Go to Post Honestly, I'd volunteer my team to be on that alliance. It'd be an honor to touch bumpers with those bots. - ttldomination [more]
Unread 01-02-2006, 11:59
naor52 naor52 is offline
FRC #1578
naor52 is an unknown quantity at this point
green
I've got a little problam....i've got the values of the color green from the cam but hadn't found where to put them inside the user_routines.c, i would like if any one can write me where and how plz...cuz maby im noob but i havnt found where..
Unread 01-02-2006, 12:39
bush's Avatar
bush bush is offline
AKA: Aaron
FRC #0710 (Pine Crest School)
bush has a spectacular aura aboutbush has a spectacular aura about
Send a message via AIM to bush
Re: green
All you need is Kevin's code. All of the calibration parameters are programmed in, and the servos auto-track the target.
Either get the "bells and whistles" or the "streamlined" version of camera.zip from http://www.kevin.org/frc/
Unread 01-02-2006, 13:03
FRC #1578
Re: green
I have downloaded the kevin code but when i download it to the controller nothing has happend...how should i make it work?!?
and anther q's when i use labview and take a pictuer the green light is comming out as white why is that?!?and how to make it back green?!?
Unread 01-02-2006, 16:06
David55 David55 is offline
AKA: David Hillman
FRC #1577 (Steampunk) & FRC #125 (NUTRONS)
David55 is a splendid one to beholdDavid55 is a splendid one to beholdDavid55 is a splendid one to beholdDavid55 is a splendid one to beholdDavid55 is a splendid one to beholdDavid55 is a splendid one to behold
Re: green
הבעיה הזאת קרתה גם לנו
זה פשוט בגלל שהאור בהיר מדי
אבל זאת לא אמורה להיות בעיה...תנסה לעשות את הקליברציה במקום בלי פלורוסנט
Unread 01-02-2006, 17:38
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Re: green
That's pretty impressive. My browser can handle jewish (?) characters. (The same can not be said for far-east languages.)
David55, seeing as most of us are obnoxious, monolingual Americans, you're probably going to need to use English. (As horrible of a language it is; highschoolers still don't get it right.)
Unread 01-02-2006, 17:42
Re: green
YM "Hebrew"
Unread 01-02-2006, 17:50
AKA: David Hillman
Re: green
I just wanted to check if this forum supports Hebrew
I guess the answer is positive
hooray
Unread 01-02-2006, 17:55
DanDon's Avatar
DanDon DanDon is offline
ohhh MY god
AKA: Dan Hoizner
FRC #0375 (The Robotic Plague)
DanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond repute
Send a message via ICQ to DanDon Send a message via AIM to DanDon Send a message via MSN to DanDon
Re: green
hooray
haha....madlik.
yesh laha ICQ?
Unread 01-02-2006, 17:57
Heretic121 Heretic121 is offline
The Resident Gamer -
AKA: Pat or Harry... if you ask its a long story...
FRC #0078 (AIR Strike)
Team Role: Tactician
Heretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond reputeHeretic121 has a reputation beyond repute
Send a message via AIM to Heretic121
Re: green
mkay i had the same problem w/ kevins code...
i tried to use his values with no success of tracking because it kept seeing the florescent lighting... even with my own values i have trouble =(
more tweaking time for me =( lol... *and im also having trouble w/ the tracking algorythim but thats a whole nother story where it finds the target the moves AWAY from it *ive tried using a jump to reverse which way it goes it doesnt help*
2004 - Team 121 Human Player
2005 - Team 121 Student Captian
2006 - Team 38 Drive Team Coach / Mentor
2007 - 2009 - Team 121 Mentor / Strategery Master
2010 - 2013 - Team 78 Mentor / Strategy / Scouting Lead
2014 - Team 78 coach
Unread 01-02-2006, 18:13
6600gt's Avatar
6600gt 6600gt is offline
AKA: Lohit
FRC #0226 (Hammerhead)
6600gt is a jewel in the rough6600gt is a jewel in the rough6600gt is a jewel in the rough
Re: green
if you are using the "bells and wistles" version, just use the terminal window to reload the default values. if you are using the normal one then just load a fresh non "bells and wistles" version that has to modifications.
BASICLY keep all the default values, except the noise filter. Crank that up one by one until the camera works the way you want it to. Then just fine tune the other values as you need to.
Don't add any jumpers because you can just change it in the code:
// If your camera suddenly moves away from the target once
// it finds it, you'll need to change the sign on one or
// both of these values.
#define PAN_ROTATION_SIGN_DEFAULT -1
#define TILT_ROTATION_SIGN_DEFAULT +1
or the termial window for the "bells and wistles" version.
Unread 02-02-2006, 00:27
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
Re: green
We tested the code out for the first time today, it took about 30-40 minutes to get it tracking properly.
The default colors should work, we never modified those, and the camera picked up the target both with and without a lexan cover over the cathode lights.
Two problems that happened to us which might screw your stuff up...
1. At first the camera "ran away" from the light anytime it saw it. This was fixed by modifying the sign on both the pan and tilt default sign values.
2. The camera would pick up the light fine when pointed at it; however, when it turned from one side of the pan limit to the other, it would pick up the light part way through, lose it by the time it got to the pan position, and would restart the search repeatedly. This occurred because the camera searches with the same tilt value at 3 or 4 different pan positions, then rotates back to the start of the pan positions while shifting the tilt up to the next position. During the shift to the starting pan position, it would pick up the target because the tilt shifts at the same time and the camera was now at the new tilt angle. It no longer the saw the target when it got all the way to the pan start position though, and since it had seen the target and lost it, it restarted the search, which caused the pan position to be reset to 0 and the tilt to be reset to 127, which put us back in the place we had been before the camera's first sweep. It would then repeat indefinetely. To fix this, in the 2 lines of code that set the pan and tilt values for the start of a new search (this is in tracker.c), we just made it keep the current pwm values of the servos rather than reseting.
Anyway, hope this might help other teams with similar problems.
Unread 02-02-2006, 07:21
bear24rw's Avatar
bear24rw bear24rw is offline
Team 11 Programming Captain
AKA: Max T
FRC #0011 (MORT)
bear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to behold
Send a message via AIM to bear24rw
Re: green
They go in camera.h
FAHA: Green Paint Ken Leung General Forum 7 09-03-2005 22:47
Purple Image after tryin to capture green. Code\\Pilot Programming 2 02-02-2005 16:55
Concerns regarding the green paneling/green shirts Petey General Forum 127 15-01-2005 10:35
Reputation points SilverStar CD Forum Support 73 26-05-2004 02:14
