Go to Post For our next exercise, we should define Beauty and Truth. :) - Taylor [more]
Unread 29-01-2006, 00:53
nukem nukem is offline
nukem is on a distinguished road
Robot Controller Brickified?
Today after the integration and testing team were done testing different values we got from the camera I tried to load some new code on implemented new features I programmed today. I hit the program button and went to download the new code with ifi-pictools(the Linux hex code loader). The problem is that after it got to 44/1300(the size of the program) it just froze, nothing happened. We tried it on another Linux computer and it had the same thing. Just the other day everything was working fine. Why is it that I can no longer load any code(default or own) onto the controller? Is it possible for us to fix it or do we have to send it back to ifi-robotics for repairs?
Thanks
Unread 29-01-2006, 02:02
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Re: Robot Controller Brickified?
IIRC, the size of the buffer in the C version is currently hardcoded at some size. I don't remember what, though. (I contributed the non-functional Python port. )
Basically, increase the 4096 constant in main.c and recompile until it's fixed (and then tell us so we can get a new version).
Any of the C developers have a better answer?
Unread 29-01-2006, 02:15
Eldarion's Avatar
Eldarion Eldarion is offline
Electrical Engineer / Computer Geek
AKA: Eldarion Telcontar
no team (Teamless Orphan)
Eldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond repute
Send a message via AIM to Eldarion Send a message via Yahoo to Eldarion
You need to perform a master reset. Hold both the RESET and PROG buttons on the RC for about five seconds. Release the RESET button, wait another five seconds, and then release the PROG button. The Battery light should go green, the Program light should go orange, and the rest should stay unlit.
Hope this helps!
CMUCam not working? Tracks sporadically? Try this instead: http://www.falconir.com!
PM me for more information if you are interested (it's open source!).
Want the FIRST Email blasts? See here: http://www.chiefdelphi.com/forums/sh...ad.php?t=50809
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
If it's falling apart it's a mechanical problem. If it's spewing smoke it's a electrical problem.
If it's rampaging around destroying things it's a programming problem.
"All technology is run on 'Magic Smoke' contained within the device. As everyone knows, whenever the magic smoke is released, the device ceases to function."
-- Anonymous
I currently speak: English, some German, Verilog, x86 and 8051 Assembler, C, C++, VB, VB.NET, ASP, PHP, HTML, UNIX and SQL
Unread 29-01-2006, 13:18
Hope this helps!
I tried that and it didn't work.
Unread 29-01-2006, 18:52
Eldarion's Avatar
That's odd. Another thing you could try is holding down the program button while applying power to the RC, although you may have already tried that.
Beyond those two things, I have no clue.
-- Thomas Paine
-- Anonymous
Unread 29-01-2006, 19:15
steven114 steven114 is offline
Programming Wizard and Team Captain
AKA: Steven Schlansker
FRC #0114 (Eaglestrike)
steven114 is a jewel in the roughsteven114 is a jewel in the roughsteven114 is a jewel in the rough
Send a message via AIM to steven114
It didn't work how - after you did the master reset, which lights were on? You're supposed to go green on battery, yellow on program, and the rest should be entirely off. Did it crash, did it boot up normally, or what?
Shift to the left, shift to the right!
Pop up, push down, byte, byte, byte!
Unread 30-01-2006, 16:37
DonRotolo's Avatar
Back to humble
FRC #0832
Hope this helps!
It did indeed. I can't say why it did not appear to correct the problem for nukem, but when he did it again in a quiet environment, it restored full functionality. Funny, we tried that Friday as well (found it on another post somewhere) and it didn't correct it then, either.
Bottom line is that we're back in business, THANK YOU ELDARION
Don
Unread 31-01-2006, 23:52
It seems that the reason it did not work last friday was that we had to load the code directly after resetting everything, I hit the program button. Anyway thanks for the help!
Unread 01-02-2006, 00:20
Eldarion's Avatar
That makes sense. I was going to mention that, but forgot.
Sorry!
-- Thomas Paine
-- Anonymous
Robot Controller NotaNerd Control System 6 04-11-2004 16:53
Best Robot Ever(again) Corey Balint General Forum 26 04-08-2004 23:03
Interfacing a PC with last year's Robot Controller punarhero Technical Discussion 2 21-04-2004 00:05
2004 Robot Controller CNCBoy461 Electrical 18 02-12-2003 16:36
Visibility of Robot Controller and Reset Button Tracy Rules/Strategy 1 17-02-2003 07:36
