Go to Post Enlighten a man who sometimes has difficulty understanding why others stray outside the box, when the box appears to be an optimized and elegant solution. - JVN [more]
Unread 01-02-2006, 13:25
falconmaster's Avatar
falconmaster falconmaster is offline
AKA: Ledge
FRC #0842 (Falcon Robotics)
falconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond repute
Send a message via MSN to falconmaster
pic: Dual track, Maximum grip
Faridodin "Fredi" Lajvardi KD7WKD
Unread 01-02-2006, 13:28
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: pic: Dual track, Maximum grip
How did you determine that double wheels will give you better traction? To me, even one of those wheels seems pretty wide.
Unread 01-02-2006, 13:41
REVving up for a new season
FRC #2848 (All-sparks)
Friction force does not increase with a higher surface contact. The reasoning behind that is due to the force in between the surface and the wheel, in this case the robot weight. A larger area between the wheel and the carpet would create a larger source of frictional forces, but it reduces the pressure between them. The same force dissipated over a larger area with the same coefficient of friction is equivalent to a smaller area with less sources of friction forces.
Basically since your robot weight is a constant and your CG is the same with both smaller and larger wheels, your traction actually does not change. The only thing that could be reasoning for this traction wise is more surface contact while on the ramp. If a smaller wheel looses contact with the ground it would have no friction, such having larger wheels would have less of a chance of loosing contact with the ground.
So in this case i think sanddrag has a point but you never know the reasoning behind their decision.
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 01-02-2006, 15:51
Jeff K.'s Avatar
Jeff K. Jeff K. is offline
Hmm..now what?
FRC #1138 (Eagle Engineering)
Jeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond repute
Send a message via AIM to Jeff K. Send a message via MSN to Jeff K.
Why didn't you just go with the roughtop for more traction? It has a higher coefficient of friction than wedgetop and costs the same.
It might also be overkill though for your design for dual roughtop.
And nice chassis.
Unread 01-02-2006, 16:02
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
I'm still puzzled as to why you shortened your chassis, presumably to help the robot turn more easily (or to facilitate picking up balls), and then put a shifting transmission on the bot, driving omniwheels in front, and traction wheels in the back.
You should have been able to get away with just the shortening of the chassis., and still be able to turn with 4 traction wheels. Using omniwheels and a powerful transmission just seems like you're shortchanging yourself.
2001-2004: Team 100
2006-Present: Team 254
Unread 01-02-2006, 16:21
occra 23.
AKA: ryo
None #1481
And nice chassis.
really? i thought it was a more opinion thing.. anyone test this on diamondplate btw?
and well wider tire contact will help it go straight.. more scrub when turning.
pic: Dewalt Dual Motor CD47-Bot Extra Discussion 8 10-12-2004 20:31
pic: 716 Dual Motor/Dual Speed CD47-Bot Robot Showcase 18 23-04-2004 01:51
pic: Team 959 V-Belt Track Bot CD47-Bot Robot Showcase 2 28-02-2004 09:43
pic: dual speed gearbox CD47-Bot Extra Discussion 9 07-10-2003 15:04
