Go to Post Changing the world starts with changing yourself. - Jeremy_Mc [more]
View Poll Results: Is your team going aftr the ramp this year?
Yes, we are going after the ramp 211 90.95%
No, we are not going after the ramp 10 4.31%
Ramp??? What ramp? 11 4.74%
Voters: 232. You may not vote on this poll
Unread 31-01-2006, 19:00
Re: Teams going after the ramp?
How about an out-of-the box idea? Cover the front rail of your robot with something soft and highly sticky -- like a layer of natural rubber. Drive up to the ramp and stop when your rubber bumper hits. A ram (which can be nearly 60 inches long under the rules) then extends out from the bottom near the other end, levering the robot up onto its face until the CG passes over the rubber pad and the robot tips up on the ramp. The soft rubber bumper keeps it from sliding back down.
OK, it's weird, but you could use it with a holonomic drive or with the Skyway 8-inch wheels. Somewhere, someone is building just this system into their robot.
Rick's first FIRST rule: If you've thought of and rejected an engineering approach, someone else will successfully implement it. Every conceivable approach will be tried.
Unread 31-01-2006, 20:37
bobotics319 bobotics319 is offline
AKA: Andrew Levasseur
FRC #0319 (Bobotics)
Team Role: Communications
bobotics319 is an unknown quantity at this point
Yes are Team is going after the ramp.. its gona be sick...
Unread 31-01-2006, 23:01
Eldarion's Avatar
Eldarion Eldarion is offline
Electrical Engineer / Computer Geek
AKA: Eldarion Telcontar
no team (Teamless Orphan)
Eldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond repute
Send a message via AIM to Eldarion Send a message via Yahoo to Eldarion
We actually are building an assist into our robot, just not the one you described. Time will tell which system is better...
CMUCam not working? Tracks sporadically? Try this instead: http://www.falconir.com!
PM me for more information if you are interested (it's open source!).
Want the FIRST Email blasts? See here: http://www.chiefdelphi.com/forums/sh...ad.php?t=50809
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
If it's falling apart it's a mechanical problem. If it's spewing smoke it's a electrical problem.
If it's rampaging around destroying things it's a programming problem.
"All technology is run on 'Magic Smoke' contained within the device. As everyone knows, whenever the magic smoke is released, the device ceases to function."
-- Anonymous
I currently speak: English, some German, Verilog, x86 and 8051 Assembler, C, C++, VB, VB.NET, ASP, PHP, HTML, UNIX and SQL
Unread 31-01-2006, 23:10
LightWaves1636's Avatar
LightWaves1636 LightWaves1636 is offline
is all over it.
AKA: Sarah Le
LightWaves1636 is a splendid one to beholdLightWaves1636 is a splendid one to beholdLightWaves1636 is a splendid one to beholdLightWaves1636 is a splendid one to beholdLightWaves1636 is a splendid one to beholdLightWaves1636 is a splendid one to beholdLightWaves1636 is a splendid one to behold
Send a message via AIM to LightWaves1636 Send a message via Yahoo to LightWaves1636
we're going, hopefully, I think. we just need to make dure our wheels are good. so yeah we're going to try. those bonus point sure sound nice.
Unread 31-01-2006, 23:24
Alekat's Avatar
Alekat Alekat is offline
AKA: Alex
None #0701 (RoboVikes)
Alekat has a spectacular aura aboutAlekat has a spectacular aura about
Send a message via AIM to Alekat
Originally Posted by cgrar2008
The largest problem we observed was the clearance because of the seemingly "extreme" 30 degree angle. Being a rookie team and using the stock frame there was a small amount of clearance with the kit skyway wheels, but they did not provide near enough traction so we resorted to the "running start method" and made it up. We purchased new wheels that will hopefully allow us to have a high enough coefficient of friction to claw our way onto the ramp.
-Chuck
Yes! You guys are on the right track, I think this is the minimum a rookie team should aim for.
Unread 31-01-2006, 23:28
pez1959's Avatar
pez1959 pez1959 is offline
Cap'n Patty
AKA: Patrick
FRC #1959 (Aye Aye Robot)
pez1959 is on a distinguished road
Send a message via AIM to pez1959 Send a message via MSN to pez1959 Send a message via Yahoo to pez1959
Another thing to keep in mind. The rules specify off the carpet, not necessarily on the flat part of the platform.
Unread 31-01-2006, 23:49
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
I personally can't understand how some teams could not think that the ramp is important. It's 25 points if everyone can do it, that's a lot! I'd hate to be on the only team in an alliance that could not make it up, that'd be quite a letdown. So yes, we are indeed going for the ramp.
I am liking the out of the box ideas though. Heres one: latch onto the side wall of the ramp (the ones that are supposed to keep you from falling off) and just clamp on so your robot is just barely lifted off the carpet. That would be cool.
Unread 01-02-2006, 00:14
cire's Avatar
cire cire is offline
Alumni, Mentor, and Coach
AKA: Eric Diehr
FRC #1716 (Redbird Robotics)
cire is just really nicecire is just really nicecire is just really nicecire is just really nice
Send a message via MSN to cire
We can get up the ramp, we need quite a bit of a running start though. The wheels kept on slipping, I hope that diamond plating has a higher coefficient of friction then smooth plywood.
Unread 01-02-2006, 09:58
Schneidie's Avatar
Schneidie Schneidie is offline
AKA: Marc Schneider
FRC #0177 (The Bobcats)
Schneidie will become famous soon enoughSchneidie will become famous soon enough
Originally Posted by Eldarion
Just curious if anyone is going after the ramp this year.
We will try, but if it won't work it's not the end of the world.
Of course, we are trying and wea re trying to work out our clearance issues.
Schneidie
Unread 01-02-2006, 11:05
aaeamdar's Avatar
aaeamdar aaeamdar is offline
Post-A-Holic
AKA: Paul Dennis
FRC #1719 (The Umbrella Corp)
aaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant future
Originally Posted by Abwehr
I'm of the school of thought that any robot can make it up the ramp if they're going fast enough
The problem with this school of thought is that in practice it doesn't work. When you are running at the ramp at a great velocity, you will hit the steep ramp and essentially bounce back. If what you meant to say was that "If you are going fast enough when on the ramp" then that's funny (seriously).
[QUOTE = antthecyberguy]Our original thought was that of "the ramp is not worth it" but our robot design allows to go up it if necessary. We would hate to be the only one in the alliance that could not make it.[/quote]
I'm absolutely in agreement. You don't want to be the "downer" on your team that can't get up the ramp at the end, especially if your teammates are counting on you. Nicely said.
Paul Dennis
Unread 01-02-2006, 12:07
Mike Norton's Avatar
Mike Norton Mike Norton is offline
FRC #0061
Rookie Year: 1995
Mike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to all
And you'd be alot more vaulable if you got the torque and the design to help your other alliance robots get up the ramp
Help other alliance. We plan on pushing the other teams robots our ramp just to make sure we get 25 points and they don't, that is a big swing of points.
and if they are stuck on your ramp they can't score and there are no pinning on the ramp.
Question is how many robots can you push up the ramp in 40 seconds
power, speed nice
Building FIRST robots since 1995
BVT Robotics
Unread 01-02-2006, 13:21
MattB703 MattB703 is offline
AKA: Matt
None #0703 (Team Pheonix)
MattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud of
My guess is one. Unless you can co-ordinate with your alliance partner to hold the first on in place while you go get the second. And after the first one the other guys might decide to stay away from you.
Unread 01-02-2006, 13:49
Daru Daru is offline
Daru has a spectacular aura aboutDaru has a spectacular aura about
We're going for the ramp this year, with our design we have a couple of millimeters of clearence. We might move the front wheels back a little... what if their ramp is a mm off of what ours is, then we're in ruin ;-;
I think getting up the ramp will be important, to the point that if you cant do it, you will disappoint other teams. Really all there is to it is having the ground clearence.
Unread 01-02-2006, 13:50
Eldarion's Avatar
And a low enough CG
-- Thomas Paine
-- Anonymous
Unread 01-02-2006, 13:57
BRosser314's Avatar
BRosser314 BRosser314 is offline
Post-A-Holic
AKA: Brandon Rosser
FRC #0469 (Las Guerrillas)
BRosser314 is a splendid one to beholdBRosser314 is a splendid one to beholdBRosser314 is a splendid one to beholdBRosser314 is a splendid one to beholdBRosser314 is a splendid one to beholdBRosser314 is a splendid one to beholdBRosser314 is a splendid one to behold
Send a message via AIM to BRosser314 Send a message via Yahoo to BRosser314
Originally Posted by greencactus3
well i think brake HARD right before the ramp so you fall forwards onto the ramp rather than backwards onto the carpet. easier to push a robot half on the ramp than ompletley on their backs on carpet.
Well atleast someone saw my humor behind this. And what might sound stupid might be a good idea if you cant get up there by yourselfs. Have someone on your alliance push you up if they have th power or you can withsatnd being pushed.
YMTC: Can teams start cutting metal for 2005? Natchez You Make The Call 67 07-02-2006 21:55
Finding new teams Kit Gerhart Finding A Team 8 13-04-2004 12:05
The top 8 teams will be....(2004) Jessica Boucher General Forum 20 24-03-2004 22:31
Robot Collaboration Karthik General Forum 153 18-02-2004 03:40
Long post - this year's game was tough - here's why: archiver 2001 7 24-06-2002 03:31
