Go to Post I used to think FIRST was about my learning experiences, but now that I'm out of high school and am a seasoned veteran of FIRST I've realized that this organization is about more than my own enjoyment, it's about the enjoyment of others. - Jeremiah Johnson [more]
Unread 31-01-2006, 14:56
Denz's Avatar
Denz Denz is offline
FRC #0772 (Sabre Bytes Robotics)
Denz is on a distinguished road
Send a message via MSN to Denz
Fried Cam?
Anyone else have a fried cam. We fed it 5v from the analog port on the processor. The mount was not touching the cam. Yet a piece on the cam gets very hot, and the cam looks like it's now fried. Any comments? Suggestions? Please guys, what went wrong?
www.sabrerobotics.com
Unread 31-01-2006, 15:16
Eldarion's Avatar
Eldarion Eldarion is offline
Electrical Engineer / Computer Geek
AKA: Eldarion Telcontar
no team (Teamless Orphan)
Eldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond repute
Send a message via AIM to Eldarion Send a message via Yahoo to Eldarion
Re: Fried Cam?
Are you sure you didn't hook up power backwards? It is very easy to do.
CMUCam not working? Tracks sporadically? Try this instead: http://www.falconir.com!
PM me for more information if you are interested (it's open source!).
Want the FIRST Email blasts? See here: http://www.chiefdelphi.com/forums/sh...ad.php?t=50809
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
If it's falling apart it's a mechanical problem. If it's spewing smoke it's a electrical problem.
If it's rampaging around destroying things it's a programming problem.
"All technology is run on 'Magic Smoke' contained within the device. As everyone knows, whenever the magic smoke is released, the device ceases to function."
-- Anonymous
I currently speak: English, some German, Verilog, x86 and 8051 Assembler, C, C++, VB, VB.NET, ASP, PHP, HTML, UNIX and SQL
Unread 31-01-2006, 16:34
varcsscotty varcsscotty is offline
Programmer
FRC #1571 (Braughtswurst)
varcsscotty is an unknown quantity at this point
Re: Fried Cam?
I found out the hard way that a very unfriendly place for shorts is underneath the serial port. Our camera motherboard actually started smoking from underneath there. Make sure you don't have any shorts....
"If you want the best, try the Wurst!"
Unread 31-01-2006, 23:53
Denz's Avatar
Re: Fried Cam?
Umm, it looks like one of our ICs is fried, completely dead. The power cannot be attached the wrong way, I always put the black where the little B is. And even if it was, that wouldn't cause a really big problem, the camera would just not work. It shouldn't get so hot as to burn someone (like me!). I was only feeding it 5V. I contacted IFI, the short was right underneath the lens part of the camera on an IC, but the other heat up quickly as well. Comments or anything? It's very much appreciated guys!
Unread 01-02-2006, 00:22
Eldarion's Avatar
Re: Fried Cam?
The camera does not have reverse polarity protection, the thing actually glows red-hot when hooked up backwards!
I only mentioned it because it is a common problem.
-- Thomas Paine
-- Anonymous
Unread 01-02-2006, 21:43
Denz's Avatar
Re: Fried Cam?
Don't think it was hooked up backwards, unless the battery was, but that doesn't make sense, because then the camera just wouldn't work. The camera's light was on for a bit until it got too hot and things fried. I seriously doubt that's not the problem, lol and I hope it's not because I'd feel like an idiot.
Steps to make cam work? magical hands Programming 7 31-01-2006 17:43
Team 343 Web Cam Gene F General Forum 6 20-02-2005 13:28
Questions about cam magical hands Programming 1 04-02-2005 17:13
G-Codes vs. CAM / CNC Forums indieFan Technical Discussion 19 16-06-2004 22:51
fried archiver 2000 4 23-06-2002 22:45
