Go to Post Why silence the rude ones and naysayers when you could have the students learn to deal with them? - JackG [more]
Unread 01-02-2006, 20:16
QuantumNinja QuantumNinja is offline
FRC #1677
QuantumNinja is an unknown quantity at this point
CMU-Cam power
After assembling the camera completely, It is apparent that the kit we recieved may not have come with a power adapter to go from the battery pack to the camera. Could someone post a picture of what this looks like, and where it connects to on the sensor board? You help is much appreciated.
Unread 01-02-2006, 21:14
JonBell JonBell is offline
None #0546 (Technotics)
JonBell is just really niceJonBell is just really niceJonBell is just really niceJonBell is just really niceJonBell is just really nice
Send a message via AIM to JonBell
Re: CMU-Cam power
The CMU-Cam is powered off of the RC, via a PWM line. The RC, in turn, draws the power for the PWM from the backup battery. If you are trying to do some bench testing, then I'd reccomend splicing quick-disconnects onto one end of a PWM cable and then connect the PWM cable to the Cam power line, the other end to the backup battery pigtail, and then the pigtail to the battery.
CMU Cam prosseser running hot kjhobin Programming 4 10-01-2006 21:57
Video of the (not so) humble beginnings of the CMU cam. Elgin Clock Programming 0 29-03-2005 21:31
CMU Cam GUI Arc736UV Programming 2 15-03-2005 19:26
CMU Cam servo jitter adamdb Programming 3 01-02-2005 14:42
CMU cam and Linux? scitobor 617 Programming 2 30-01-2005 23:02
