Go to Post There is something to be learned (sometimes hard to find) from everyone you meet. - wireties [more]
Unread 31-01-2006, 15:46
NASAbound1636 NASAbound1636 is offline
clueless???
AKA: joe
FRC #1636 (Reds Robotics)
NASAbound1636 is an unknown quantity at this point
Re: fickle autonomous
ok to give everyone a clear picture of the problem i will post the error message and the code itself, btw i tried both of your suggestions, it didn't like either of them. (note: tabs are included in the proper areas)
Skipping file. There is no tool to process the file with the given suffix.
Skipping link step. Not all sources built successfully.
BUILD FAILED: Tue Jan 31 13:42:48 2006
#include <stdio.h>
#include "ifi_aliases.h"
#include "eeprom.h"
#include "ifi_default.h"
#include "ifi_utilities.h"
#include "serial_ports.h"
#include "terminal.h"
#include "tracking.h"
#include "tracking_menu.h"
#include "user_routines.h"
#include "camera.h"
#include "camera_menu.h"
void User_Autonomous_Code(void)
/* Initialize all PWMs and Relays when entering Autonomous mode, or else it
will be stuck with the last values mapped from the joysticks. Remember,
even when Disabled it is reading inputs from the Operator Interface.
pwm01 = pwm02 = pwm03 = pwm04 = pwm05 = pwm06 = pwm07 = pwm08 = 127;
pwm09 = pwm10 = pwm11 = pwm12 = pwm13 = pwm14 = pwm15 = pwm16 = 127;
relay1_fwd = relay1_rev = relay2_fwd = relay2_rev = 0;
relay3_fwd = relay3_rev = relay4_fwd = relay4_rev = 0;
relay5_fwd = relay5_rev = relay6_fwd = relay6_rev = 0;
relay7_fwd = relay7_rev = relay8_fwd = relay8_rev = 0;
static unsigned int t;
while (autonomous_mode) /* DO NOT CHANGE! */
if (statusflag.NEW_SPI_DATA) /* 26.2ms loop area */
Getdata(&rxdata); /* DO NOT DELETE, or you will be stuck here forever! */
/* Add your own autonomous code here. */
t++;
if (t<19)
pwm01=190; /* left motor */
pwm02=190; /* right motor */
pwm03=127; /* launcher motor */
pwm04=127; /* feeder motor? */
else if (t<38)
pwm01=150;
pwm02=90;
pwm03=127;
pwm04=127;
else if (t<95)
pwm01=190;
pwm02=190;
pwm03=127;
pwm04=127;
else if (t<380)
pwm01=127;
pwm02=127;
pwm03=190;
pwm04=160;
Generate_Pwms(pwm13,pwm14,pwm15,pwm16);
Putdata(&txdata);
there are 3 kinds of people in the world. those who can count, and those who can't.
Did you know that 4/3 of all people have trouble with fractions?
there are 10 kinds of people in the world, those who understand binary, and those who don't.
If you have 1 of these and you will let me use it then pm it to me
Unread 31-01-2006, 16:09
Dave Scheck's Avatar
Dave Scheck Dave Scheck is offline
Dave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond repute
You're missing a closing brace
Line 70 lines up with 32
Line 71 lines up with 30
Line 72 lines up with 27
Line 16 has an open brace but no matching closing brace
Unread 31-01-2006, 21:00
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
use the [ code ] tag next time, please.
Unread 31-01-2006, 23:35
clueless???
AKA: joe
what is a code tag? a thread name?
Unread 01-02-2006, 00:02
LightWaves1636's Avatar
LightWaves1636 LightWaves1636 is offline
is all over it.
AKA: Sarah Le
LightWaves1636 is a splendid one to beholdLightWaves1636 is a splendid one to beholdLightWaves1636 is a splendid one to beholdLightWaves1636 is a splendid one to beholdLightWaves1636 is a splendid one to beholdLightWaves1636 is a splendid one to beholdLightWaves1636 is a splendid one to behold
Send a message via AIM to LightWaves1636 Send a message via Yahoo to LightWaves1636
you weren't using the entire "bells and whistles" default programming. you were trying to make a brand new program of your own. so try again using the code me and Jake's been altering because I bet you need the vaules of what are the pwm outputs(because we've completely changed them) and a whole bunch of other stuff.
When I saw your screen, you were missing a bunch load of files. And can't just dump all the files your missing right into the workspace. Load "bells and whistles" and redo it. Or else you'll never get the autonomous code to work.
A code tag is an attachment that you can just put the code into so you don't take up half the screen.
By nickname Jake was asking, he was asking what's your nickname, not your s/n. Like mine is Light Goddess in the theatre dept.
Unread 01-02-2006, 00:24
Eldarion's Avatar
Eldarion Eldarion is offline
Electrical Engineer / Computer Geek
AKA: Eldarion Telcontar
no team (Teamless Orphan)
Eldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond repute
Send a message via AIM to Eldarion Send a message via Yahoo to Eldarion
Originally Posted by NASAbound1636
all brackets, parenthesis, and semicolons are accounted for. any other possibilities?
Colons and semicolons look almost identical, and it can be a real pain to find the problem when you put a colon in instead of a semicolon!
Just a thought...
CMUCam not working? Tracks sporadically? Try this instead: http://www.falconir.com!
PM me for more information if you are interested (it's open source!).
Want the FIRST Email blasts? See here: http://www.chiefdelphi.com/forums/sh...ad.php?t=50809
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
If it's falling apart it's a mechanical problem. If it's spewing smoke it's a electrical problem.
If it's rampaging around destroying things it's a programming problem.
"All technology is run on 'Magic Smoke' contained within the device. As everyone knows, whenever the magic smoke is released, the device ceases to function."
-- Anonymous
I currently speak: English, some German, Verilog, x86 and 8051 Assembler, C, C++, VB, VB.NET, ASP, PHP, HTML, UNIX and SQL
A Warning to Human Players During Autonomous The Lucas General Forum 21 07-04-2005 02:29
Setting Autonomous Settings from OI Tom Saxton Programming 15 27-03-2005 11:45
Despite what IFI says, you can configure autonomous from OI... TedP Programming 19 31-03-2004 10:09
autonomous mode problem on field Chris_C Programming 17 26-03-2003 19:11
