Go to Post Oh, you know us...kicking puppies and stealing candy from babies and all. :rolleyes: - Travis Hoffman [more]
Unread 31-01-2006, 17:04
naor52 naor52 is offline
FRC #1578
naor52 is an unknown quantity at this point
Kevin Code?
Does the Kevin code track green ligh?
If it is
How can i change the green value?
-Naor
Unread 31-01-2006, 19:18
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Re: Kevin Code?
Yes, it does track the light. There are #defines in one of the files, but changing them has caused serious problems for teams... you shouldn't need to change what it is looking for at all.
Unread 31-01-2006, 21:45
Anime-niac_2.9's Avatar
Anime-niac_2.9 Anime-niac_2.9 is offline
Japanese-crap freak(NOTE AVATAR)
AKA: Alex Abenoja, A-Squared, & Anime
FRC #0599 (Robodox)
Anime-niac_2.9 will become famous soon enough
Re: Kevin Code?
but the code should be altered. When you download the unaltered code and test your robot with it, with the camera mounted, the thing may start looking at the ground. what is the point of it, anyway?
Unread 01-02-2006, 11:41
FRC #1578
Re: Kevin Code?
I have downloaded the camera code to the prog. and conetcted all the wires to the control panell and to the power but still the camera don't responed it only works with the Demo mode...plz..any one can tell me what am i doing wrong?!?
Unread 01-02-2006, 19:34
FRC #0599 (Robodox)
Re: Kevin Code?
please be more specific. I still can't tell exactly what the problem is.
THE ROBODOX FORUM
Reading: Suzumiya Haruhi no Yuutsu by Tanigawa Nagaru
Religion: Haruhiism
If statement in .h file or Indirect addressing? Kevin NAV code... Chris_Elston Programming 11 14-02-2005 23:39
Kevin Watson's encoder code with RPM output MaxM Programming 2 05-02-2005 00:06
Team THRUST - Kevin's Code and Camera Code Combine Chris_Elston Programming 3 31-01-2005 22:28
Kevin Watson's Kick-off Demo Code! Mr. Lim Programming 27 22-01-2005 03:38
