey has a spectacular aura about
Originally Posted by Abwehr
BACKUP BATTERY.
Idiotic question here, but I just want to make sure, Are you talking about the blue one that hooks up to the rc controller? Mine is doing the samething and I just tried to fix it for 2 hours without it wanting to work
Thanks.
Unread 01-02-2006, 21:28
bush's Avatar
bush bush is offline
AKA: Aaron
FRC #0710 (Pine Crest School)
bush has a spectacular aura aboutbush has a spectacular aura about
Send a message via AIM to bush
Yes that's the blue one - the one that connects with spade wires in to the part of the RC that says backup battery
Unread 01-02-2006, 22:14
Oumonkey's Avatar
AKA: Josh Tyus
FRC #1555 (Pulse)
[quote=bush]Yes that's the blue one - the one that connects with spade wires in to the part of the RC that says backup battery [/QUOTE
Yay, Thank you, I just wanted to make sure
Unread 01-02-2006, 22:22
penguinsrock234 penguinsrock234 is offline
AKA: Rachel
FRC #0234 (Cyber Blue 234)
Team Role: Electrical
penguinsrock234 is an unknown quantity at this point
Our camera had the same problem for awhile. Check your PWM connections; they tend to jar loose. I would suggest zip tying the cables to the holes that are pre-drilled into the camera mount. They stay in much better that way. Also, we discovered that you can get power to the camera through the first Digital port on the RC. FYI: The 7.2 V backup battery can drain fairly quickly, so make sure you charge it regularly. If the camera still isn't working, try restarting the RC and OI completely. Our camera worked fine once we did that.
Unread 02-02-2006, 08:22
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
In addition, check all your connections. Ours stopped moving because the serial port cable came loose.
CMU Camera kills robot controller if not found. Chris_Elston Programming 21 27-03-2006 14:30
How To Use the Google Camera generalbrando Kit & Additional Hardware 2 07-02-2006 16:00
Scripting Setup and the Camera + Serial Port Drivers CJO Programming 22 11-01-2006 17:42
Unresponsive camera neilsonster Programming 9 17-02-2005 08:51
Camera stops working when we use camera_set_servos()... SeanCassidy Programming 16 13-02-2005 03:08
