Go to Post Remind me to wear my kevlar vest to any event you're at. - Andrew Schreiber [more]
Unread 31-01-2006, 23:42
Mike Hendricks Mike Hendricks is offline
misses his IFI control system
FRC #0973 (GRR)
Mike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to all
pic: Team 1388: Getting there ..
2004-2010: Founding Member, Technical Mentor - Team 1388, Eagle Robotics
2011: ???
Unread 31-01-2006, 23:43
Alekat's Avatar
Alekat Alekat is offline
AKA: Alex
None #0701 (RoboVikes)
Alekat has a spectacular aura aboutAlekat has a spectacular aura about
Send a message via AIM to Alekat
Re: pic: Team 1388: Getting there ..
Diggin the chassis there. I would never even think about trying to weld and get the wheel shaft holes to line up.
Unread 01-02-2006, 00:21
FRC #0973 (GRR)
Hehehe.
Ok, so maybe we cheated a little bit. Maybe these will clear it up ..
Basically, we took a solid aluminum rod, turned the outsides down enough to fit into the holes we drilled into the frame, and drilled out the center of the rod (all this was done on a mill and a lathe). Stick the 2 frame rails together, and it lines up perfectly. Clamp and weld. Once we welded the 4 2x1 braces in (you can see them in the top picture), we cut out tubes. Milled it down so 1/16" is outside the frame (so we didn't cut the entire weld off). Our wheels are going to be driven off the hub on the wheel, so the shaft doesn't have to spin. It took alot of machining, and work to get it right, but the final result is something that is dead on straight. Nothing worse than a robot that doesnt drive straight.
2011: ???
Unread 01-02-2006, 10:19
FRC #0701 (RoboVikes)
clever! , nice chassis hope to see you @ sac.
it looks like you are using the same safety goggles as us. lol
Team 701
Unread 01-02-2006, 18:16
Andrew Blair's Avatar
FRC #0306 (CRT)
I'm impressed that it was done with MIG. I've only ever seen anyone attempt something like that with TIG. Great job guys!
-Sir Francis Bacon
-Albert Einstein
East Coast Drivers Union Corey Balint FIRST-related Organizations 153 10-04-2006 15:50
Who do you think is the best bet to win the Chairman's Award at the Championship? Koko Ed Chairman's Award 58 29-04-2005 16:39
pic: Team 1388 Gearbox Mike Hendricks Robot Showcase 5 07-02-2005 17:26
pic: Team 1388 Teaser #2 jgannon Extra Discussion 7 03-02-2005 02:05
Real names, please Andy Baker General Forum 131 21-07-2004 22:07
