Go to Post ... One of the things I happen to like about the Chief Delphi community is that at every competition I go to, someone recognises me and comes over to say hi ... I meet someone new, they meet someone new, and it's win/win. - EddieMcD [more]
Unread 01-02-2006, 13:41
REVving up for a new season
FRC #2848 (All-sparks)
Re: pic: Dual track, Maximum grip
Friction force does not increase with a higher surface contact. The reasoning behind that is due to the force in between the surface and the wheel, in this case the robot weight. A larger area between the wheel and the carpet would create a larger source of frictional forces, but it reduces the pressure between them. The same force dissipated over a larger area with the same coefficient of friction is equivalent to a smaller area with less sources of friction forces.
Basically since your robot weight is a constant and your CG is the same with both smaller and larger wheels, your traction actually does not change. The only thing that could be reasoning for this traction wise is more surface contact while on the ramp. If a smaller wheel looses contact with the ground it would have no friction, such having larger wheels would have less of a chance of loosing contact with the ground.
So in this case i think sanddrag has a point but you never know the reasoning behind their decision.
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
pic: Dewalt Dual Motor CD47-Bot Extra Discussion 8 10-12-2004 20:31
pic: 716 Dual Motor/Dual Speed CD47-Bot Robot Showcase 18 23-04-2004 01:51
pic: Team 959 V-Belt Track Bot CD47-Bot Robot Showcase 2 28-02-2004 09:43
pic: dual speed gearbox CD47-Bot Extra Discussion 9 07-10-2003 15:04
