Go to Post I HAVE ENERGY DRINKS AND STARBUCKS COFFEE!!! I'M READY!!! - looneylin [more]
Unread 12-01-2006, 11:18
de_ de_ is offline
AKA: Dave Edwards
FRC #1310 (Runnymede Robotics)
de_ is a jewel in the roughde_ is a jewel in the roughde_ is a jewel in the roughde_ is a jewel in the rough
How to remove pulley from CIM motor
We removed the circlip and set screw but we have yet to be able to get the pulley off. I assume it is a press fit but you would think not too hard a press fit otherwise why have the circlip and the setscrew. Our next step is either heat or cutting it off. Anyone got it off yet ? How ?
Unread 12-01-2006, 11:25
ebmonon36's Avatar
ebmonon36 ebmonon36 is offline
AKA: Eric Bredehoeft
FRC #1018 (Robodevils)
ebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud of
Send a message via AIM to ebmonon36
Re: How to remove pulley from CIM motor
Use a gear puller to get the pulley off.
Eric
Unread 12-01-2006, 13:26
President, VEX Robotics, Inc.
You should heat up the pulley with a heat gun. The pulley is held in place using an adhesive that loses strength with heat. You do not have to heat it so hot that the shaft changes color, but a few hundred degrees with a standard hardware stor heat gun will do the trick.
-Paul
Unread 14-01-2006, 23:27
AKA: Dr. Brooks
no team (WRRF)
-Paul
Our shop teacher tried twice to get this pulley off with a puller, leaving a dimple in the end of the motor shaft with each attempt. Realizing that there must glue in the works, we got the torch and set it up ready to go. With the simple threat of heat from the torch, when the puller went on for the third time the pulley came off without actually having to apply heat. I guess the pulley knew with the gig was up and let go!
Unread 15-01-2006, 09:21
Mike Martus's Avatar Unsung FIRST Hero
Mike Martus Mike Martus is offline
FRC #0051 (Wings of Fire)
Mike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond repute
andymark.biz
Andy Baker is selling a great puller for $10.00. Check out their other great products.
Mike Martus
Unread 19-01-2006, 19:09
RY-GUY's Avatar
RY-GUY RY-GUY is offline
None #1566 (Ammoknights)
RY-GUY is an unknown quantity at this point
You can also get the gear up by heating it up with a bunsen burner and then pry it off with two screw drivers. Just FYI.
Unread 20-01-2006, 02:26
mr_spam mr_spam is offline
Kenny B
AKA: Brendan
FRC #1410
mr_spam is an unknown quantity at this point
Send a message via AIM to mr_spam Send a message via MSN to mr_spam Send a message via Yahoo to mr_spam
We used a bolt/nut crunching tool. it just crumbled off.
Unread 21-01-2006, 23:11
in between teams
AKA: Luke Van Oort
This method works GREAT! In fact, it is so good, that our biggest problem was removing the snap ring from the shaft, not the pulley. (Although that beefy spring caused more anxiety)
Team 1219: 2009 - Mentor
Unread 21-01-2006, 23:19
sciguy125 sciguy125 is offline
Electrical Engineer
AKA: Phil Baltar
FRC #1351
sciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond repute
Send a message via AIM to sciguy125 Send a message via MSN to sciguy125 Send a message via Yahoo to sciguy125
1351's attack strategy:
Take the nut off of the tensioner screw. Nudge the tensioner off with a few blows of the hammer.
Take the clip off of the shaft. Use two screwdrivers to pry off the pully. As you get farther up, you'll need spacers. Combo wrenches around the shaft work well. The earlier attempts with a torch may or may not have affected the adhesive prior to the screwdriver operation.
If you only plan on using one of the motors, you can also pull the long tensioner screw off of the other one so that you have two on one motor. It seems like it might be a good way to mount it. However, we're unsure of the legality of this.
-----BEGIN GEEK CODE BLOCK-----
Version: 3.12
GE/S/P a-- e y-- r-- s:++ d+ h! X+++
t++ C+ P+ L++ E W++ w M-- V? PS+ PE+
5- R-- tv+ b+ DI+++ D- G
------END GEEK CODE BLOCK------
Unread 22-01-2006, 01:22
MrB's Avatar
MrB MrB is offline
871 Team Leader
AKA: Brian Buonomo
FRC #0871 (WI RoboTechs)
MrB is a jewel in the roughMrB is a jewel in the roughMrB is a jewel in the roughMrB is a jewel in the rough
we pushed it out in a hydraulic press. No heat required.
~ Mr. Buonomo, Team 871
Unread 01-02-2006, 00:42
lil_ruber_duky's Avatar
lil_ruber_duky lil_ruber_duky is offline
AKA: Tatiana
FRC #1868 (Space Cookies)
Team Role: Operator
lil_ruber_duky will become famous soon enough
Send a message via AIM to lil_ruber_duky
when we were trying to get it off, our screw from the gear puller snapped in half. so we took a blow torch and that melted the adhesive and then it slid right off!
Unread 01-02-2006, 07:33
Nitroxextreme's Avatar
Nitroxextreme Nitroxextreme is offline
Relation to Mrs. Steve
AKA: Jon
FRC #1626 (Falcon Robotics ; 190 (Gompei and The Herd))
Nitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to behold
Send a message via AIM to Nitroxextreme
We use a blow torch and a gear puller (heavy Duty)
"He needed a chuck norris lesson in FIRST"...."I will give him a round house kick to the face...with gracious professionalism"
Unread 01-02-2006, 12:11
richwong richwong is offline
None #1701 (Robocubs)
richwong is an unknown quantity at this point
We used a heat-gun and two flat-head screwdrivers to pry it off. Worked great.
Unread 01-02-2006, 17:46
Phil,
I would only recommend this as a last resort. By using the endplate as a wedge, much of the pry force is placed on the bearing surface inside the end plate. As the force transfers to the bearing, additional stress is placed on the endplate securing the bearing in place.
Unread 01-02-2006, 20:49
Electrical Engineer
AKA: Phil Baltar
FRC #1351
Yeah, we realized that and it was our last resort. Well...after you get it off, there's not much need to investigate other options...
Our gear puller couldn't grab the pully correctly. We tried clamping the pully in the vise then hammering on the shaft, but it kept slipping. The press was considered, but it didn't look safe. There was also some talk of trying to either cut or crack the pully somehow. After a few hours, we settled for just prying it off.
Version: 3.12
Gear Ratio Math for Cim Motor FP801-005 KogaVanDragon Motors 2 14-01-2006 02:38
Inductance of CIMs phrontist Electrical 13 06-01-2006 09:17
Cheap Torque Measurement? ChuckDickerson Motors 15 13-06-2005 13:57
**FIRST EMAIL**/Important Fisher-Price motor and gearbox information sanddrag FIRST E-Mail Blast Archive 1 11-02-2005 18:19
CIM vs. Drill motor duckshepherd Motors 3 15-02-2003 18:36
