Go to Post I'm impressed and incredibly amused that you found so many of Dave's evildoings, though granted, they aren't that hard to search out. - DCA Fan [more]
Unread 01-02-2006, 17:49
falconmaster's Avatar
falconmaster falconmaster is offline
AKA: Ledge
FRC #0842 (Falcon Robotics)
falconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond repute
Send a message via MSN to falconmaster
pic: installed battery team 842
Faridodin "Fredi" Lajvardi KD7WKD
Unread 01-02-2006, 17:50
Kyle A's Avatar
Kyle A Kyle A is offline
If it ain't broke don't fix it!
AKA: K Adams
FRC #0306 (CRT(Corry Robotics Team))
Kyle A has much to be proud ofKyle A has much to be proud ofKyle A has much to be proud ofKyle A has much to be proud ofKyle A has much to be proud ofKyle A has much to be proud ofKyle A has much to be proud ofKyle A has much to be proud of
Send a message via AIM to Kyle A Send a message via Yahoo to Kyle A
Re: pic: installed battery team 842
Looks nice but isn't going to be hard to change batteries in the finals or if a match is back to back?
Corry Robotics Team 306 1999-2015
Unread 01-02-2006, 18:41
Bill_Hancoc's Avatar
Bill_Hancoc Bill_Hancoc is offline
Volkswagen Enthusiast
AKA: Bill Hancock
FRC #0573 (MechWarriors)
Bill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud of
Send a message via AIM to Bill_Hancoc
I agree with Kyle but the lil' aluminum handle is a nice touch.
MechWarriors 573
Unread 01-02-2006, 20:36
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
If I'm not mistaken, it would appear as if you've bolted the Anderson quick disconnect connector to the side of your battery mount. If this is true, you're probably going to have trouble when inspection time rolls around at regionals.
I cannot find any mention of it in the rules, but should your robot go haywire on the field, this falls into the "make sure your main breaker is clearly accessible" category. If you can't easily pull the two halves apart, the entire point of using the connector is defeated.
As I said, I can't find anything in the rules about this, but I'd submit a question in the Q&A forum to be sure, as it seems like it'd get called somewhere down the line at competition.
2001-2004: Team 100
2006-Present: Team 254
Unread 02-02-2006, 19:13
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
That little handle, while a nice idea, would very likely fail an inspection, for the simple reason that you'd need to convince the inspector that the battery sidewall is structurally strong enough to support a 14 lb load (i.e. the battery), without risking spilling gel electrolyte all over you, and dropping the battery on your foot.
Also, the resistance of the battery wires will increase greatly because of the sharp bends—while tidy, they may hinder performance.
Unread 02-02-2006, 22:20
N7UJJ N7UJJ is offline
Teacher
AKA: Allan Cameron
FRC #5465 (BinaryBots)
N7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond repute
The bar atop the battery pivots on the back hinge. One flip of a latch and the bar goes up. Then lift the hanle and the battery automatically disconnests at the Anderson connector. Drop the new battery in place, lower the holding bar, secure it and batteries are changed withinin 10 seconds.
Cory, one half of the Anderson is on the chasis, theo other on the battery. The two halves are not bolted to each other.
Bill, no aluminun, all extruded fiberglass material. No electrical conductivity problems.
Tristian. The creative pultrusion fiber abgle material is stonger than steel for it's weight. There is no way the battery will fall. It's very secure.
thanks,
Allan
Unread 03-02-2006, 00:12
occra 23.
AKA: ryo
None #1481
i think they meant the battery wall itself breaking.
i agree its a greeat idea. if you post in the Q/A lmk when they give you a response
Unread 03-02-2006, 02:27
Alekat's Avatar
Alekat Alekat is offline
AKA: Alex
None #0701 (RoboVikes)
Alekat has a spectacular aura aboutAlekat has a spectacular aura about
Send a message via AIM to Alekat
I like it, it is very innovative, and it seems like you've done everything to get it to pass inspection according to the rules.
Unread 03-02-2006, 08:12
Actually, it's the battery wall itself, or the glue/resin joint that concerns me.
Unread 03-02-2006, 10:22
Kyle A's Avatar
AKA: K Adams
Ok is see now. But I do agree with everyone on the glued on handle having a possibility of breaking.
Unread 03-02-2006, 22:06
AKA: Ledge
Ok, I will join in the frey. We have used this method minus the glued on assist handle for the past two years and always made it past inspection. If need be we can change the design in minutes as per judges request. As far as the glue, it is plumbers goop, or shoe goo. It won't come off, we have to work to get it off. The handle is only used to get the battery moving in a verticle direction. One hand is around the back end and the other is on the handle to just disengage the anderson. Once disengaged, the battery itself is handled with both hands. When installing the battery, the handle is used to guide the andersons into each other. The fiberglass, on the other hand, really threw you. Totally safe there! Any way when I started to enter this reply I was just going to say
"Na ah, we used super duper goop!"
Unread 04-02-2006, 09:36
Teacher
AKA: Allan Cameron
I have not heard that before. With a high frequency AC signal, with it's skin effect, I guess a sharp bend might have an effect, but a DC circuit? Assumming no kinks or deforming thd diameter of the wire, why would bending a wire affect it's resistance?
The Death of FIRST Anton Abaya General Forum 23 03-05-2006 17:18
Why do teams voluntarily do FIRST without adult technical mentors? Andy Baker General Forum 127 05-12-2005 08:08
How do you organize your team? NoodleKnight Team Organization 18 03-11-2005 22:57
What's the best organizational structure for photos? maikull Chit-Chat 2 17-03-2005 17:47
Real names, please Andy Baker General Forum 131 21-07-2004 22:07
