Go to Post My most distinct memory was watching Tom fix our robot's frame... by whacking it with the hammer. - Jaine Perotti [more]
Unread 01-02-2006, 16:50
Joel J's Avatar
Joel J Joel J is offline
do you..
Re: C18 v2.4 -- Syntax error where there is no syntax error
Originally Posted by Tom Bottiglieri
I had the same problem last year. I think it can be resolved by simply checking the #include statements in all of your source files to be sure functions that are being referenced are included, and non used headers are not included. I know it seems kind of obvious, but give it a try.
That did the trick, for the most part.
Thanks.
Joel Johnson
RAGE (173) Alumni, 1999-2003
C18 v2.4 compiler location b_mallerd Programming 1 14-12-2005 16:43
Syntax Error: externs, structs, and macros Astronouth7303 Programming 3 16-02-2005 15:39
syntax error using enum{} gnormhurst Programming 8 07-02-2005 14:25
Routine declaration syntax error (Or: Where's wlado?) Astronouth7303 Programming 15 24-03-2004 05:51
