Go to Post Never, Never tell a prospective mentor what the actual job description is. You need to get them hooked first. :D - BJT [more]
Unread 01-02-2006, 18:18
jcatt's Avatar
jcatt jcatt is offline
AKA: Jonathan Catt
FRC #1902 (Exploading Bacon and FRC #1251 TechTigers)
jcatt is a glorious beacon of lightjcatt is a glorious beacon of lightjcatt is a glorious beacon of lightjcatt is a glorious beacon of lightjcatt is a glorious beacon of lightjcatt is a glorious beacon of light
MPLAB Issues
I have just made so modifications to the CMUCam Default code and I am having an issue building or making the .hex file. I keep on getting
Clean: Deleting intermediary and output files.
Clean: Deleted file "C:\Documents and Settings\ellicd8714\Desktop\frc_camera\camera.o".
Clean: Deleted file "C:\Documents and Settings\ellicd8714\Desktop\frc_camera\camera_menu .o".
Clean: Deleted file "C:\Documents and Settings\ellicd8714\Desktop\frc_camera\eeprom.o".
Clean: Deleted file "C:\Documents and Settings\ellicd8714\Desktop\frc_camera\ifi_startup .o".
Clean: Deleted file "C:\Documents and Settings\ellicd8714\Desktop\frc_camera\ifi_utiliti es.o".
Clean: Deleted file "C:\Documents and Settings\ellicd8714\Desktop\frc_camera\main.o".
Clean: Deleted file "C:\Documents and Settings\ellicd8714\Desktop\frc_camera\serial_port s.o".
Clean: Deleted file "C:\Documents and Settings\ellicd8714\Desktop\frc_camera\terminal.o" .
Clean: Deleted file "C:\Documents and Settings\ellicd8714\Desktop\frc_camera\tracking.o" .
Clean: Deleted file "C:\Documents and Settings\ellicd8714\Desktop\frc_camera\tracking_me nu.o".
Clean: Deleted file "C:\Documents and Settings\ellicd8714\Desktop\frc_camera\user_routin es.o".
Clean: Deleted file "C:\Documents and Settings\ellicd8714\Desktop\frc_camera\user_routin es_fast.o".
Clean: Done.
Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8722 /i"C:\mcc18\h" "camera.c" -fo="C:\DOCUME~1\ELLICD~1\Desktop\FRC_CA~1\camera.o " -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa- -nw=2066 -D_FRC_BOARD
Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8722 /i"C:\mcc18\h" "camera_menu.c" -fo="C:\DOCUME~1\ELLICD~1\Desktop\FRC_CA~1\camera_m enu.o" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa- -nw=2066 -D_FRC_BOARD
Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8722 /i"C:\mcc18\h" "eeprom.c" -fo="C:\DOCUME~1\ELLICD~1\Desktop\FRC_CA~1\eeprom.o " -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa- -nw=2066 -D_FRC_BOARD
Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8722 /i"C:\mcc18\h" "ifi_startup.c" -fo="C:\DOCUME~1\ELLICD~1\Desktop\FRC_CA~1\ifi_star tup.o" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa- -nw=2066 -D_FRC_BOARD
Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8722 /i"C:\mcc18\h" "ifi_utilities.c" -fo="C:\DOCUME~1\ELLICD~1\Desktop\FRC_CA~1\ifi_util ities.o" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa- -nw=2066 -D_FRC_BOARD
Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8722 /i"C:\mcc18\h" "main.c" -fo="C:\DOCUME~1\ELLICD~1\Desktop\FRC_CA~1\main.o" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa- -nw=2066 -D_FRC_BOARD
Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8722 /i"C:\mcc18\h" "serial_ports.c" -fo="C:\DOCUME~1\ELLICD~1\Desktop\FRC_CA~1\serial_p orts.o" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa- -nw=2066 -D_FRC_BOARD
Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8722 /i"C:\mcc18\h" "terminal.c" -fo="C:\DOCUME~1\ELLICD~1\Desktop\FRC_CA~1\terminal .o" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa- -nw=2066 -D_FRC_BOARD
Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8722 /i"C:\mcc18\h" "tracking.c" -fo="C:\DOCUME~1\ELLICD~1\Desktop\FRC_CA~1\tracking .o" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa- -nw=2066 -D_FRC_BOARD
Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8722 /i"C:\mcc18\h" "tracking_menu.c" -fo="C:\DOCUME~1\ELLICD~1\Desktop\FRC_CA~1\tracking _menu.o" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa- -nw=2066 -D_FRC_BOARD
Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8722 /i"C:\mcc18\h" "user_routines.c" -fo="C:\DOCUME~1\ELLICD~1\Desktop\FRC_CA~1\user_rou tines.o" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa- -nw=2066 -D_FRC_BOARD
Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8722 /i"C:\mcc18\h" "user_routines_fast.c" -fo="C:\DOCUME~1\ELLICD~1\Desktop\FRC_CA~1\user_rou tines_fast.o" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa- -nw=2066 -D_FRC_BOARD
Couldn't locate build tool. Check tool locations.
Link step failed.
BUILD FAILED: Wed Feb 01 18:09:32 2006
Any Suggestions would be helpfull?
Thanks, Jonathan Catt(1251)
Jonathan Catt
Co-Owner and Systems Architect of ColorScene Inc.
Co-Sponsor of The RoboShow: Orlando
FRC 1251 Alumni
FRC 1902 Mentor
Unread 01-02-2006, 18:20
Cuog's Avatar
Cuog Cuog is offline
Registered Linux User: 390661
AKA: Alex
FRC #0422
Re: MPLAB Issues
try compiling user_routines_fast by itself then the whole project again and see if that works(sometimes it does) and check to make sure all the files are properly utilized.
KK4KQO
http://voltair.us
Unread 01-02-2006, 18:42
CaseyKasem_1251's Avatar
CaseyKasem_1251 CaseyKasem_1251 is offline
AKA: John Casey
FRC #1251 (TechTigers)
Team Role: Student
CaseyKasem_1251 is on a distinguished road
Send a message via AIM to CaseyKasem_1251
Re: MPLAB Issues
Thx we tried that didnt work i searched the forum and found that the language tool locations were not set to where we installed them so we set those and it worked perfectally thx for the help though.
2008 UCF Regional Champs thanks to 233 and 86
2008 UCF Regional GM Industrial Design Award
2007 Palmetto Regional finalists thanks to 1626 and 1758
2007 Palmetto Regional Motorola Quality Award
2007 UCF Regional Champs thanks to 1270 and 86
2007 UCF Regional GM Industrial Design Award
2006 Palmetto Regional Champs thanks to 11 and 247
2006 UCF Regional Semifinalist thanks to 86 and 710
2005 Palmetto Regional finalist thanks to 25 and 301
2005 Palmetto Regional Xerox Creativity Award
2005 UCF Regional finalists thanks to 845 and 1270
2005 UCF Regional Judges Award
2004 UCF Regional Rookie All-star Award
Unread 02-02-2006, 17:49
Cuog's Avatar
AKA: Alex
FRC #0422
Re: MPLAB Issues
oh well at least you got it working.
KK4KQO
http://voltair.us
Issues with MPLAB 7.30 gnirts Programming 4 25-01-2006 22:57
MPLAB Variable Simulator? Chris_Elston Programming 3 18-02-2004 12:08
using the MPLAB IDE MPLAB SIM simulator WizardOfAz Programming 1 03-11-2003 01:24
